Question about Samsung GT-C3312 Cellphone - Unlocked Phone - US Warranty - Silver
My phones blue tooth is not turning on even after format
Help me
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 77 Answers
Its defective.. it will not work anymore..
Posted on Mar 20, 2014
2 Suggested Answers
Bajanguru
  • 7752 Answers
SOURCE: D900 Bluetooth
try a hard reset *2767*3855# then try again
Posted on Jul 04, 2008
How to you set it up with your phone
In order to set up your blue tooth device to your phone you first must turn your blue tooth power to on in your phone menu then you must turn your blue tooth device into discovery mode.this usually is done by holding the power on for 6 to 10 seconds and a solid light will be on,then in your phone menu you can add or search for blue tooth device if you have your blue tooth in diuscovery mode the two will pair then you must enter a pin or pairing code,most manufatures of blue tooth devices use a 4 digit factory pin or pairing code they are as follows 0000,1234,9999 or 1111 enter the code and they will pair ,once paired it might ask you to connect ,selet ok or yes and your in business, i hope this helps
Feb 21, 2011 | Plantronics Explorer 230 Bluetooth Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
Hi wat is the shortcut to turning the blue tooth
hey brian
in this model there is no short cut for blue tooth as such but you can set a short cut by personalising your short cut keys like your joystick keys or even your selection keys.
hope it helps
Oct 03, 2010 | Sony Ericsson W350A Cell Phone
Im trying to turn on blutooth on my nokia 5800 it is coming unable to perform bluetooth operation
Hi,when trying to use a blue tooth and it shows (unable to perform blue tooth operation, Is because the blue tooth is corrupted.
You will need to format phone to restore blue tooth .
First: better use kasperaskey anti virus.
If your desktop pc or laptop has antivirus,
have your pc scan your fon memory through bluetooth, or usb cable
OR:
If you have Virus On mobile
1 - remove memory card.
2 - dial *#7780# or *#7073*
3 - It format your Phone
4 - Format memory card.
and enjoyyyyyyyyyyyyyyyyyyyyyy
OR
FORMATTING PHONE
Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone.
Read and learn more about flashing and how to flash a phone on this links.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Aug 20, 2010 | Cell Phones
My bluetooth dosent work in my nokia 6600
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
But if it doesn't pair after you've tried the above, that means the blue tooth is corrupted and will need to be flashed to restore bluetooth back.
FORMATTING PHONE
Read and learn more about flashing and how to flash a phone on this link.
Take care.
Take care.
Jun 30, 2010 | Nokia 6600
Blue tooth connectivity
I would suggest u to remove ur memory card and receive a similar file on the phone memory…try to play it…if this happens then the problem Is there with the memory card…it may b a virus problem…format ur memory card…take backup of ur important data in the memory card and format it...
Oct 09, 2007 | Nokia 6233 Cellular Phone
Nokia3230. Inbox messages doesnt open
you got infected with serious virus . you have your flash/format your mobile. you may lose your data in your mobile phone like sms , contract , pictures,song, etc . if you are ready to do this follow the simple steps 1. Trun your phone off 2.Press * then 3 and power on button all at once till the black and white screen appears with the word "formatting" 3. wait for few second till the process ends 4. now your mobile is ready and free from errors and it just like the new mobile phone now 5. If you want this not to happen if future . Please don't use blue tooth but if you can't live without it get anti virus installed on your phone then use the blue tooth
Aug 17, 2007 | Nokia 3230 Cellular Phone
Blue tooth LED indicator
try going to back to your bluetooth settings and making sure you phones visibility or "find me" mode is turned off. This is a good idea anyway cause anyone can find your phone. Then consider most people don't change their passwords so hacking into your phone and reading your texts and looking at your pictures and even trade things back and forth from their phone to yours!!!
May 08, 2007 | Motorola Mobility RAZR V3
Camera wont work
Dear if ur cammra is not working and also gallery is not opening or ginving a message of gallery is empty and some time blue tooth is also not working its problum form blue tooth module resold it or replace it need special tools. but before it format ur phone.
Mar 27, 2007 | Nokia 6600
Samsung GT-C3312 Cellphone - Unlocked Phone - US Warranty - Silver Logo
14 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
