Question about Electronics - Others
Enclosure specs i need a spec enclosure for my starsound digital 8120 quads subs. i have two of those subs. Please can i have the spec enclosure for spl.
zoomiezz
  • 50 Answers
SOURCE: spl box 12inch pioneer subs pls
this is from pioneer  http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/126763081TRD1217-A.pdf
Posted on Feb 25, 2009
etirbynnor
  • 655 Answers
SOURCE: I need to know the enclosure specs for the PSW615
Hello chetdyal,
For a ported enclosure with room for a port, you're going to need a box with about 3.0 CuFt internal volume. Using 3/4" material and outside dimensions, this translates into a box 25"(w)X18"(h)X15"(d) giving you 3.03 CuFt allowing a little volume for the sub and port displacement. For a tuned frequency of 38Hz, you'll need a rectangular port 2"X6" and 4.6" in length. A round or cylindrical port for the same tuning frequency would be 4" in diameter and 4.9" in length. Increasing the port length will lower the tuned frequency.
There's excellent volume and port calculators on The12v.com web site. I'd recommend that you browse some of the "box-building" information before you begin your build. The DIY Subwoofer site also has some great resources.
Keep in mind that a ported enclosure will tend to produce the loudest bass notes very close to the tuned frequency. So tune it higher or lower according to the music you will be playing.
Hope this helps.
Posted on Jun 11, 2009
etirbynnor
  • 655 Answers
SOURCE: i have a thunderform truck 2 10' sub enclosure for
Hello hperezrod,
Measure from the top of your thunderform to the bottom at the shortest point. You need 5 5/16" to mount the CVX's.
Posted on Nov 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: trying to build an enclosure for three of the 800
What brand?
Posted on Nov 28, 2009
SOURCE: what are the factory enclosure specs for this sub?
my speaker not working properly.
Posted on Mar 10, 2010
What is the Specs for Digital starsound 12" ssw-f1-1242?
Starsound 12" 2000w Subwoofer
- 700rms
- stamped slim steel basket
- dual 4ohm 2" ASV voice coil
- 40 oz magnet structure
- rubber gasket ring
- silver push terminal
Not that good of quality speakers. You would be lucky if they lasted a couple months pushing 700 watts rms.
Jul 06, 2014 | Orion HCCA 12D Car Speaker
Hi what amp do i use on my starsound ssw-f1-1242 slim sub
any amplifier u use will make the sub work ( if configured for subwoofer play)
my recommendation is that u use between 400watt rms to 1000watt rms ( the smaller the box used for the sub, the more power you can give it)
please note though that playing at high power levels exceeding manufacturers specs needs someone who knows what they are doing (when it sounds distorted decrees power)
also make sure to match the headunits output voltage to the amplifiers voltage (eg. if the headunit output is 4 volt, then make sure to adjust the sensitivity on the amplifier to be at 4 volt as well)
hope this helps and let me know if you have any other question
Jan 02, 2014 | Car Audio & Video
Mtx mxa 6001 amp cant get it to produce good bass using mtx 5500 subs running a 2ohm load
You seem to have everything in spec. check your crossover points and your speaker wiring. subs may be playing out of phase.
A huge factor is subwoofer enclosure ...if the enclosure is not in spec with sub requirements the subs will not peform great.
Sep 23, 2013 | Car Audio & Video
In need specs to build a box
Hello fmaisonet77,
Here's a link to Clif Designs website the specs on your sub.
They recommned a 1.75 CuFt sealed, or a 2.75 CuFt ported enclosure.
Hope this helps.
Oct 07, 2009 | Clif Designs CD1200C Car Speaker
Specs for Ported Box for 2 12" MA AUDIO HK12X2 Subs
Hello joseph_delac,
MA Audio's website has the recommended box volume and port size online here. A ported enclosure needs 3.0 CuFt of internal volume and the port should be 48 sq/in and 14.5" in length. A 4X12" rectangular port would give you the recommended 48 sq/in. Using 3/4" MDF, a box 16X18X25 has an internal volume of 3.25 CuFt allowing .25 CuFt for the sub and port displacement.
Hope this helps.
May 13, 2009 | MA Audio HK12X2 Car Subwoofer
Need specs to build box for my truck
I do design sub enclosures for a living and I give free specs on basic setups, so you are in luck. As a starting point I'll start by saying that fitting them under the seat may not work that well. Each sub will need about .75 cu.ft. sealed and probably double or triple that for a good ported box. I can get more specific If you e-mail me (dynami28@charter.net) the specs on those subs. Specifically I will need the Theile Small parameters ( these numbers-VAS, QES, QMS, FS, etc,) and then I can give you a better idea of where they will fit. If they do go under the seat they will probably not produce really low bass because smaller boxes generally produce higher bass tones. This decision should be based on what you listen too and what you expect them to sound like. They most likely will be more thump than boom and some people like that, so figure that out as well and let me know. Also my father has the same truck and there is a lot of room under the back seat. You can also gain some extra space by using fiberglass to conform the enclosure to the contour of the truck.
-Dynami
Apr 02, 2009 | Rockford Fosgate Car Audio & Video
MTX 5500 SLEDGEHAMMER 12" ENCLOSURE
According to MTX they need 1.25 cubic ft per sub sealed and 2 cubic feet vented. Most pre-fab boxes will work for those subs.
Jan 06, 2009 | MTX Dual 12" Subwoofer Enclosure (Bs212s)
Finding a good box for the sub
< I design sub enclosures for a living so you are in luck. > The one thing to remember is that generic sub boxes are just that - generic. Even if they have a fancy brand name, unless they are built for the sub you are using you will be making a guess as to how well it works. Don't get me wrong though it may work well in that band pass box, but just imagine how much better it could sound in a custom enclosure. Having said that you have the right idea, and bandpass enclosures can be power-full. If you send me (dynami28@charter.net)
the specs that came with the sub I can give you an idea of what kind of box you should get or, if you want to build your own, I can do the specs on that too. Personally I stay away from bandpass enclosures for one reason. When the subs distorts or gets pushed too hard you can't hear it happening. Since the sub is completely enclosed it's somewhat muffled or insulated so that distortion is hard to hear, which can blow up subs. A good ported enclosure would do well and basic plans should be on Lanzar's website, or available from myself. I do not recommend a sealed enclosure unless these subs will see light duty and you don't expect ground shaking bass. They can sound okay in a sealed box but most car audio enthusiasts like the ported boxes for their increased output and lower tones. Email me if you can't find the specs on those subs I might still have them on file. (Also the enclosure should be at least 3/4" thick MDF with bracing throughout.)
-Dynami
Dec 23, 2008 | Lanzar (Pair) MAXP104D Max Pro Series...
Electronics - Others Logo
55 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
