Question about Dream Maker Spas Pool & Spa
Model 8003- x - 400 when plugged in motor hums for about 10 seconds then breaker trips(no pump but display lights up
Spa has been in storage for 14 months
    Scholar:
    New Friend:
  • 66 Answers
Sounds like the motor is seized. Of it cant turn over it will trip the breaker. Sometimes you can get to the shaft of the motor on the back end by removing a cover or cap. With a large flat screw driver or open end wrench you can sometimes spin it manually to break it free. If it is really stuck the pump may have to be dis-assembled or replaced.
Posted on Apr 13, 2014
vincob
  • 718 Answers
SOURCE: spa keeps tripping breaker. Not GFI. Ran for 2
Sounds like wiring problem, rule out GFI sometimes they just go bad or have your wiring checked in that run something is not hooked up correctly or loose. Make sure this circuit it is not shared with anything else. If not ran for 2 years could be wiring problem in spa get it checked out be safe, water and electric bad news if your not familiar with or comfortable with electrical issues. Good luck!
Posted on Oct 15, 2009
SOURCE: I have a spa pac 1100 kw heater it trips the
jkuigjiu9u9uirj9u9jrri89jij9f ijoijog j9j9r hi8h9jrij9jfij9j9dij9jasifj9jifj8ef i8hfh9ufihihfhihd73uurwejhydjjhuynjujjuyvnnydhnhrhhydfhyfhhyrhyyjhhfuhuughurtuguhuerghuhrrguhurhgurgbrguhrrguhrhguherghuhghughfjvnuhuf udfu h8h uhufhuwenuh uh hh unu huwenfui h8ef hwuehfu bufg ubdfuh unuwebf jwbfubu weyfgu huyff uhehfuywehfuyweghufhweufhuwefhuefuefuwefguwefgudfbdbvusfgfudgfugfugsdfsdgfusdusdfusdfsudfg7egrwegfwgefyugydgybefygeyfgywfgygdycgybefygybsyfvwyfbgydvfytyfgefywefy y ge7yfg gyeyf wy yegjhbuvhuvye7fg7egf7g7dg77gd76gwte6t6qge6qt6q6e
Posted on Jan 08, 2010
john224
  • 1378 Answers
SOURCE: breaker on the end of
I have had a few troublesome units over the year that did as you describe due to 'dew' overnight collecting around the tub and the increased moiture sent the motor of the circ pump "over the edge" iinto a grounded state. A leaking pump seal was adding to the problem. Once the seal leak along with the dew got high enough the GFI would sense the grounded condition and trip. Fixing the pump seal and drying/cleaning the motor fixed the problem every time. If you find any other leak sources around the pump you will need to fix them as well.
Posted on Oct 12, 2010
  • 760 Answers
SOURCE: Dream Maker spa GFCI plug was all corroded. I cut
Did you make sure you observed the correct polaity on the cord? The white wire should go to the silver screw on the cord cap. The black wire should go to the gold terminal (brass) and the Green wire should go to the Green screw. If the plug was corroded, is it possible that the GFCI is also corroded? They aren't that expensive and you could replace the GFCI yourself if you're sure you can locate the circuit breaker and turn it off.
Posted on Nov 22, 2010
john224
  • 1378 Answers
SOURCE: I have a 300GAL Spa
What is the amp rating for the tub? What voltage are you actually running the tub on, 120 or 240? Is the 120v 10amp two-pole then the switch rating since you mention a switch? If there is no amp rating on the control what is the wattage of the heater element and how much horsepower is the pump rated for?
In the end it seems likely you do not have high enough breaker ratings to carry the pump(s) and the heater at the same time. Depending on the electrical circuit wire size and the breakers and switches you may need to make some adjustments or replace some of the components but I'll/we'll need more details on your existing setup and the tubs electrical demand to help you further.
John
Posted on Mar 29, 2011
Why does my hydromate motor trip the breaker?
Drag on the Motor is increasing the HEAT, the HEAT is what is causing the trip. Your motor sounds like it is getting weak.
Jul 03, 2014 | Pool & Spa
Tripping circuit breaker
Hi Kathy
Sometimes when a breaker keeps tripping, it will wear and will be in need of replacement...try replacing the breaker and see if that solves your problem.
If not then check the amps on the pump and make sure the breaker is able to hand the amperage the pump is requiring.
Bud
Oct 09, 2013 | Pool & Spa
Pool pump motor noise/hum would come and go, noise was not constant nor continuous, every few seconds would go from high to low sound but volume would seemed constant. was not an extraordinary noise and...
The problem is the starter capacitor on the back or top of motor depending on make. The capacitor is round and black and about 3 inches long and the diameter of a half dollar. it will have 4 wires with quick disconnects on them, unplug and replace capacitor and put wires back on the same way they came off old one. as far as the noise, the bearings are starting to wear and can be replaced when you get tired of the noise. you will have to take it in to have the bearings replaced.
Aug 31, 2011 | Emerson Pool & Spa
I have a Jandy stealth series pump and this morning it was not running. The breaker was tripped and when I reset it and turned it on the motor only hums for a few seconds and then the breaker trips...
This sounds like the motor has seized up. You will most likely need to replace at least the motor and maybe the complete pump assembly.
You can take the pump into a local motor shop and see if they can rebuild the motor for you.
US Parts Center
Aug 21, 2011 | Jandy Stealth 2 HP UR Pool Pump SHPM2.0...
My spa hums for a few seconds then kicks off. No flow. lights and control display are working.
Is the shut off occuring @ the GFI? & is there an error code displayed on your topside?
If the breaker is kicking off, the best way to troubleshoot is to disconnect all components, (pumps, heater, circ, etc.) & then plug one in & turn the breaker on. repeat the process until you locate which component is tripping the breaker.. then you know whats causing the trouble
Feb 24, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Motor runs at low speed and trips breaker within 10 seconds
The motor is bad. It overheats inside and the contacts aren't releasing and this trips the breaker to prevent more damage, You can reset it because it had time to cool down and the contacts have released.
Jul 03, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Spa keeps tripping breaker shows pr
two main reasons breaker trips is the pump motor jammed [not turning]or the heater shorted out --disconnect power open access panel disconnect the lines to the heater turn on power if breaker trips than motor /pump problem if doesnt trip than heater problem can order heater replacement online or pool spa store--if motor pump check pump for debris and motor for lube if u can turn shaft or impeller oil motor and work it into bearings if still not turning possible need to replace motor unit
Apr 26, 2010 | Heritage Pool & Spa
Plug in motor and it hums for 10 seconds then the breaker trips. Why won't it rotate?
The shaft is frozen; you've got damaged goods. Your only option is to replace the motor.
Jul 19, 2009 | ADVANTAGE 1.0 Hp 1 Speed Waterway Spa Pump...
USQ1102 pump gets power, buzzes, trips breaker
The motor-start capacitor is bad. This is a very common problem. It can be easily and cheaply fixed by replacing the capacitor. Replacements are usually less than $10.
See http://www.youtube.com/watch?v=ZEIv5ClLqXg for a step=by=step guide.
When you have the capacitor in hand, check the model# which is printed on it. Alternatively, you can Google the motor brand & model to find the parts list which will identify the right one. Then Google the part number, to find a seller.
Jun 27, 2009 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Pool & Spa Logo
145 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
