Question about Omega BMJ330 Mega Mouth Juicer
Wont turn on
My BMJ330 is brand new out of the box. I plugged it in, turned it on and nothing happens. I checked the outlet with a lamp so I know that is not what it is.
Why kitchenaid blender wont turn on ?
It's brand new, take it back. Messing around can only void your guarantee.
Jul 12, 2014 | KitchenAid KSB560 5 Speed Blender
Ninja blender blade wont turn with food in container.
make sure blade is pressed tightly onto shaft... should click into indent. if not then you need a new blade piece.- stripped
Aug 18, 2012 | Blenders
I have a Vita Mix 3600. I was making a fruit smoothie (banana, blueberry, raspberry), milk, small scoop of protein powder . Speed was on 1. I depressed the lever to reverse. I don't remember if I had...
Yes that is strange, if you let it cool down and try it again with pushing the re-set button and still does not work, try plugging it into a different outlet. Find something in your place that you know outlet is working, lamp, toaster you know. If does work in another out let, then you of course griped that breaker. Then check your breaker box to see what breaker is tripped, and switch it back on, might just of had a power surge based on putting on reverse. If that don't work, I suppose possibly something in motor or switch went out. Please let me know, if it works, I will take a banana smoothie LOL
Jun 09, 2011 | Vitamix Vita-Mix 1364 3-Speed Blender
My ninja blender is brand new and i plugged it in and it doesn't start. what do i do?
There's an arrow on the lid and an arrow on the handle and they have to line up and point towards each other. When you lock the lid down it pushes a pin inside the handle which in turn pushes a swith inside the base of the blender that tells it that everything is in place and that its safe to use. Now its ready to use
Apr 02, 2011 | Blenders
Can not get Margaritaville blender to start
look for rocker switch left side of machine near bottom
Jun 30, 2009 | Margaritaville Frozen Concoction (DM1000)...
Wont turn on. its plugged in and the switch on the plug socket is turned on
have you fix the container? most blender today has a switch to verify if the blender container is fixed to the motor.
May 31, 2009 | Blenders
Motor won't turn on
Hi , Try to check with multi tester the power cord ,test the two tips of male outlet switch on tested read the continuity /if not reading ,pulout if push type /if permanent open cover below test the test the cord inside to the male plug if does not response cord is problem,check also fuse test both end of fuse not reading fuse buste then replace thats all goodluck.
Nov 12, 2007 | KitchenAid KSB5 Professional Stainless...
Blinking lights on KitchenAid blender
Alternating blinking lights on a Kitchenaid blender indicate a bad circuit board which is unable to run the motor properly. Unplug the blender, take the jar off, and turn the spindle by hand. Then plug it back in. If it does not work properly, try a different outlet (perhaps not in the kitchen). If nothing works, the blender needs to be repaired.
Aug 27, 2007 | KitchenAid KSB3 Classic Work Top Blender
Omega BMJ330 Mega Mouth Juicer Logo
51 people viewed this question
Top Omega Blenders Experts
rhodesworks
Lesley Cameron
Lesley Cameron
Glenn
Glenn
Are you an Omega Blender Expert? Answer questions, earn points and help others
