Question about Car Audio & Video
Pioneer deh p4900ib wont turn on
My friend put the wrong fuse in the deck and i had it on last night it then shut off and i cant get it to turn back on what can i do someone can email me a solution at sageofsouls87@gmail.com
shaggyrat
  • 1224 Answers
SOURCE: install pioneer DEH-P6400 into 98 dodge dakota, just wont work :-(
you have the memmory wire which is usually the yellow connected to the wrong wire it should go to a straight power red should go to accessory power now you should have wire harness basically its colors match to match the colors easy if colors dont match colors you messed up now the other thing is there is about 3 fuses from sterio to battery sometimes 2; on the back of radio and in the fuse box sometimes someone just adds the 3rd to the power wire in back check fuses if hooked up right simple check take ground power and the yellow memmory take sterio to battery with fuses on all 3 hook direct to battery nothing else if sterio powers up you know you have right wires if it doesnt power up you blew it
Posted on Apr 20, 2008
SOURCE: pioneer DEH-P780MP
turn your head unit off, hold the function button and the functions menu to toggle the aux issue will pop up. its like an "off" function setting
Posted on Sep 13, 2008
SOURCE: Pioneer DEH-P4900IB Changing Time and Date
when the radio is off hold the on the left bottom side for about 3 or 4 seconds and a menu should come on....keep hitting that button till the time comes on. use the up down left right to change it and once ur done just turn on the radio...good lucj
Posted on Dec 29, 2008
  • 87 Answers
SOURCE: wire colours for my pioneer deh 2300
here are the wiring for the deck and the car:
Deck:
12v - red
ignition: yellow
blk - ground
orange - dimmer
white - frt left +
white /blk - frt left -
gray - frt right +
gray /blk - frt right -
green - left rear +
green /blk - left rear _
Purple - right rear +
Purple w/blk right rear -
Car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Posted on Jun 02, 2009
  • 182 Answers
SOURCE: JVC KD-LX333 car stereo turns on, but then shut off and wont...
TAKE IT OUT AND TRY IT ON A 12V BATERRY AND IF IT TURNS ON ITS GOOD AND IF IT DOESNT IS NOT GOOD. IF IT TURNS ON FOLLOW UR CONSTAN AND UR POWER WIRES AND SEE IF IT HAS A FUSE BOX IN THE BOAT/ CHECK THOSE FUSES. AND CHECK UR BOAT BATTERY TOO CAUSE IT COULD HAVE DIED WHEN TESTING THE STEREO TOO IT HAPPENS ALOT ON BOATS
Posted on Jul 04, 2009
Pioneer deh-4450bt how do I reset when no button also unit wont turn off using src button
Hi, the way you properly reset that deck is this. Get the removal tools, slide them in to release the deck. Once its out look in the back corner of the deck for a fuse. R -R the fuse you should hear it cycle, thats it.
Jul 11, 2016 | Pioneer Car Audio & Video
Pioneer deh p4900ib my dpeakers wirs are not working none of the what is wrong wit it
Use VOM meter to see if you have DC Voltage coming out of speaker leads. It should go up as you turn volume knob.
May 15, 2014 | Car Audio & Video
I have a Pioneer DEH-P4900IB and I need to know what the remote turn on wire color is thanks or can you give me the complete wire chart thanks
remote turn on for amplifier should be blue/white. remote turn on for a power antenna will be blue. using the blue wire to turn an amp on will shut it off when leaving tuner mode.
Mar 29, 2011 | Pioneer DEH-P4900IB
I installed a pioneer Deh P49001B car stereo in a 1997 dodge stratus with wiring adapter from best buy. everything works great until you switch on the lights. all power to stereo is gone.
to solve the problem with it turning off when u turn your lights on is that on the back side of your radio is a spot that says max and something else keep your ground wires conected just how they are but get u a a 14 to 12 gage wire a cut u about 6 inches and use one end and connect to your other ground wires (with Connecters ) and the other end and with a closed end connecter with the little hole in the center i cant place wat its called but any ways put it where that max hole thing is where there is a screw there and that should fix that problem cause i had that happen before .. but make sure your antentia is pluged iin to ok .. good luck Paul,
May 13, 2009 | Pioneer DEH-P5200 CD Player
Installing pioneer deck
Considering you have done many installs, make sure you check the fuse in the back of the unit. Then check all the fuses in your car. My car has 4 fuses for the radio.
Jun 30, 2008 | Pioneer DEH-P2000 CD Player
Pioneer deh p4900ib. After installing, only the sub woofer works. Why wont any of the door speakers work
Dodges internal amp requires a remote power wire. I tied the exteral MTX amp to the Dodge internal amp and all speakers work.
Jun 26, 2008 | Pioneer Car Audio & Video
Install pioneer DEH-P6400 into 98 dodge dakota, just wont work :-(
Have you measured the 12v ignition and permanent supply?
Also check the earth.
You will need a tester for this.
Check the fuses
John w
Feb 13, 2008 | Pioneer DEH-P6400 CD Player
Pioneer DEH-P6900UB problem.
It's called Reverse. Just set it to No.
Oct 14, 2007 | Pioneer DEH-P6900UB CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
