Question about Vehicle Parts & Accessories
1999 z71 chevy silverado 1500 multiple misfire
Multiple misfire detected dtc code p0300
  • 508 Answers
Bad upstream O2 sensor on driver side. Low voltage to sensor sends lean code, which in turn sends more fuel to bank 1, resulting in multiple misfires. That being said, lets me say this as well, take it to a shop and have them look. So many other things can cause this problem from vacuum leaks to looking at it cross eyed. Hope this helps
Posted on Mar 20, 2014
2 Suggested Answers
frankyanna30
SOURCE: 97 1500 z71 random/multiple misfires, runs horrible
mine was the fuel pump
Posted on Feb 20, 2013
What are codes PO300, PO332, and PO756
P0300=Random/Multiple Cylinder Misfire Detected
P0332=Knock Sensor 2 Circuit Low Input (Bank 2)
P0756=Shift Solenoid B CKT Performance Or, Stuck Off
Get that sick puppy to a good, retired GM guy. NOT a dealership, Marie. Best of luck to ya, sweetie.
Feb 14, 2015 | 2005 Chevrolet Silverado 1500 2WD
Po300pd code mean
DTC P0300 indicates random multiple misfires have been detected. Probable causes are:
1. Vacuum leaks, damaged hoses, improper routing
2. Contaminated fuel
3. Ignition system problem(s). Check the ignition module, coil, spark plugs and wires
4. Fuel system problem(s)
Apr 01, 2014 | 2008 Pontiac Torrent
White smoke
P0300'Random/Multiple Cylinder Misfire Detected
P0306'Cylinder 6 Misfire Detected
P0303'Cylinder 3 Misfire Detected
http://tinyurl.com/qbg9dbs
Mar 18, 2014 | Chevrolet 2005 Chevrolet Silverado 2500HD...
When my car is ran on computer is has cose PO300 PD. What does this indicate?
DTC P0300 - Random/Multiple Cylinder Misfire Detected
Basically this means that the the car's computer has detected that not all of the engine's cylinders are firing properly.
A P0300 diagnostic code indicates a random or multiple misfire. If the last digit is a number other than zero, it corresponds to the cylinder number that is misfiring. A P0302 code, for example, would tell you cylinder number two is misfiring. Unfortunately, a P0300 doesn't tell you specifically which cylinder(s) is/are mis-firing, nor why.
Hope this helps.
Oct 03, 2011 | 2004 Chevrolet Malibu
I have 1999 alero with a 3400 what does code P0300 mean and what does it cause the car to do
P0300....Random/Multiple Cylinder Misfire Detected
ask local mechanic to have a look for you ,could just be a cold damp engine or snow blown under the bonnet
Dec 03, 2010 | Oldsmobile Alero Cars & Trucks
2003 1500hd chevy silverado 6.0 liter. I had a
DTC Number
P0160 DTC Name O2 Sensor Circuit No Activity Detected Bank 2 Sensor DTC Number P0300 DTC Name Random/Multiple Cylinder Misfire Detected
Feb 17, 2010 | 2003 Chevrolet Silverado 1500
Where is the purge solenoid location on a 1996 Chevrolet silverado 1500 ???? trucks runs bad and I was told it was that or some other vacuum leak also I have code p0300 and p1441 if anyone can help...
A P0300 DTC is a misfire code. The P1441 is a no flow during purge code which has to do with the purge solenoid. With the misfire code present I would say you have a vacuum leak on one of the hoses. The purge solenoid is located in the passenger side, rear of the intake manifold.
May 09, 2009 | 1999 Chevrolet Silverado 1500
Codes 1133-0131-0171-0300
p1133 - o2 sensor, Insufficiant Switching, Bank 1 Sensor 1.
p0131 - o2 sensor circuit, low voltage, bank 1 sensor 1
p0171 - Lean condition, Bank 1
p0300 - Random Misfire
I would be looking at the front passenger side oxygen sensor for issues. It may be bad, it may not be plugged in, bad wiring at harness.
The random misfire may be symptomatic of the o2 sensor problem.
Mar 17, 2009 | 2002 Chevrolet Silverado 1500
I am workiing on a 1999 toyota carolla has a misfire
Here is a good site for OBD II trouble codes.  P0300: Random/Multiple Cylinder Misfires Detected, P0301: Cylinder 1 Misfire Detected, P0304: Cylinder 4 Misfire Detected.
Jan 25, 2009 | 1999 Toyota Camry
Vehicle Parts & Accessories Logo
63 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
