Question about Michele Mini Urban Watch
Watch stem crown repair
Recently replaced watch stem/new crown and new battery. the problem is the watch will run fine for a day or so and then stop. i do notice with the new crown/stem that if i turn the crown, the hands have slight movement. if i push the crown and turn at the same time, the long hand moves just like when the crown/stem is pulled out to change the time. could the length of the new watch stem be a problem?
3 Suggested Answers
SOURCE: I just bought my wife a michele csx-36 watch. Its brand
that happened to me too...the watch repair man told me that I had the stop watch on. The stop watch should serve as a stop watch, not the second hand. The second time on your watch is the small dial at the bottom middle of the face. Once I turned off the stop watch feature, my battery life is fine...I have not had to change my battery in over 2 years now. HOpe this helps.
Posted on Feb 28, 2010
ZJLimited
  • 17970 Answers
SOURCE: Had the battery replaced in
Loose cannon pinion or cannon driving wheel; the seconds hand represents the wheels in the back of the watch going around ok, but the power need to transfer through to the front of the watch somehow.
This is done by snapping/clicking two wheels together on either side of the main plate. The one on the dial side (cannon pinion) needs to slip to be able to set the time as the minute hand is set on this pinion. Im sorry, its time to see a repair guy.
Hope helps.
Posted on May 04, 2011
Does anyone know how to take crown and stem out of my Michael kors watch model#8108
Take your watch to a jeweler for replacement of the crown and stem.
Mar 04, 2017 | Crown Watches
How to remove the plastic between the stem and the case-how do you remove this plastic
simply pull the plastic tab out
then push the crown back in
the battery is energized when the stem ( crown) is pushed all the way in
it is used to stop the crown from making contact during storage before sale so ensuring that a new battery is installed on purchase
Dec 19, 2016 | The Watches
How to set day/date on an 1968 DX automatic Seiko watch
Seiko watches from this period should have a setting stem that pull out half-way and fully. Pulling the stem out fully permits you to set the time. Pulling the stem out half-way should let you set the date by moving the crown forward/clockwise and set the day of the week by moving the crown backward/counterclockwise.
However, for this to work correctly, the watch must have the correct set stem. I have worked with a number of watches, including Seikos, where a generic stem was substituted after someone accidentally pulled out the crown and stem (Seiko replacement parts can be tough to find in the U.S., especially for discontinued models). If an incorrect stem has been installed, the day/date setting procedure I've just described may no longer work correctly. At that point, setting the date involves advancing the hands to get to the right date; day of the week may not be able to be set at all.
Mar 09, 2012 | Watches
I recently bought a nixon newton watch and my crown fell off the other day. So now i can't adjust my time i was wonder can i replace the crown or do i need to get a whole new stem and crown?
if you still can see the stem near the hole of the watch, you only have to replace its crown. but if not you have to replace both. i hope i had been helped you.
Sep 01, 2011 | Nixon Newton Red Wrist Watch
Hello I have two nixon men's wrist watches that
just bring your watch to Nixon watch experts. they have spare and tools to repair your watch.
Jul 14, 2011 | Watches
I want to remove my quartz movement to dry moisture from inside my watch. How can I remove crown, so that I can remove movement? Watch is old Gruen. Not worth shop repair.
Thanks for contacting FixYa.
It is WAY too risky to remove crown/fixture. Try this instead;
  • Step 2 Lay the watch in a dry place in sunlight and see if the water evaporates on its own. Put a piece of soft, absorbent cloth such as a towel under the watch. If the water inside the watch face is only a fine film of condensation that clears on its own after a short time, you probably do not need to do anything else.
  • Step 3 Seal the watch in a plastic bag filled with unopened packets of silica gel desiccant. These are the packets that come in shoe boxes and other packaged items. You can also use dry rice instead of the silica gel packets. Leave the bag somewhere warm and dry for a few days. The silica gel packets or rice can help draw out the water from inside the watch.
  • Step 4 Direct a fan at the watch or use a hair dryer on the lowest heat setting to blow air on the watch. Alternatively, if you can safely leave the watch on top of a low heat source such as a floor vent or radiator, this can help evaporate the water from inside the watch.
  • Step 5 Obtain the appropriate watch repair supplies. If you need to purchase tools, look for these at a watch repair shop or at a jewelry store. You can also find watch repair tools online. You may need small, fine-tipped screwdrivers and watch openers and closers.
  • Step 6 Take off the back of the watch, as if you were changing the battery. Use care not to scratch or damage any of the mechanisms such as the coil or stem. Let the watch dry thoroughly in the open air until there is no trace of moisture. Reassemble the watch once it is dry and press the seal firmly back into place. If the seal does not fit tightly, you may need to replace it
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Best regards. Jewel
    Sep 21, 2010 | Watches
    I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
    DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
    Dec 06, 2009 | Seiko Alarm Chronograph Titanium CASE AND...
    Winder is lost
    You need a replacement stem and crown. I would replace the stem just to be sure you arent putting a new crown on a damaged stem.
    Sakgen is very good about repairing their watches. Unfortunately this doesnt fall under their warranty but the repair directly through them is an average price for this part.
    Generic after market crowns are also available at local watch repair shops. Make sure that if you go this route that you select a shop that can reseal the watch to is water resistance rating so you do not void your lifetime limited warranty on the movement. This mean they must have a pressure testing chamber and be able to supply printed proof of resealing.
    Sep 23, 2009 | Skagen 355LGSC Wrist Watch
    Dkny ladies watch winder lost and watch stopped
    DKNY is typically a quartz movement and doesn't have a "winder". I believe the part you are referring to is the crown. The watch may have stopped working for several reasons. The first three things I would suspect is that the battery died, the watch is in the set position, or the movement was damaged when the crown was coming off. If the watch is in the set position then pushing the stem in will cause the watch to run. The next thing to do is to replace the battery since it is only a few bucks. If it runs then you can replace the crown and your set. If it doesn't run I would suggest replacing the movement along with the crown and that you will have to price and see if it is within reason since this type of repair wont be covered under warranty.
    Depending on the model of DKNY you may have to go through DKNY for the part. Remember that they are manufactured by Fossil. You could save yourself a lot of time by going to your local watch repair shop.
    Thanks!
    Sep 19, 2009 | DKNY Watches
    Ebel Classic Wave fitting a new crown
    i have changed the battery on my and my wifes ebel classic wave watch,,
    step 1 ...remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
    step 2 ...remove all 5 gold bezel screws
    step 3... be careful,, the bezel/crystal will pry off easy
    step 4... be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
    step 5.. small screwdriver and remove/replace battery
    step 6... reinstall watch guts/bezel and gold screws
    step 7... push crown back into watch
    step 8... take wife and kids to dinner ,,you just saved three hunderd bucks
    if have done it many times ,, you can do it !!!!
    Dec 10, 2006 | Ebel Classic Wave 9090F249725 Wrist Watch
    Michele Mini Urban Watch Logo
    32 people viewed this question
    Top Michele Watches Experts
    jasiel murphy
    Jimmy Accardi
    Are you a Michele Watch Expert? Answer questions, earn points and help others
