Question about Sony KDF-E55A20 55 in. LCD Television
No standby red light on sanyo avl3210
No standby wont turn on
2 Suggested Answers
  • 4234 Answers
SOURCE: red standby light light blinking
The 5 blinks can indicate a picture tube starting to fail. Carefully open up the back and look for the flyback transformer. It will be the part with the large red wire coming out the top that goes to the side of the picture tube. There should be 2 controls on the flyback, screen and focus. Turn the screen control slightly clockwise. If the set stays on, the picture tube is starting to fail and you have bought yourself time to find a replacement. If that fails, then you will need to investigate other possibilities that will involve soldering. Let me know if you need to do that.
The 6 blinks indicate no horiszontal. This can be as simple as a couple of bad capacitors or the "jungle" IC. If you can solder, please post another question with the model and a brief description indicating that you can work in the set and we'll continue to track this down.
Thanks,
Dan
Posted on Dec 23, 2008
Avl3210 tv wont turn on
Open internal fuse or power supply failure
Feb 24, 2017 | Televison & Video
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Sanyo TV turns on and works but standby light not working
Do you mean that the standby LED does not light up; but the set works fine? Of so, either the standby LED is damaged, or it do not get voltage [due to loose soldering or some other reason]. Anyway, the set works fine. Isn't it. It means that there is no other fault than this. Contact any service technician in this case; to find out the reason. Electro help
Dec 05, 2014 | Sanyo Televison & Video
I have a sanyo 31.5 tv dvd combo when pluged in the red light appears but does not turn on no green light
No green light means set is in standby because it cannot make it on.
Either a short or a open exists.
On Combo units it can also mean the mechanism for the DVD is jammed etc.
Apr 03, 2012 | Sanyo Televison & Video
My sanyo tv stand by light keeps flashing and it wont turn on can you tell me whats up with it
i have 32inch sanyo tv i have blue light on front whitch comes on when on stand by it wount come of standby eney idears on how mutch it will cost to get fixed x
Nov 13, 2010 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Sanyo Plasma DTV turns it self on
No solution sorry but i have a problem too... I usually watch my tv on "dtv" now it just went black no channel is working it automatically went to "ATV" where the channels are fuzzy and my extra channels aren't working. I tried scanning on "DTV" for all the channels but automatically scanned and defaulted back to "ATV". Does anyone know how to fix this?
Mar 26, 2010 | Sanyo Televison & Video
Sanyo ce32ld47-b code for sky+ remote
  1. Turn your TV on.
  2. Press tv on your Sky remote control.
  3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
  4. Press tv on your Sky remote control again.
  5. Key in the code 0157. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code you entered and start again at Step 1.
  6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Oct 12, 2009 | Sanyo Televison & Video
No pic or sound
First unplug set and let set for several minutes the plug in and turn on. Could be in a serv mode.
Jul 13, 2009 | Hitachi 51F59 51" HDTV Projection...
Red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
Jan 11, 2009 | Sony KDF-E55A20 55 in. LCD Television
Ilo 32 lcd
I have the same issue. Here's a temporary solution, which is what I've been doing for the last couple of weeks, unplug the unit from the wall, just long enough for the red standby light to go out, then plug the unit back up. as soon that the red standby light comes on, press the on button the the remote or the unit. You may have to do this couple of time before it works. Somedays it works on the first try for me and then somedays I have to do it 3 to 4 time. I sure that at some point this will stop working too.
Sep 08, 2008 | iLO 3200 32 in. LCD Television
Sony KDF-E55A20 55 in. LCD Television Logo
21 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
