Question about Horizon T4000 Premier Folding Treadmill
Johnson treadmill error codes
E04
Johnson t7000 treadmill incline fails;gives error 6 when press incline button
If you wish to get some details about treadmill error codes and solutions then check the following link.
http://electro-medical.blogspot.com/
Sep 29, 2016 | Exercise & Fitness
What does the inverter error message mean in johnson t8000 pro treadmill?
If you wish to get some details about treadmill repair and service then check the link
Aug 22, 2016 | Exercise & Fitness
How to fix error code e04-01 after paper jam
Reset code in service mode F9/ram initialize/fuser reset/reset power
Aug 06, 2014 | Panasonic DP2000P Workio Spring located in...
Error code e4
"E04": Incline motor wrong, check if the VR of the incline motor connects well or replug it. The
mark of the DC motor and control board should be matched connected. Sometimes you also test the wires from motor, and restart again the machine and proof.
Jun 07, 2013 | Exercise & Fitness
York treadmill T780 error code 04
mark of the DC motor and control board should be matched connected. Sometimes you also check the wires of motor, and restart the machine complete.see the diagram attached
Jan 22, 2013 | Exercise & Fitness
Treadmill error E04
mark of the DC motor and control board should be matched connected. Sometimes you alsoneed to check the wires of the motor and restart the whole treadmill again
Jan 10, 2013 | Exercise & Fitness
Vision Fitness T960 treadmill error code E4 I was going to recalabrat hit start could hear machine turn off
please proceed according and fix it. See the diagram for troubleshooting and see my personal TIPS for motor help.
mark of the DC motor and control board should be matched connected. Sometimes you also test the wires from motor and restart the treadmill
Jan 08, 2013 | Exercise & Fitness
Panasonic FP-D355 Error Code E04-01
the best thing that u do first is to clean the fuser unit, esp. the thermostat located there. then you may go to service mode, (function+orig.size+3), F9, look for ram initialize, then look for LBP FUSER RESET.
it will reset all e4 machine error.
Jan 16, 2008 | Panasonic Workio DP-3530 Copier
Horizon T4000 Premier Folding Treadmill Logo
29 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
