Question about Kenmore Refrigerators
Loud vibration from compressor
(Reposting, as this problem was mistaking ascribed to a Maytag unit.) Ever since I moved in, the compressor has made a loud clunk when turning off. Returning home after a 3 week trip, I found that the compressor now makes a loud vibrating sound when running. It also seems to be running more often, although the freezer and refrigerator compartments are still cold. The repair guy just listened and said the compressor is going out, no way to know when it will quit. I am willing to buy a replacement, but wondered if it's possible that there is a simple mechanical problem, say a loose bolt or some such. I am fairly handy, although I don't know anything about refrigerators specifically, so if there is something I can check, I will. Thanks for any advice!
  • Kenmore Master
  • 1,874 Answers
Has the refrigerator been shifted, then just you have to leveling the feet, that will cure oft on one or both feet on the front this has little priority but can have influence otherwise this can made in this more difference
How to Adjust Refrigerator Doors so they Close Properly
Posted on Mar 22, 2017
    Top Expert:
  • Kenmore Master
  • 12,962 Answers
Compressor motor inside the hermetic container has rubber mountings. If any go, the motor will lean in that direction and the motor will hit the shell when it starts, or turns off.
Compressor motor is not going and the guy is full of it.
U cannot open the case and repair the mounting but the motor and its bearings are good to go for a long time, albeit it might have some noise. U can experiment with tilting the compressor assembly in the direction opposite to the bad mounting - often you can reduce and/or completely eliminate the startup/shutdown noise and running noises..
2 Suggested Answers
SOURCE: Loud vibration from compressor, but still cooling
i would check for loose bolts some where if the ref is get cold and the freeze
Posted on Mar 18, 2014
When it is lcooling it has now begun tomake loud vibrations.
it is most likely from the frame of the fridge that the compressor is mounted on vibrating on the floor
I use two door wedges ( available from the hardware shop and I push one under either side a bit to get clearance from the floor
the noise stopped but the problem is that there is nothing available on the market to replace the wedges
rubber buttons under the plate worked but to stop the noise they tend to make the fridge unstable when opening the door or the front of the fridge has to be adjusted up so that the door self closes
try that and if it works the you are on the right rack
if not you may have to get the compressor rubber mounts replaced as they may have collapsed and allow the compressor to hit on the plate
Oct 14, 2015 | Maytag MSD2454G Side by Side Refrigerator
One of the most common mistakes made while moving a refrigerator
is shaking the compressor, thereby ruining it.
The motor inside the compressor is usually sitting on springs
to allow it flexibility when it runs and to cut down on the vibration.
Especially in older units. The motor inside is wrapped in coils of insulated copper wires. When the compressor is moved it causes the motor to
bang against the inside of compressor, Causing the insulation to break
off and short out.
Just move the Ref or Freezer very slowly and carefully.
Over grass bumps is the worst. It takes a lot longer to move it but it is worth it.
Leo Ponder
on Jul 27, 2011 | Refrigerators
Mar 18, 2014 | Maytag 15 Cu. Ft. Top Mount Refrigerator
Loud vibrating washer
What is the model number of the unit?
Mar 03, 2014 | Kenmore HE2 Plus Front Load Washer
Runs loud when the compressor kicks in? Why?
Check vibration eliminators on the feet of the compressors, over time of running in tough conditions they wear out and cause rattling. If this does not fix the problem see below
-check amp draw, if amp draw is high windings are wearing out and compressor is running harder, may need replaced
- check to make sure your refrigerant charge is correct you could be slugging the compressor
-find other ways to isolate compressor operations
May 29, 2017 | Maytag M6P09S2ACOM Air Conditioner
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
GE top freezer refrigerator: motor has become very loud and refrigerator vibrates. However, when I move the cold control to a lower number, it gets slightly quieter and vibrates slightly less.
Please make sure it is level, the compressor is designed to run on level ground. Also check the fans. if the fan is bad or the bearings are shot, it'll vibrate and make a loud humming noise.
Find out where the noise is loudest. if it's under the fridge, it's the compressor.You have to check the coil for the compressor and if it's inside the freezer, it's the fan bearing.
Please leave me comment, if you need further assistance
Oct 20, 2009 | Refrigerators
Maytag performa PAV2300 Vibrates
HI!!! I used to work for maytag and this model vibrates and moves around ..we used to install skid pads so that it would not vibrate and move..also make sure that the unit is not off balance.. You should have 4 knobs underneath the unit so that you can adjust it..Good Luck..
Jan 04, 2009 | Maytag PAV2300 Top Load Washer
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Loud as Hell
Is it installed in a window? Check to make sure it is installed correctly. usually there is a felt or foam strip that is used to dampen vibration when you place it in the window. It also acts as seal to keep outside air and bugs out. If you place your hand at various locations on the unit does the sound go away? If it does then you know it is a vibration problem. Just add new foam or re-adjust the foam or gasketing it already has. If that doesn't work then try to locate the source of the noise. Use a mechanics stethoscope or even a cardboard tube from paper towels will work. Once you have located the source then you can tell the store what the problem is when you take it back and get a new one. Cheap air conditioners are noisy. Some more than others, it's why they are cheap. But your problem does sound like it could be a product issue.
Sep 25, 2007 | Haier Mechanical Air Conditioner HWF05XC7
Refrigerators Logo
35 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
