Question about Goodman CKL24AR24 Air Conditioner
Heat works but ac dont
Fan works great on heat.but on ac it comes on for 2 seconds off for 10 seconds on for 2 ect...ect...replaced thermostat but did not work still same problem.outside condencer works fine any clue??????????thanks in advance kevin
  • 614 Answers
Does unit do this when you turn the fan to the on position. If so you have a bad fan sequencer. Posibly
Posted on Jun 14, 2009
Malibu overheating
Your cooling fan is not coming on when engine is warmed up. Could be the fan motor is broken. You can check this by checking the fan operation when the a/c is on and engine is warmed up. Look at the fans and see if one or two are on. If both are on then your temperature relay is unplugged or broken. If just one fan is on then most likely the fan that's not on is broken.
Mar 23, 2014 | 2007 Chevrolet Malibu Maxx LTZ Hatchback
I guess I need a Honda Expert. I have a severe overheating problem. I have now spent $ 2,000 trying to fix this. What happens is, as I am driving, the anti-freeze and the motor get hot, and the overflow...
have you checked the head gasket. oil with gunk on the cap. water when standing have a film on it. gray or black smoke coming out of the exhaust... the thermostat been replaced ??? need to check these. dont keep throwing money at it. in the end you can change every thing and cost you a fortune. then find out it was something that just cost a few dollers or pounds.
Oct 16, 2013 | 1992 Honda Civic
Hiiiii..... I have samsung Thermostat AC, But i dont know how to use the warmer / heater for the same. I dont know about the model number but its one of the old AC written thermostat. Now help me out how...
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Jan 03, 2011 | Samsung AW1203B Air Conditioner
AC WORKS FINE HEAT COMES ON BUT WHEN TEMP IS REACHED FAN NEVER GOES OFF AND TROUBLE WITH HEAT COMING BACK ON
When temp reached to thermostat level heatewr only will cut off not the blower. And secondly all thermostat at heat stage will cut off at the end of +2 degree and cut in starting of -2 degree.
E.g; If you keep 30 degree heat it will cut off at 32 and cut in 28 degree.
Dec 07, 2010 | Crosley CAE12ESR Air Conditioner
Furnace blows cold air
Sometimes the fans kicks in by time ---or by heat...even if the heat cycles dont starts . Is this gas or electric,, name brand,.... model # ect...ect..
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
Here is my problem... 1998 Jeep Cherokee Sport 4.0 straight 6. Overheating. New thermostat,new water pump,hoses,sensor on the water outlet, no leaks. electric fan comes on with the a/c only does not come...
Sounds like an air lock, from when you changed the water pump, most likely. Take a heater hose off, and try and get some air out of it. Then, idle it with the rad cap off, until the thermostat opens. You should see the water level drop when it does. If not that, then the sensor for your fan needs to be replaced. The fan always comes on when the AC is on, but the sensor turns it on when the AC is not on.
Aug 27, 2009 | 1998 Jeep Cherokee
Car is reaching 220 when i idle...fans dont come on
On that car when you put the A/C on it throws it into a bypass mode to where the fan runs it's normal,but when you don't have the A/C on The fan should come on around whatever the thermostat rating is . try dropping the thermostat down to a 165 rating and also check your tempature sensor to see if it's operating at the right setting. Useually when a car over heats it'll damage the sensor so best to replace it to make sure and check your water pump flow also,it should move the water in the radiator quite rapidly whenever the thermostat opens .
May 02, 2009 | 2006 Chevrolet Cobalt
44860 thermostat won't activate in heat mode
I had the same set and problem. I had a RC wire which is the power to the AC. But didn't have an RH wire which is the power for the heat. To fix this just use the jumper wire and insert it in with the RC wire and hook it up to the RH. Fixed my problem.
Oct 20, 2008 | Hunter Fan Company 5/1/1 Programmable...
I have an amana package system heat pump model number phb30c02e , sometimes the indoor blower will not kick on thus making no air come in the home at all throught the vents, i tried a new copasitor and ...
Sometimes the thermostat can have a burnt place in the fan contacts. This stops the interior fan motor because the compressor wiring is not interconnected to the interior fan. The compressor command is the yellow wire. The interior fan command arrives from the thermostat on the green wire. Check the green wire for delivering 24 volts AC to the fan relay.
During heat, the heat is electrically interconnected with the interior fan. Thus, if the thermostat is bad, the fan will work properly during heating. I know July is a bad time to turn the heat on, but this is a method to see if the interior fan works properly and is not getting the proper command during cooling.
Jul 24, 2008 | Amana Heating & Cooling
Goodman CKL24AR24 Air Conditioner Logo
87 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
