Question about GE Refrigerators
GE GSL22JFTABA Side by Side water dispenser problem
Water dispenser not working at door.
    Novelist:
    Scholar:
  • 166 Answers
Check that the solenoid valve is working. If not, check that it's getting voltage when activated. If no voltage, control or switch is bad. If voltage OK, valve is bad. If none of the above, the water line is frozen.
Posted on May 26, 2014
Profile series pfs22slsbss water dispenser not working.
Fixing GE Side by Side Refrigerator Water Dispenser ...
? 4:00
https://www.youtube.com/watch?v=7G81-kJrqWI
May 24, 2012 - Uploaded by The Handyguys
But he then explains how he fixed his particular water dispenserissue by ... Refrigerator Repair - Not Dispensing Water through door- GE, ...
Nov 06, 2015 | GE Refrigerators
How do you fix the water dispenser on a GE side by side refrigerator model GSS201EPD WW
Here are a couple of possible problems. Most common one is a defective water inlet valve. It is the plastic assembly at the lower back area where the house water connects to. On dispenser systems it is actually 2 valves in one unit---half lets water in to icemaker---the other half lets water dispense at door. It is electrically operated so if half goes bad , the other half can still work. If bad it needs replaced as a complete unit.
Second possible problem with some GE side by side models is they had problems with the water line in the door going to the dispenser sometime would freeze up. They came out with a heater kit that needs installed in the dispenser area to defrost the water line. Call GE service with your model number and they may be able to tell you if you need that kit installed.
Jun 28, 2015 | GE Refrigerators
Water dispenser stopped working. Water valve works
A major problem with the ge side by side refrigerators with metal liners is water freeze-up inside the door of the freezer. Short term repair is to heat the dispenser area CAREFULLY with a hair dryer right at the point where the water spout comes out.
The long term fix involves installing a heater in the dispenser part number wr49x10173 @$60. The kit comes with installation instructions..
Let me know if you have any questions!!
Aug 14, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
No water from water dispenser
I have a GE GSH22JFTA side by side and my water dispenser just stopped working after about a year. The selenoid for the pump is buzzing, and when I disconenct the water line at the bottom on the freezer door, it water dispenses fine. the water is freezing IN the freezer door. I got some plastic sheathing and duct tape and opened my freezer door and sealed the freezer compartment so the food would not defrost and left door open to thaw out. in about 2 hours, voila.. my dispenser was working again. I suspect I'm not the only one with this issue.
Mar 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker and now water dispenser does not work
Do you get water to the connector at the bottom of the freezer door ? if you do then the water pipe in the door is probably frozen - read new door ! if not then check thw electrical connector at the bottom of the freezer door as they have a habit of corroding.
Feb 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Mar 10, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
