Question about Sony VAIO VGN-FE870E/H Notebook
Charger pin which you connect to laptop socket gets heated.
The charger PIN where you insert into the socket of the laptop gets heated heavily.  I have a Sony vaio laptop. I thought that the charger is the problem then bought another charger with same specifications and tried but still the problem is the same. The pin gets heated and feels like it will melt.
Any solutions..
    Problem Solver:
  • 17 Answers
You will need to take this in to a BackStage center at any Sony Style store to have it looked at for defectives.
Posted on Nov 11, 2007
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
My tablet wont charge when put into mains charger this is the second time my charger connection feels lose
which end feels loose, the dc socket on the tablet or the mains (240volts) end (three pin plug?).
If the mains end, you need you need to get a new charger, it is dangerous to continue using it.
If it is the dc socket end, there is not a lot you can do about it, as it is solder to the mainboard, unless you can unsolder it and insert a new one.
Have you thought about gluing the dc side into place, so it cannot move?
Sep 08, 2014 | Archos 101 Internet Tablet
How to concert laptop to tv
what do you mean by concert, Do you mean connect?
If you do then you will need a 15 pin to 15 pin vga lead. Connect it to the 15 pin socket on the laptop, connect the other end to the tv's 15 pin socket if it has one. Then select PC on the tv's input source menu using the tv remote. Switch on the laptop and it should display on the tv.
May 06, 2012 | LG Computers & Internet
When you put the charger they have light and no power
Please remove and clean the Battery terminals of the Notebook, make sure that the output pin of the AC Adapter is properly connected to the notebook. The fault might be either with the output pin of the AC Adapter or Input DC socket of the Notebook.
Mar 24, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
System won't post with the 12 V cpu power plug connected (only runs for about 5 sec)
switch off the system and remove the processor heat sink and the processor clean them with a clean cloth now insert the processor in the socket then apply athin layer of heat sink compund to the processor and fix the heatsink tightly in the socket an drmove the memory card and clean with clean soft cloth and insert them and restart the computer if the problem still presists change the processor with any sutable for the socket and check if the problem still presits remove the f pin conector from the smps and switch on the computer if the processor fan is working properly then switch off the computer and recontct the four pin conector and switch on if the processor fan just initate then you have problem with motherboard
Dec 28, 2010 | ASUS M2N68AM PLUS Motherboard AMD Athlon...
InvaMed Sovereign Mobility Scooter Model S888NR battery charger red light flashing to indicate fault. I have a multimeter and want to know how to test the charger. I need a wiring diagram and to identify...
Hi. Its easy to identify the pins out. Put the probes into the socket on the scooter to read the polarity. the two terminals on opposite sides will be the positive and negative battery supply. The pin to one side is to disable the scooter when the charger is connected. This terminal is normally connected to negative when the charger socket is in place.
Most faults like this are caused by a broken wire in the charger plug orv by a faulty connection in the scooter. Sometimes the charger socket is faulty, check for heat damage or melted plastic.
Check the battery connectors. Good luck. Neil.
May 15, 2010 | Health & Beauty
The audio socket on my Nokia 6613 cell phone is broken inside the phone where the pin end of the charger plugs in. How can i repair this?
Its simple, provided you have a phone screw driver and you know a store where you can buy the audio broken socket and the pin end of your charger.
Turn off the phone, remove the battery, loose all the phone screws and carefully remove the phone cover. Locate the broken parts and buy a new one and do the replacement.
If I am not mistaken, what you are referring to as "pin end of charger" is called charging port.
If you can't get any of the above fixed, then I would advice you give it to an an expert to do for you. But try is yourself, its very simple but you just need to be careful. You can start learning for there.
I wish you the best.
Dec 16, 2009 | Computers & Internet
My acer aspire 5315 doesnt charge properly.
I'm sorry to say that your initial fears are correct and the pin that the adapter connects to in the laptop is loose. This is a common problem with laptop's and can be easily dealt with.
Now I'm not going to tell you to open the laptop up and de-solder the adapter (unless you want me to).
Because this is a fiddly job and you have to order the correct adapter i recommend you take it to a reputable repair store and have them replace the adapter for you, don't let them tell you that you need a new motherboard as this is not the case at all, adapters can and do get regularly get fixed and is not that expensive.
Good luck.
Aug 18, 2009 | Acer Aspire 5315 Notebook
Dell c640 charging problems.
Instead of spending alot of time trying to do something that could potentially harm your laptop..why not just buy a power supply?
You can get one here Click here for about 16 dollars. That's a great deal they are usually about $60 and its a Dell brand not some off brand.
Good Luck
Jan 18, 2009 | Dell Latitude C640 Notebook
Sony VAIO VGN-FE870E/H Notebook Logo
115 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
