Question about Dishwashers
New world nw dw45 integrated dishwasher door has lost tension and won't close How can I fix this
Renlig dw45 the washing machine keeps trying to drain even though it is empty please help
Yup. I have an IKEA Renlig DW45 and this cured the problem (the dishwasher would not stop draining).
Thank you so much for taking the time to detail it here for us.
Jan 20, 2014 | Dishwashers
Fisher/p nemo dishwasher door
it is sometimes linked to the dishwasher not level or the spring tension on one side getting weak. Refer installation manual http://kitchen.manualsonline.com/mdownloads/c11d2c17-cb0a-489c-99bf-a61513fbf876.pdf to make sure the level is adjusted. May need to replace the door seal in case leak is too excessive.
Apr 27, 2013 | Fisher and Paykel Dishwashers
My KitchenAid Dishwasher door won't stay closed. It keeps popping open after a few seconds.
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
Aug 11, 2012 | KitchenAid Dishwashers
Door won't close
1) adjust the latch
2)see the spring if are broken or without tension replace or repair
3)hinges bent, replace
4)door seal, try to adjust or replace
Jun 19, 2012 | Whirlpool 18 in. ADP530 Free-standing...
Dishwasher door won't close
Turn the dishwasher circuit breaker off inside your home electrical panel. Open and close the door and watch where the strike plate makes contact with the door. The strike plate is usually on the front top center of the dishwasher. If the strike plate is out of alignment, it will hit the inside of the door
May 19, 2012 | Bosch Dishwashers
Deactivate childlock on fully integrated neff dishwasher
If door won't close and you don't have a child-lock, just push the door closed a lot harder than you normally would - NEFF manual says to do that, and it worked for me! I think it just forces it to engage and 'releases' the catch, as after that it closed with just normal pressure applied.
Apr 09, 2012 | Neff 24 in. S5456 Built-in Dishwasher
My door will not shut and there is no tension on
make sure the strike is adjusted correctly.. it may have gotten bent out of place.. the strike is the little metal tab that comes off of the top of the center of the tub and goes into the door when you close the door.
Aug 29, 2009 | Fagor LFA-65 IT Dishwasher
The door on my dishwasher will not close
There are a few problems that can occur with the diswasher door assembly. These usually involve the latching mechanism, the door seal, the counterbalance spring assembly or the hinges. 1) The door latch plate can occasionally become out of alignment. Some door latch plates are adjustable, some aren't. If yours is adjustable, try loosening the retaining screws and repositioning the plate. It's trial-and-error, so have a lot of patience. If this doesn't work, then the latch needs replacing.
2) A new dishwasher or a newly installed door seal can be difficult to close for a while until the seal softens and compresses over time. You can try adjusting the latch, if possible.
3) If the door feels unusually heavy, there could be a problem with the counterbalance spring assembly. These counterbalance assemblies allow the door to open and close easier and are held by two springs. On some dishwasher models, holes are positioned in line so you can re-tension the springs by moving the spring hooks to other tensioning holes. If any of these springs break, they will need to be replaced as a pair.
4) The door hinges might be bent. They can seldom be adequately fixed and should be replaced.
hope this helps
Nov 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Mar 16, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Integrated dishwasher door fitting
open the front door. On each side of the inside of the door are various long screws, unscrew these and the old door will fall off. discard the old door and follow the same steps in reverse to put the new door on. It took me 10 mins to do. Hope this helps
Apr 12, 2007 | AEG 23 in. Favorit 50750Vi Built-in...
Dishwashers Logo
22 people viewed this question
Top Dishwashers Experts
