Question about Homelite Mighty Lite Lawn Trimmer
Hard to start
I have a mighty light 26vt onley about 2 yr. old. it is hard to start but runs a littli and sounds like it is runing of gas. please help me.
    Problem Solver:
  • 6 Answers
Take the carb. apart and blow thru all the little passaged w/ carb cleaner you probably have a passage pluged with yuck. Make sure you use new gas when you try to start it again.
Posted on Jun 14, 2009
What is wrong if it will not idle
It would help to have engine codes but it sounds like leaking injectors hard to start because any time the key is on gas is just running into the engine. No idle to much gas. Oil level high because of gas in oil going past rings could blow oil pan off. High speed fine. replace injector or injectors. Look down throttle body with key on and see if gas is leaking out. If this help someone please rate it
Dec 20, 2011 | 1997 Jeep Grand Cherokee
Do I mix the gas with 2 cycle oil for the homelite mighty lie 26vt gas grass trimmer and what is ratio I need?
Your MightyLite trimmer requires a 50:1 fuel mix. Use a high quality 2 cycle oil that is made for lawn equipment. Do not use outboard boat oil...it will cause your trimmer to run too hot. If you use the mix that has fuel stabilizer in it, then the bottle will be 3.2 ounces. Use one 3.2 ounce per gallon of gasoline.
Aug 30, 2010 | Garden
Have a homelite grass trimmer crank ok run ok will trim grass for about 2 minutes then stop if you crank it and run for few seconds and the give it the gas it will not take gas just stop have replaced both...
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
May 02, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite 26vt Mighty Lite carb settings
Setting up the carb right on a trimmer is like setting one up on an RC gas operated car. It takes someone with a good year,and a lot of experience doing it. If youre new at it,youre not just going to be able to get it tuned,well you could,if you want to spend a few hours. Just take it to someone who does it,they wont charge you much and it will save you a lot of aggrevation.
Aug 13, 2009 | Homelite Mighty Lite Lawn Trimmer
I have a Homelite 26vt Mighty Lite that will only start when I dump gas straight in the carburetor after it uses that gas it will not start
you have 1 of 3 things wrong
1 you have pluged jets
2 you have a pluged fuel filter
3 you have a stuck float
4 fuel line is crimped
1 2 3 4 thats all it can be
preasurise the fuel tank by blowing into it when almost empty
this will as times clear jets
if fuel line kinked un twist it
best bet buy a rebuild kit for the carb and enjoy some time with a screw driver
Jul 27, 2009 | Homelite Mighty Lite Lawn Trimmer
My mighty lite will start but it runs on full choke but it stops
Your carburetor needs cleaned you had old gas in it this cloggedup your jets and made the diaprams hard witch will not move enough to pump enough gas to keep engine running off choke.
May 15, 2009 | Homelite Mighty Lite Lawn Trimmer
94 chevy z 71
Old gas turns to varnish which can cause the valves to seize in the valve guide,bend push rods or even bend the valves themselves.NEVER put old gas in an internal combustion engine.
Mar 14, 2009 | 1994 Chevrolet K1500
Homelite Mighty Lite Lawn Trimmer  Logo
418 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
