How to reset the error c2454 for bizhub c6500?
I have replace the black developer then my machine is work then i put that developer with error to the other machine and the error comes out the same how to reset it?
  • 44 Answers
SOURCE: Trouble shoot error code 2701 in bizhub c6500
check the yellow charge coronas and see if their dirty. If they are blow off the toner on the grid and wires
Posted on Nov 29, 2009
goodgold
  • 389 Answers
SOURCE: Error codes for Konica Minolta bizhub pro C6500
C6500 Scan sensor or scan problem
Posted on Jan 16, 2010
Bizhubman
  • 108 Answers
SOURCE: Have a konica bizhub c6500
C 2861= Gamma correction/Y aborted. Patch output voltage is high.
Possible causes: Printer control board (PRCB) Developing unit/Y
PGC sensor (PS11)
Posted on Oct 01, 2010
ctf1800
  • 4402 Answers
SOURCE: Hi, I have a C6500
The fuser exit rollers are the light grey painted rollers on the exit of the fuser itself. There is a slider mechanism that when slid forward or towards the rear, will adjust the pinch of the roller. Primarily it is there to deal with what is called a waxing effect where the rollers physically leave an impression in the soft toner on thick stocks. Reducing the pinch for thick stock reduces this. However, when doing thin stock, especially letter size paper, jamming can occur if the pinch is not engaged since there is no physical contact to drive the paper to the next conveyance rollers when doing duplex or face down printing.
The slider can be found on the left side door of the fusing unit itself, near the front. Normal operation is in the middle.
Replacing the CDB is just one of many troubleshooting steps, it is not the end all to this.
The 3102 code you encountered has nothing to do with temperature and humidity. It is a code related to the failure of the fuser conveyance. Gamma correction is also unrelated because gamma correction is image related, not conveyance related.
I highly suspect that you are encountering this code because of some kind of failure related to the fusing unit itself, again related to the movement of the fuser, which usually is in motion during many test modes of the main body components. Check all the connectors to ensure they are seated properly. The previous document relates to what to check and replace related specifically to fuser pressure roller.
We do not leave fusers at the customers either. We have spares at the shop that we rebuild during slow periods. This is simply our own initiative, not the norm, and is also a part of our troubleshooting regarding fusing unit related errors that are not so obvious...it is part of the elimination process, as some fuser related codes can be caused in other areas, such as the CDB, a bad conveyance clutch or motor or simply timing adjustments that are out of the normal range.
PROBABLE CAUSES:
1.One of the gears in the fusing unit gearboxfails. The shaft for fusing unit gear/H has been changed so that it is now supported at both ends instead of just
one end. The gear is now made of a stronger material.
The new design has been incorporated into all bizhub PRO C6500 machines beginning with s/n A03U0000787. A replacement gearbox is available for
machines with lower serial numbers. For the machines with serial numbers between A03U010000788 and A03U010001446 the fuser gearbox is already
updated and only fusing gear /H (p/n A03U808811) needs to be replaced.
Note :See attached Bulletin Number5923.This only applies to bizhub PRO C6500. All other models have the new style. To viewthe PDF, Adobe Reader®
must be installed. Adobe Reader® can be downloaded for free from the Adobe® web site at: Adobe - Adobe Reader download - All versions .
2. The machine cannot determine the separation cam home position.
Check the following items PS16 (p/n 08AA 8551 2) and Release Actuator flag (p/n A03U 7244 00). Make sure when the fuser jam release green knob is
turned counterclockwise, the Release Actuator flag (p/n A03U 7244 00) blocks and unblocks PS16/PS17. Check to see if the sensor is disconnected. If
turning the Fuser Jam removal Knob does not change the position of the Release Actuator flag, then check the drive gears associated withM30 (p/n 27LA
8003 0) for broken or stripped drive gears andreplace them if damaged.
3. A one-way gear (p/n A03U 8093 00) is slipping in the fixing drive assembly.
Replace the (3) fixing drive gears with the modifiedFixing Drive Gear/M 22T (p/n A03U 8093 11) andthe fixing drive shaft/A (p/n A03U725800).
Please refer to the attached Parts Modification Notices for details. To view a PDF, Adobe Reader® must be installed. Adobe Reader® can be downloaded for
4. Failed fixing limiter.
Replace fixing limiter (p/n 65AA53651).
5. Failed ICP14 on Conveyance Drive Board
Replace Conveyance Drive Board (p/n A03U H050 04).
Posted on Apr 27, 2011
SOURCE: konica minolta Bizhub C6500 error code 2424
Hi, I have a C6500 Bizhub pro, but, recently displays an C2404 error. I need to print an urgent job and y can't!
Please helpme!
Posted on Sep 15, 2011
Hi Can you help me how to fix this problem Konica Minolta bizhub pro C1060L error code C2454 and full black background copies and prints,the machine is brand new
Recommend you get a tech out to look at unless you know all of these as they are all that can cause this code:
1. Check that the process unit is correctly installed without looseness, and reinstall or repair it when there is any abnormality.
2. Check TCRS, and clean or repair it when there is a sensor dirt or any abnormality. (Wiring diagram: Main body (2/4):20-B)
3. Check the developing section, and clean or repair it if there is a sensor dirt or any abnormality.
4. Check the connector connection and the wiring between PRCB and TCRS, and repair it when there is any abnormality.
5. Check the connector connection and the wiring between PRCB and the developing motor, and repair it when there is any abnormality.
6. Rotate the developing motor by I/O, and repair or replace it when there is any abnormality. (Wiring diagram: Main body (2/4): 15-B)
7. Replace TCRS.
8. Replace M5.
9. Replace PRCB.$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Jan 03, 2016 | Konica Minolta Office Equipment & Supplies
C 2454 Code
Printer control board (PRCB) 4 choice $$$$$$$$$$$$$$$$$$$$$$$$
Developing motor/K (M23) 3 choice
TCR sensor/K (TCRS/K) 2 choice
1. Clear black developer counter, replace the black developer an run required procedures
Apr 02, 2014 | Konica Minolta Bizhub C6501 C6500 Ikon 550...
Error code C-2704 mean on C6500 Bizhub Pro
Abnormality in the black charging unit.
Possible causes:
Black charging unit
HV Unit
Print Control Board
My best guess is that you have a faulty charge unit. Try swapping the units around with another colour and see if the fault code shifts.
Dec 30, 2013 | Konica Minolta Bizhub Pro C6500 Color...
I have c6500 konica minolta bizhub and i am getting c2452 code what i shouls do?
check the magenta developer unit, might need to replace the developer, also might have to replace the Toner sensor located under on the unit
Dec 28, 2013 | Konica Minolta bizhub C250 All-In-One...
Bizhub c6500 c2454
Black developing unit fault, has the black developer been replaced? Was it replaced correctly, with required counters cleared and proper test run after install? Was who ever installed new developer using a vacuum cleaner? If so might have destroyed the sensor located below the developer unit. (NEVER EVER USE A VACUUM CLEANER TO REMOVE DEVELOPER STATIC ELECTRICTY can destroy the ATDC (Automatic Toner Density Control) sensor. Toner mixes with the developer, on any Developer unit. So could have a bad sensor or control board. As for the counters if the developer was replaced but counters not properly cleared then copier thinks the developer is old and will adjust voltage as required when in fact new developer is installed and messing with image issues. KONICAMINOLTA PRODUCTION PRINT MACHINES USE THOSE COUNTERS!!!!!!!!!
Oct 07, 2013 | Minolta C250 Color Copier
What does Error Code C2564 Konica Minolta Bizhub 552 mean
Black drum ATDC replace the black developer unit, also check to make sure the black toner is getting into the black developer unit. Open close the front door to reset the code (Not the Toner door)
Apr 24, 2012 | Konica Minolta Bizhub C552 Copier
Konica minolta Bizhub C6500 error code 2424
Please helpme!
Jan 07, 2010 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub pro c6500 error c2452
C-2452 When the developing motor/M
(M21) is ON, the maximum
detection value of TCR sensor/
M (TCRS/M) is the specified
value and the difference
between the maximum detection
value and the minimum
detection value is over the specified
value.
Estimated abnormal parts
Developing motor/C (M22)
TCR sensor/C (TCRS/C
Jul 07, 2009 | Konica Minolta bizhub C250 All-In-One...
What does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Jun 08, 2009 | Konica Minolta Office Equipment & Supplies
jasbo
jasbo
