Question about HP Officejet 4620 All in One
Fax error 344
Will not fax to 1 specific number
  • HP Master
  • 3,368 Answers
Posted on May 29, 2016
3 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: fax series 920, can receive but not send faxes, error code 344*
Do you have or are you sending a fax to a party that has a DIGITAL PHONE SERVICE?
Posted on Jun 06, 2009
  • 117 Answers
SOURCE: I'm getting error code 388 when I fax to one
The fax machine has originated a fax session and detected a remote fax machine but has been unable to connect to it. If the machine is in V.17 mode, it is likely the connection has been interrupted. In V.34 mode it is also possible for this error to occur due to compatibility problems with certain machines and/or line conditions.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
or
2. Disable V.34 on the local machine and attempt the transmission using the V.17 mode. I hope I have been able to help you. Have a NICE Day!!
Posted on Jan 26, 2011
My HP 8600 Premium no longer sends or accepts FAXes. It says it's connecting, but never does. And returns error 344. I know the other fax machines are working fine. Please advise.
Here's a document that explains some on the fax error codes: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=buu02549
The code 344 indicates noise or static on the line and usually the best way to get around that is to disable Error Correction Mode and/or lower the fax speed.
To disable the Error Correction Mode (ECM) touch the right arrow, then Setup, then Advanced Fax Setup, then down arrow and then Error Correction Mode and set it to Off.
To lower the fax speed, also go to Advanced Fax Setup and set it to Slow.
Nov 07, 2014 | HP Officejet Pro 8600 Premium e-All-in-One...
Error 386
Hi Error 344,
Is telling you the remote end has hung up the call which means it may not be a fax number (you called a voice line number for example, you can confirm if it as fax by just calling the number on your phone if you hear the whistles of a fax then that's not the cause).
I'm not familiar with the HP model but if it is "Super Group 3" (you can tell this if the transmission speed is capable of above 14.4kbps) and you're trying to call an older fax the remote machine may not be able to recognise the "Calling tone" your machine is sending and so it hangs up. You can try to remedy this by temporarily disabling Error Correction Mode (ECM) in your machines fax set up menu this will disable the Super Group 3 capabilities of the fax and maximum transmission speed will be reduced to the older Group 3 machine. HP website recommends the following:
Error Code: 344, 345, 346, 347, 348, 349 ECM, 350 ECM, 351 ECM, 352 ECM, 353 ECM, 354, 355 Definitions
  • The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power-related problems.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote user pressed the Stop key while the reception was in progress.
  • Under rare conditions, incompatibility between the two machines might cause the remote machine to abandon the call.
Solutions
  • Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Jan 23, 2014 | HP Officejet 6600 e-All-in-One -...
I get the error 344 message continuously to this one number i'm trying to fax to. i can fax to any other number, but this one # almost always produces this error 344?
Then the problem is most definately on the fax you're trying to send to, and not on your machine. If it works to all other numbers but not to that specific one, then you can shift the blame to the other guy.
Jul 28, 2010 | Office Equipment & Supplies
Fax error 344 - HP officejet 4255 all-in-one
fax error is remote machine not responding to your fax.the other fax has stopped communicating.this is a comms error.
Jun 29, 2009 | HP LaserJet 3050 All-In-One Printer
Fax series 920, can receive but not send faxes, error code 344*
Jun 04, 2009 | HP 920 Plain Paper Fax
Error code 344*
Error code344 shows that The remote machine has failed to respond to a fax command from the product because the connection was interrupted.The remote user has pressed the Stop button while the remote machine was receiving.
Under rare conditions, incompatibility between the two machines can cause the remote machine to simply abandon the call.
check here for more information
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00062808#A5
Jan 26, 2009 | HP Officejet 4315v All-In-One InkJet...
Fax
344 Error can be caused by a few things. One of the following is occurring:
The sending fax has failed to respond to a fax command from the receiving fax due to poor line quality or fax interruption.
The sender has pressed cancel button while the reception was in progess.
In rare conditions, incompatibility has been encountered by two faxes and causes the sending fax to abandon the fax call.
Solutions:
Fax session was using ECM. Check your fax settings under the fax set-up menu on the printer. Disable the ECM (Error Correction Mode).
Fax at a different time to see if line quality improves.
Try relocating the fax to a differnt phone plug.
Replace the phone cord attached to the fax/printer.
Aug 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Error 344- Fax Function
Try to connect the phone line from the phone oulet directly to the line one connection of the machine.
May 09, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Comm Error 344 is: (Note that this is on the receivers end)
The remote machine has failed to respond to a fax command from the product because the connection is interrupted.
This website will show you what the error codes are.
Feb 26, 2008 | HP LaserJet 3050 All-In-One Printer
HP Officejet 4620 All in One Logo
232 people viewed this question
Seeker5211
Seeker5211
