Question about Dell Dimension 4600 PC Desktop
Just reinstalled windows xp and i cant start up until i enter f 1 or f 2
What can i do to stop this? ty
    Master:
  • 397 Answers
Does the system request you press one of these buttons? Does it give a message?
Posted on Mar 19, 2014
Cant sign in on my pc after reinstalling windows xp
You can try to start up the computer in safe mode and sign in to the admin account. if you never used it there should be no password.
Dec 10, 2013 | 2001 Buick Century
Tip
How to repair windows xp operating system
One of the best kept secrets of Windows XP is it's built in repair feature!
In previous versions of Windows, correcting an operating system error, or installing a new motherboard, usually meant formating and reinstalling, resulting in loss of all data. Don't worry; Windows XP repair feature won't delete your data, installed programs, personal information, or settings. It just repairs the operating system!
Note: The system repair function will remove any updates you have previously installed that are not included on the CD. Drivers will also be reverted to their original XP versions, as well as some settings (network & performance settings may sometimes be reset to their defaults). It may be necessary to reactivate your Windows XP as well. When finished, you will have to download all of the updates from Microsoft Windows Update, because they are all replaced during repair.
Why would I want to reinstall Windows XP?
1) Can't start Windows XP in safe mode.
2) You have problems caused by a recently installed system update (Windows Update, hotfix, Windows XP service pack, or Microsoft Internet Explorer update).
3) Your problems can't be solved with system restore, or you can't access system restore.
4) You've installed a new motherboard, or made other major hardware changes and need to reinstall Windows.
Let's get started!
Step 1: Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
Step 2: Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
Step 3: Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD. Can't boot from your CD? Please see the note at the bottom of this page (Configuring Your Computer to Boot from CD).
Step 4: A blue screen will appear and begin loading Windows XP Setup from the CD.
Note: RAID/SCSI/Unsupported UDMA users:
You will be prompted to "press F6 to install any third party SCSI or RAID drivers". Most users will not have to press F6, but if you are running RAID, SCSI or unsupported UDMA controllers, then you will have to have your controller drivers on a floppy disk. If you are unsure whether you have RAID/SCSI, then simply let the CD load without pressing F6.
When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
When presented with the screen below. press the F8 key to continue.
Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
Note: If you install a fresh copy, all data on that partition will be lost!
Your almost finished! Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts, and have your CD-KEY ready if needed.
Do you have more than one system, or lost your CD-KEY? Visit the keyfinder page to retrieve your CD-KEY.
Update: Due to the proliferation of the Blaster and Welchia Worm/Virus be aware that a Repair Install will leave your system vulnerable. You can get infected within seconds. Do not go on line until you have enabled XP's firewall first.
Remember to run Windows Update! (install critical updates first)
Many computers are not configured to boot from the CDROM. If you cannot boot from the CDROM, this is probably due to the boot order of your devices being incorrect. You can change this in the BIOS.
You enter the BIOS from the first screen you see when you turn your computer on. To enter your BIOS, most users here will press the DEL key.
Most Dell, Toshiba, Gateway, Sony & HP systems will press F2.
Compaq users will usually have to press F10.
IBM typically uses F1 or F2.
Other brands may have different keys to press to enter setup, F1, F2, Del, Tab and CTRL+S. If possible see the manual for your computer or motherboard. Also, the BIOS will usually display which button to press to "enter setup" during POST (if it flashes by too fast, press the Pause key).
When you enter the BIOS setup, you need to change the boot order. The CDROM should be setup before the Hard Drive. Each BIOS is different.
Note: If you need assistance with a repair installation, please start a new topic in our Windows XP Forum. This topic is also open for comments, but not all will receive a reply.
IMPORTANT NOTE: After running a repair, you may find that Windows Update refuses to install the most recent 80 patches. This is because the latest version of Windows Update is broken, and doesn't register some DLLs if they're previously been registered (as happens with a repair install). Here's a work around until they get it fixed:
Stop the Automatic Updates service. To do this, follow these steps:
Click Start, click Run, type cmd, and then click OK.
At the command prompt, type the following commands, and then press ENTER after each command:
net stop wuauserv
exit
Register the file that is used by Windows Update and Microsoft Update. To do this, follow these steps:
At the command prompt, type the following command, press ENTER after the command, and then click OK when you receive a verification message:
regsvr32 %windir%\system32\wups2.dll
Note: for x64 machines regsvr32 %windir%\syswow64\wups2.dll
Start the Automatic Updates service. To do this, follow these steps:
net start wuauserv
exit
on Jul 02, 2010 | Computers & Internet
Computer wont bootup windows xp error loading operating system drive 1 not found please help me
1.Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
3.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
Performing a repair installation of Windows XP can fix many serious startup problems. While you should not lose any of your important documents, you might lose settings, and you will need to reinstall many updates.
Before performing a repair installation of Windows XP, you should have both your Windows XP CD and your product key available.
To perform a repair installation of Windows XP
1.
Insert your Windows XP CD into your computer.
2.
Restart your computer. If prompted, press a key to start from the CD-ROM.
When the Welcome to Setup page appears, press ENTER on your keyboard.
On the Windows XP Licensing Agreement page, read the licensing agreement. Press the PAGE DOWN key to scroll to the bottom of the agreement. Then, press F8.
When prompted, press R to have Windows XP attempt to repair Windows by reinstalling important Windows components.
The repair and reinstallation process might take more than an hour. Eventually, Setup prompts you to answer questions just as if you were installing Windows XP for the first time. For detailed instructions, read Install Windows XP.
Oct 26, 2010 | Computers & Internet
How do you reinstall Windows XP on an Toshiba Satellite A60 PC Notebook?
1. boot your PC or laptop from the Windows XP CD (To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer).
2. You will see "Press any key to boot from CD" displayed on the screen, at this point press any key to start the computer from the Windows XP CD.
3. You will see the Welcome to Setup screen, press ENTER to start Windows XP Setup.
4. Read and agree to the Microsoft Software License Terms, and then press F8.
5. Follow the instructions to select and format the c: partition where you want to reinstall Windows XP.
6. Follow the remander of the instructions on the screen to complete Windows XP Setup
7. Reinstall any drivers which are required.
8. Reinstall any software programs which you need.
9. copy your data back to the drive.
Jan 07, 2010 | Toshiba Satellite A60 Notebook
I have a dell with windows vista. the monitor is 20 or 21 inches wide screen. I recently had a friend try to install windows xp but at the last attempt he tried to reformat my computer & install it xp...
You can adjust the screen resolution to increase the size of the image to fill the screen.
Go to the Control Panel - Display - Settings and adjust the screen resolution to 1280 X 1200 pixels. If this still doesn't fill the screen then increase it further say 1600 X 1200 pixels even higher if necessary.
Aug 19, 2009 | Dell Computers & Internet
Windows xp will not load
When it asks for administrator password, and you didn't have one set, just push enter and you'll be able to continue.
If you don't need any information from the computer, use a program to writes zeros to the drive and then you'll be able to install windows. HDD manufacturers provide a program to zero the drive
May 08, 2009 | Dell Latitude D600 Notebook
Can't reinstall printer- ''print spooler is not working''
If you have the windows disk for it , Save everything important to disks.  Put WIndows  disk into machine and tell it to install. It will find you version and ask if you wish to repair it, Say yes.   If you have Xp pro just "Restore" computer to the date before the problem started. If you have neither one. Save you work and then reinstall everything using your backup disks.
Mar 18, 2009 | HP Computers & Internet
Lifecam VX-6000 microphone in Windows XP stopped working
you need to restore your PC back to the date when it is working.pls.. rate.ty
Jan 27, 2009 | Microsoft LifeCam VX-6000 Webcam
Windows wont open
need to re-install windows
Oct 20, 2008 | Acer Aspire 5100 Notebook
Dell Dimension 4600 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
