Hard drive makes a noise
Makes noise when running
  • 3,320 Answers
There are no serviceable areas in a hard drive. Noise equals big problems. Replace the drive. SOON!
Posted on Mar 18, 2014
My Segeate Hard disk (500 GB) is making weird noise like scratching or ticking.Can data recovery is possible without any professional help?
Back up your data or image your drive. Next download Seagate's Seatools for Windows (or DOS) and run the diagnostics to see if the drive is actually failing.
Sep 15, 2014 | Computers & Internet
Toshiba MK1059GSM sudden noise?
First backup all your data asap. Noises of this type are a sign of a failing drive.
Then run the extended test... http://gsmartcontrol.berlios.de/home/index.php/en/Home
You should be able to replace the drive with in the one year warranty period.
Sep 12, 2012 | Toshiba (MK1059GSM) 1 TB Hard Drive
My Passport Essential making clicking noise
it might be power or data trying to get a connection make sure all power and data leads are securely attached
if this fails you might have a dirty hard driver with the reader arm skipping across the platters on your hard drive
give the hard drive a firm tap on the side to free up the reader arm you might be able to get it going long enough to slvage your data or it might go for a longer time
or you might use the freeze hard drive
http://lifehacker.com/170257/macgyver-tip--save-your-hard-drive-in-the-freezer
hope this helps
Aug 15, 2012 | Western Digital My Passport Essential...
Why does my hard drive make grinding noise in sleep mode?
Hi Lou, that's a good question. In sleep mode there should be absolutly no noise at all as the machine is asleep. If there is a noise then it is not asleep. Also, the chances of a hard drive in a laptop making a grinding noise is pretty slim so it is probably not the HD - if it was you would be having trouble using the Mac. It could be a fan that is still running to cool the machine down. How long does the noise go on for after you put it to sleep?
Apr 09, 2012 | Computers & Internet
Hard drive is making a "clicking" noise
The clicking noise is the reader arm skipping across the platters on your hard drive
a dirty hard first clean all of the dust from your computer using a fine air blower from an air compressor making sure there is no MOISTURE in the air line then give the hard drive a firm tap on one side to free up the read arm
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which willscan for and attempt to repair any bad
sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Jan 12, 2011 | Dell Computers & Internet
I have this Lacie 1TB hard drive and i recently uploaded about 150 GB of video on it at once. I did it over night and the next morning the drive was making some noise like its working on something. Now it...
Drive noises are typically a common and needed noise. Most run via magnetic (voice coil) technology and that is noisy. Slow play back may be related to connection, usually you need stuff on your harddrive (C:\) to avoid access delays.
Oct 03, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My computer makes a loud noise,how can I fix this problem please?
there are a limited number of things that could be making noises. take off the cover of your computer and listen close when you start it. A fan would be the first thing i'de suspect. check them all- cpu fan- motherboard fan-videocard fan- powersupply fan.
I would also listen to the powersupply (rear top of computer)
only things left to check that could be making noise are the cd/dvd rom, floppy drive (both wont run without a disk in them) and your hard drive which would be the last one to make noise. the hard drive runs everytime your computer moves data, if it is getting loud, i would suggest backing up important files and shopping for a new one. Post again here if I can be of further assistance.
Regards..
Apr 06, 2009 | E-Machines eMachines Desktop PC
Hard drive making strange alarm/chiming noise and won't load onto desktop
Listen to your power supply and see if it is making a faint buzzing noise. Try your device with a new power supply. With a new power supply my drive now runs fine, and was not corrupted.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Seagate SanMax 120GB external with fan noise
It depends on the noise. It should be still under warranty. You should NEVER operate it without a fan as this is a safety hazard. If it is making a noise like a buzzsaw, it is most likely the bearings of the HD mechanism. If it is making a scraping noise, it's likely the fan. Make use of the warranty if/while you still can!
Nov 14, 2007 | Seagate 120GB 7200 rpm Ultra ATA/100...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
