Question about Sewing Machines
How do you adjust the halifax switch on model # 385.1950280
The machine flashes the number 10 and then Er when it gets turned on
Er has appeared on the stitch width screen instead of a number and the machine is unresponsive. Suggestions before I take it for service?
Try turning off and unplugging for a while to see if it will reset.
If that doesn't work, then the software or a component has failed. Best to take it for service.
Feb 07, 2016 | Sewing Machines
How do i fix ?
Consult the owner's manual. Usually there is a list of error codes in the troubleshooting section that may help you determine why your machine is malfunctioning. If not, you can search the internet for:
Manufacturer + Model + ER-16
If no results, contact the manufacturer's support site.
Dec 10, 2015 | Sewing Machines
Sewing machine stops sewing
what type of sewing machine do you have, and have you tried turning it off, then switching back to the sewing position. you may need service, or an external bobbin winder.
Nov 18, 2014 | Sewing Machines
Singer 6038 tension dial not working
there should be small washers ( discs with a tapered flange to direct the thread between the plates ) if they are not under the spring behind the tension adjuster knob then that will be your problem
if they are there then check that the tread is between the plates and not behind them
missing plates are available from a sewing machine mechanic sgop
May 07, 2017 | Singer 6038 Mechanical Sewing Machine
The dog feed stuck in the downward position.
Have you turned the machine off and then back on?
The switch may be broken and you will need to find a sewing machine repair shop that repairs all brands of sewing equipment.
If you decide to purchase another machine try a different brand. This one seems to have on a lot of issues.
Feb 19, 2010 | Sewing Machines
When you set the switch for the feed dogs to be in the up position, turn the handwheel 1 complete revolution and they should come up.
Feb 19, 2010 | Euro-Pro 9105 Computerized Sewing Machine
I want to know which knob I use to make the stitching narrower
there are generally two variable controls .. one adjusts the stitch length (distance between stitches measured in stitches per inch) ... the second is stitch width .. that adjusts how far the zigzag moves left and right .. thats usually just a number from 0 to 10 or so .. 10 would be maximum width .. 0 would be used for straight stitch ..
so you need to adjust the stitch width control to make the stitching narrower .. the controls are called different things on different brand sewing machines .. if you have the brand and model number then there may be instruction booklets available ...
Jan 04, 2010 | Sewing Machines
ER message on Kenmore Sensor Sew 70
the halifax switch under the top cover needs to be adjusted
Nov 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Sewing Machines Logo
56 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
