Question about Xerox Office Equipment & Supplies
Paper Jam in area 1b
Once jam is cleared it will print one page and then jam again
    Sergeant:
    Champion:
  • 266 Answers
The paper tray and/or paper are the problem.
Needs to be all pulled out and re connected
Posted on Mar 18, 2014
mickblu
  • 12 Answers
SOURCE: Clear Paper Jam error -- but there is no paper jam!
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
Posted on May 31, 2007
  • 186 Answers
SOURCE: print out blank pages after clearing a paper jam
Have you checked the obvious things? Such as pulling the tape off the new cartridge? Also make sure the transfer roller under the toner cart. is in securely.
Posted on Jul 08, 2007
Ajkill
  • 2035 Answers
SOURCE: Lexmark E238 prints about two thirds of a page and stops
Please follow the instruction given in this link:
clear the paper jam as given in this link:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=37:1:0:512:0:0&framed=&docid=ENUS25568&relevance=1
Posted on Jun 01, 2008
I have the same problem. Answer? PUt the piece of junk in the trash and never, never buy brother products again. I called Brother and they had a refurb for more than what it cost me originally!!!!!
Posted on Sep 09, 2008
SOURCE: How to clear internal paper jam on CLX-3160FN Samsung Multifunction Printer
I found another site that suggested these steps:
1. Check that all of the black plastic pieces turn freely when paper is fed through.
2. Take a fine grit sandpaper and gently sand the rubber spool/wheel in the bottom center of the pritner to re-texture it.
3. Clean all rollers with isopropyl alcohol.
Step 2, Sanding the rubber roller seemed to fix the problem completely.
Posted on Sep 15, 2008
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
I have a Samsung scx 4623fw printner. When I print one page, the machine will send 2nd page following first page causing page 1 jam at exit 2 and p2 jam on exit 1. It happens every time. Can someone h
On the document that you are trying to print, go to the very last word, of the last page.. hold the shift key down & use your down arrow to highlight anything below, no matter how long it may be highlighting white space. Hit your back arrow once. Check the last word for punctuation & spelling, resale your document & try to print again.
A lot of times in the course of 'composing', extra carriage returns or tabs or spaces, are added to the bottom of the document. I have just explained how to clear the second page printing. It may also remove the erroneous codes that may have formed.
Rebooting a printer has the same good effect as rebooting your computing device. It clears up a lot of confusion that has stacked up since the last time you did it.
If you have printed labels with this same printer, you may have part of a label throwing off the paper path. Also make sure that the paper guides in your paper bin or manual feed area are close, but not touching or pinching the paper. This can cause paper to go off of its normal print path.
Good luck.
Toby.
Aug 31, 2015 | Office Equipment & Supplies
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
We had a paper jam in the print engine area. Once the paper path has been cleared we are still receiving clear misfed paper in print engine. I have fed paper through the path and cannot find any paper jam.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Area" you should check and possibly replace the fuser exit actuator (part# 120N00534). Iteminc.com has this part in stock and ships same day. Here is a video the shows you how to check and replace the fuser exit actuator. Good luck, and thanks for using FixYa!
Jun 17, 2011 | Xerox WorkCentre 4150 Black and White...
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
Paper curl
When a paper jam occurs, the printer will stop printing and the Continue (1) and Paper Jam (2) lights on the operator panel will come on. See the illustration below.
pattlnk_1052005_1635-enus20238_oppaneljamlights_e230_en_us.gif When you experience a paper jam, it is recommended that you check and clear the entire paper path. To clear a paper jam, do the following:
  1. If you are feeding paper from a paper tray, first remove the tray. Look for and remove any jammed or damaged paper you find.
  2. Open the front cover and remove the print cartridge assembly.
    IMPORTANT!
    Do not leave the print cartridge assembly exposed to direct light, especially sunlight, for an extended period of time. Extended exposure to light will damage the green photoconductor roller and cause print quality problems.
  3. Remove any paper you find jammed in the area behind the print cartridge assembly.
  4. Also lift the flap at the front of the printer and remove any paper you find jammed beneath the flap.
  5. Open the rear exit door/cover of the printer and remove any jammed paper you find there.
  6. Once you have confirmed that the entire paper path is clear, reinstall the print cartridge assembly. Close all the printer covers/doors. Reinstall any paper trays you removed.
  7. Press the Continue button to resume printing. NOTE: The printer should reprint the page(s) that caused the paper jam.
  8. If the paper continues to jam, press the Continue button twice quickly while the Continue and Paper Jam lights are on. This will cause the operator panel to display the secondary error paper jam light sequence. The secondary error code will tell you where the printer thinks the problem has arisen. For more information, see the 'Secondary Error Codes' section on page 69 of the User's Guide.
Sep 04, 2008 | Lexmark E232 Laser Printer
Extra pages after paper jam
that's from a problem with the print queue manager..empty it out, power down completely, start again..
Aug 08, 2008 | HP Inkjet 1200dn Printer
47 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
