Question about Sony Mobile Sony Xperia ZR C5502 White 3G Quad-Core 1.5GHz 8GB Unlocked
Sony experia zr keep restarting itself
I just update the software and it won't work at all and keep restarting itself
My phone won't let me watch my videos it's a Sony experia z3
Believe this or not.
Apparently this would be to do with the latest YouTube/Facebook application update and Facebook are working on it. In the mean time uninstalling the Facebook update has been working.
Try the following steps, after trying each method verify whether that worked or not.
  • Restart the device
  • If you are using mobile data try playing the video over Wi-Fi or if you already are using Wi-Fi, try a different connection to see if it amkes a difference. Make sure you have enough mobile data if you want to use that.
  • If you are using the apps rather than the browser, clear the cache for both apps by going into Settings > Apps > All > find the app & tap on it > tap Clear cache. You can also clear the data if clearing the cache doesn't work - just note that will reset the app.
  • Check the Play Store to see if either of those apps need to be updated, if so then update them.
  • Check whether the phone requires a system update under Settings > About phone > Software update > System.
  • If everything fails, there's only one step left before confirming it's a hardware issue : Use PC Companion to repair the phone software (Support zone > Update phone software > Repair phone software)
Jan 03, 2016 | Sony Cell Phones
How do i correct the dark screen problem with Sony Experia Z (the Big Black version)
The white light sounds like it's gone bad. You'll have to replace the entire screen to fix it since the white light cannot seperate from the screen internally.
Jun 02, 2014 | Sony Ericsson Experia X8
Phone gets restart after frequent intervals
My son recently bought a Sony Experia Z which would restart frequently and finally stopped working. He tried updating the software/firmware, but nothing helped. Finally, he contacted Sony support and got it replaced through their service center. It was a hardware problem. This is a rather rare issue.
I think you should also try the same procedure with your phone, especially if its under warranty. Please note that updating the software/firmware is best left to the service center unless you are willing to take the risk yourself.
Feb 15, 2014 | Samsung Galaxy Pocket
Sony ericsson experia x8 keeps saying sim network unlock code
You can get the sim network unlock code for Sony Ericsson Xperia X8 at reasonable cost from Unlocking4U.com with easy step by step unlocking instructions.This is the fast and permanent unlocking method.
Dec 31, 2013 | Sony Ericsson Experia X8
How to update whatsapp for sony experia j it keeps saying update time and date but nothing happens?
go to Google play and search for Whatsapp...if its already downloaded to your phone there will be a green button that says "update"...press it and that should give u the solution. :}
Sep 03, 2013 | iPhone Apps
ZR-5800 won't restart
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Aug 10, 2012 | Sharp Zaurus ZR-5800
How to reprogram sony ericsson xperia x10?
Hello and Welcome to FixYa!
You need to have the Data Cable for this. If you have the cable download this update utility. Download, install and run the application. Follow the one screen instructions to update your firmware. At one stage the software may prompt you that your firmware is up-to-date, proceed anyway? At that point you have to force it to reprogram.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Feb 17, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Phone keep restarting upon sending sms and during calls
Try to update the software of the phone. I also had a problem almost the same as yours but after updating the software, the problem was solved. It even activated the screen saver feature that the phone didn't have when I bought it. You can get the updated software from the SE's website.
Jun 30, 2009 | Sony Ericsson Z750i Cellular Phone
W910i keeps restarting
The reason it restarts like mine is because u need 2 update its software. its free and u can download it online. i hope dis helped =)
Jun 20, 2009 | Sony Ericsson W910i Cellular Phone
I have a sony ericsson w950i and it keeps resetting itself
you can do a master reset of it or just get the software reloaded or with the sony ericssons update utility update your phone
http://www.sonyericsson.com/cws/support/softwaredownloads/w950i?lc=en&cc=us
Mar 30, 2009 | Sony Ericsson W950 Cellular Phone
Sony Mobile Sony Xperia ZR C5502 White 3G Quad-Core 1.5GHz 8GB Unlocked Logo
Top Sony Mobile Cameras Experts
Are you a Sony Mobile Camera Expert? Answer questions, earn points and help others
