Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
No standby light on sanyo avl3210
No standby light coming on circuit good
Sanyo tv model dp42848.want power on,no power light.after having it plugged in for30 min. light comes on,a clicking starts.screen comes on follows the clicking flashing on and off.Have to unplug it
Either the circuit board has over heated and fried itself, or your digitizer is malfunctioning. Either way it is time for a new TV sadly, TV repair is very expensive, and Sanyo is a cheap brand, you can buy a new TV for the cost of fixing it, or if its still under warranty get a new one. Good Luck!
Dec 04, 2016 | Sanyo Televison & Video
HDTV no PIC just standby light blue purple sanyo
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 19, 2015 | Sanyo Televison & Video
Sanyo TV turns on and works but standby light not working
Do you mean that the standby LED does not light up; but the set works fine? Of so, either the standby LED is damaged, or it do not get voltage [due to loose soldering or some other reason]. Anyway, the set works fine. Isn't it. It means that there is no other fault than this. Contact any service technician in this case; to find out the reason. Electro help
Dec 05, 2014 | Sanyo Televison & Video
Led blinking red on a sanyo dp50842
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 05, 2013 | Sanyo Dp50741
Sanyo tv standby mode
Too little details here - need model, chassis, more specific behavior details.
This may help:
http://blog.coppelltvrepair.com/2012/07/sanyo-dp47460-dp42840-dp46819-and.html
May 06, 2013 | Sanyo 42 in. LCD TV
I have a 46" Sanyo
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Jul 08, 2011 | Sanyo DP46849 46 in. HDTV
My sanyo tv stand by light keeps flashing and it wont turn on can you tell me whats up with it
i have 32inch sanyo tv i have blue light on front whitch comes on when on stand by it wount come of standby eney idears on how mutch it will cost to get fixed x
Nov 13, 2010 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
We are having one sanyo plc xu 78 projector.when it began to switch it on the count down screen will displays when the count down timing is coming to 0 then its directly going to stand by mode. its not...
The countdown shows while the unit is going through its internal circuit testing. Usually if a problem is found, there will be indications with the standby lights and lamp/temp lights. Are there any other indications here or just the unit going into standby?
Dan
Jul 08, 2010 | Sanyo PLC XU35 Multimedia Projector
Sanyo ces32wsd7-b set comes on with blue standby light and when you poer the tv up the standby light goes off but nothing esle happens
Favourite is the 1000uf/16Volt electrolytic capacitor (C806) in the middle of the PSU board. If the top of the can appears bulged then it has probably died. This can cause some thermal faults where it will operate when warm but not when cold, and accounts for some 'reluctant to start' faults. It is close to the heatsink, so use a high temperature rated replacement.
Jun 05, 2010 | Sanyo Televison & Video
TV problem
This is an indication that you have an overcurrent issue and the shutdown circuit is turning your TV off to protect it. Now this problem can only be worked on by someone that knows TV repair. I would suggest that you take this TV to a qualified electronics service technician.
Sep 10, 2007 | Sanyo DS24424 24" TV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
