Question about KitchenAid Refrigerators
Just moved into a house with a Kitchen Aid KBFA refrigerator. Fridge was working before power was shut off after last tenant, now with power back on, lights come on, motor runs (not sure if it is fan
This is a Kitchen Aid KBRF 20ERSS01 model, about 7 or 8 years old.
5 Suggested Answers
landsend
  • 1066 Answers
SOURCE: freezer cold, fridge warm
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
SOURCE: ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Posted on Jun 27, 2009
  • 286 Answers
SOURCE: Refrigerator compressor motor will not run.
Does the fan work? If yes then the compressor has a relay and overload that might be bad. Or it could be a compressor that is bad. If its a compressor then you will need to have a tech verify that it is the problem. If nothing is running then it could be a thermostat thats not switching it on. Let me know if you need any more help with it.
Posted on Aug 12, 2009
  • 1531 Answers
SOURCE: kitchen aid refrigerator model KSSC48QMS01
replace the condensor fan motor.
Posted on Feb 25, 2010
My kitchen aid refrigerator won't stop buzzing
If everything is cooling right, take the front grille off at the bottom of the fridge and move the plastic drip tray. It might be touching the motor or pipe, causing the noise.
Jan 28, 2015 | KitchenAid Kitchen Aid - KSC23C8EYY...
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Dec 31, 2013 | KitchenAid KSCS25FKSS Side by Side...
My fridge has stoped cooling frezzer stoped last week dumped the ice out move frome wall started working agin for a week than stoped working yesterday WTF is was made in 06 is the compressure out or what...
you moved the fridge out from the wall and it started running again?try opening the fridge door and tap on the fridge control and see if it starts up.i,ve gone into houses and then the woman tells me when the fridge shuts down she hits the side and it runs again.it's the control,this could be your problem also,when you moved the fridge the control could have kicked back on.let me know what you find
Jan 13, 2011 | Frigidaire FRS-26DR7D Side by Side...
Our tenant says she heard the fridge beeping late last night. This morning, the fridge is completely shut down. The electrical outlet that it's plugged into has power, but the fridge isn't working. Is...
Do the lights light up in the fridge or freezer? If so then your power will be fine. If you look into the fridge do you have a board that sit up the top front with the temperature for the fridge a freezer on it? It will either be that board (most common) or the start relay which connects onto the compressor in the rear of the appliance, they can sometimes burn out and stop the compreeeor starting and the appliance will lose the temperature and the noise you hear is the alarm warning you that your food is at risk.
Nov 04, 2010 | Maytag MSD2756GES Side by Side...
Kitchen aid refigerator: door won't seal then lost power.
The GFI had becme stuck - yes we had plugged the fridge into the GFI which is apparently a bad thing to do. Replaced the GFI (and moved in away from the fridge) and all is well.
Jun 02, 2009 | KitchenAid KTRC19MKSS Top Freezer...
Compressor runs continuously, and center bar (heat dissipator) is extremely hot to touch.
Molly, The hot bar is a normal part of the sealed system (compressor) operation. The relay they told you about is on the back of the compressor and I would not recommend you changing that. The refrigerator is a balanced system, the freezer air removes the heat from the refrigerator side. If the compressor runs all the time, look for food close to the edge and not letting the doors close completely. Move items back. Don't over pack the freezer, the air must circulate. The refrigerator of today runs longer and uses less power that the old refrigerator. If you are still having issues with this model call a authorized Kitchen repair person in you area and ask how much they charge to come to your house and give an estimate.
May 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Tenant says fridge is not cold enough and that food has gone off
I would check to see if the heater is working? It would behind the plastic back wall of the freezer. if its all frozen up and ice all over, get a hair dryer and melt ice and get a new heating element. cost is about 50 dollars
Dec 06, 2008 | Belling BE808 Compact Refrigerator
Fridge not cooling
Make sure coils underneath or backside are clean of dirt. Make sure compressor is humming when running. You can tell by moving fridge out and it will be at the back side of the opening on the bottom side of fridge. It will be about the size of a soccer ball. If it has a little of vibration and might be alittle warm to touch. Also open door and make light comes on inside. In newer homes these days they are using ground fault interceptors. Even tho this one is not plugged into one that has the resetable breaker check other walls for one that does have the little red and black push buttons. They sometimes wire some into one ground fault, when that pops, it shuts power to the others. Our house is that way, I have to go to our bathroom and reset it to make the ones in the kitchen work.
Nov 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
14 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
