Question about Royal Sovereign ARP-3014 - 14,000 BTU Portable Air Conditioner and Dehumidifier Contemporary Design 24 Hour Timer Remote Control Included
Hi, My royal sovereing ARP-3014 fan wheel broke into pieces an i wanna know if it can be replaced or i need to buy another one? thanks.
If i can replace it, please, may you tell me how? its because it have a copper tube that carry some gases or something like this, i dont want to broke it to. thanks again.
How do I replace the frost guard switch
The frost guard switch is usually attached to one of the copper tubes on or near the evaporator by a little spring type clip. Without a model number I cannot look up a diagram, but you could google it. Most of the self contained freeze switch units that I have run into require them to get quite warm like 90 degrees F before they will reset themselves. Try a hair dryer on it to reset before buying a new one
Jan 27, 2015 | DeLonghi Dehumidifiers
After the unit is on for a little while it leaks water. Some is still in the tank. The tank is not full when it leaks and the tank is on tight. The unit is only about 3 years old and the air filter is...
What has happened is that the tubing that carries the water to the bucket is partially clogged. To solve this problem, do the following:
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
Hope this helped you.
Jul 11, 2011 | Haier HD308 Dehumidifier
The small part that tells the unit when bucket if full broke and we would like to get a replacement part
Your unit has a one year warranty, so hopefully you fall into that time frame and still have your Proof of Purchase. Even if the warranty has expired you can purchase the tank activation switch/trigger directly from NewAir 800-734-0405.
Hope this helped you. Please let me know. Thanks.
May 28, 2011 | NewAir AD400 Dehumidifier
I have just had my second dehumidifier stop working. Both have been used exclusively in my basement from spring through fall. The first one (kenmore) lasted 5 years, and the second one (LG) lasted 2 years....
Brad, you have really hit on something. In fact, it's more common than the manufacturers want the consumers to know. Actually, the corrosion starts after the unit is not used for several months and then put back into service. Is there something that can be done, on the consumers part to help prevent this? Perhaps, but, it would require routine maintenance, which most consumers don't even think about, until they ave a problem. Like cleaning the air intake filter regularly, checking the drain hole or tube for clogs and when not in use, storing the unit in a dry environment. As far as preventing the corrosion is concerned ... Doing what you did, to expose the front coils and in addition, wiping the down the coils and spraying a light coat of WD40 on them, may slow the corrosion process.
The bottom line is this. Until the manufacturers switch from aluminum coils to copper coils, the problem will always be there. But, the downside to the consumer will be, copper is more expensive than aluminum and therefor, the cost of the dehumidifier will be higher.
Again, good job, Brad! Your theory was well thought out.
Mar 23, 2011 | LG LHD45EL Dehumidifier
I've had the lg LHD45EL Dehumidifier for about 1.5 years now. I have used it every spring/summer. I turned it on this year and it runs but the water does not collect. Obviously something is wrong any idea...
I found the same thing. I've had my LHD45EL for 2 or 3 years. Worked great for my basement. This year I hear it run, but it doesn't collect water. I cleaned the filter and of course nothing. I took the back cover off, and tried running it. The condenser runs, but the copper tube leading up to the coil doesn't get cold. My guess is that the freon (or whatever refrigerant they are using) has leaked out. There doesn't appear to be any way to recharge it, the original tube has been crimped and soldered. Looks like junking it and buying a new one is the only option unless someone is good with a torch and solder. My question is whether to go LG or not.
Jun 09, 2010 | LG LHD45EL Dehumidifier
Does not cut off when humidity level reached
I have the same unit and found that a sensor that attaches to the evaporator and the attachment holding it to the coil rusted away. Made a new clip from copper tubing and now it works again.
May 13, 2010 | Maytag M7DH65B2A Dehumidifier
Royal Sovereign ARP-3014 - 14,000 BTU Portable Air Conditioner and Dehumidifier Contemporary Design 24 Hour Timer Remote Control Included Logo
44 people viewed this question
Top Royal Sovereign Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Royal Sovereign Dehumidifier Expert? Answer questions, earn points and help others
