Question about Garmin nuvi GPS
Only one language on garmin need english only have french
I don't know how to get it off French language. It is the only one that shows up on voice. I have used this garming before and didn't have this problem. can you help me. I have big trip thursday. thank you Cheryl Tavernia
SOURCE: Using French grid reference system
UTM GPS position format, WGS 84 datum point if my memory serve correctly
Posted on Aug 29, 2007
vivek chi
  • 14 Answers
SOURCE: language
go to settings /phone settings/language and change it to french
Posted on Jan 28, 2008
SOURCE: garmin nuvi 760
Go to tools-settings-language-voice and make sure it is set to "American English-Jack (TTS) or to American English-Jill (TTS)
Posted on Oct 10, 2008
SOURCE: Need assistance changing from phone language from french to english
can any1 help me, my brother brought me a htc touch phone from hong kong and i want to change it to english
Posted on Oct 14, 2008
  • 9 Answers
SOURCE: PROBLEM DRIVERS
Go to the Holux support website at:
http://www.holux.com/JCore/en/support/downloadCenter.jsp
NOTE: All quote marks are added by me for emphasis only.
Under the "Select products Catagory" dropdown choose "GPS Receiver/Data Logger".
Under the "Select products series" dropdown choose "Mouse Type GPS Receiver" and
click on Submit. A new page opens showing various receivers. Scroll down to the GR-213u
GPS Receiver and see the one called "GR-213u Driver Program-Vista Driver". It is of a type
of file compression called "rar" which may require a unzip program. I use a free program,
"Secure Zip for Windows". Click on the little yellow box at the far right of the "GR-213u
Driver Program-Vista Driver" line. It will be labeled "9618869.rar". Save the file.
It should be found by clicking on the Vista START and then your user name & should be in
the "Downloads" folder as "9618869.rar".
Creat a new folder for the actual unzipped file by clicking on the the Vista START Icon
& then "Documents". Click on the "Organize" tab & then on the dropdown "New Folder".
Name the new folder "Holux Vista Drvr" & then open it.
Now back at the "Downloads" folder open (Unzip) the "9618869.rar" file. Copy the new
folder "GR-213u Driver Program-Vista Driver" to the "Holux Vista Drvr" folder you created
in "Documents", so that you can later delete all those files that may have built up in
"Downloads"folder from doing lots of downloading.
Open the "GR-213u Driver Program-Vista Driver" folder & see the setup file
"PL2303_Prolific_Vista_3301.exe". The size should be about 2724 KB. Open it to start the
driver install. Now you are almost done.
After Vista has done its driver install, go to "Control Panel" & open "Device Manager".
Now plug in your Holux GR-213 & the "Device Manager" should now show a new entry
called "Ports (COM & LPT). Click on the little + sign to expand it & you should see
"Prolific USB-to-Serial Comm Port (COM#)". The # represents your Comm Port number
used by the Holux. Right click on "Prolific USB-to-Serial Comm Port (COM#)" & click on
the dropdown "Properties". Click on the tab "Port Settings"at the top of the "Properties"
window. Change the value in "Bits per second" from 9600 to 4800 & click OK.
Hopefully you have installed the Holux Utility "GPS Viewer" with a shortcut on the
desktop. Open the "GPS Viewer" & click on "Scan". A new window "GPS Scanning" opens
showing GPS found at the same Comm Port # that shows in the "Device Manager". Click on
OK & the scan window closes now showing the same Comm Port#. Click on "Open GPS" &
then on "Cold Start or Warm Start" & all the satellites found should show up. You can close
the "GPS Viewer" & all the other open windows. If all went as described any software you
used with Win XP using GPS should work OK now with Vista.
Now run your software (MS S&T or whatever) & make sure its GPS Settings show the same
Comm Port# as in "GPS Viewer" & baud rate of 4800.
Posted on May 09, 2009
Only have French voice...cannot get English
you can download voices and other options from Garmin web site.
You need to register using NUVI serial number...
May 13, 2014 | Garmin Nuvi 40
No french laguage
On the Nuvi 7xx series as well as many other nuvi models, voice updates are free and downloadable from garmin.com. Garmin only charges for map upgrades. Maps do not contain voices. I have backups of french text to speech (TTS) voices. I would be happy to give you links to download them to you.
Mar 05, 2014 | Garmin nuvi 750 GPS Receiver
I would like to change from french to english on nokia 6100
Go to phone settings and select the option display. You can find the the settings for language there you can choose your language.
OR:
you can find in the settings>>phone settings>>language.
hope this helps.
if you need, and you don't have copy of the manual, let me know
Nov 02, 2012 | Nokia 6100
I can't change from Japanese to French. Please,show me how . Thank you
To change the language to French;
  • Press TOOLS (The spanner symbol on the bottom right corner of the screen which shows WHERE TO and VIEW MAP) This may take some trial and error if you don't speak Japanese but should be possible)
  • Press SETTINGS (The spanner icon) or LOCALE (the blue icon) on some models that don't have a settings menu)
  • Press LANGUAGE (the lips icon)
This brings you to a screen with 3 items; VOICE, TEXT LANGUAGE and KEYBOARD. Press each one in turn and select Francais. With the VOICE setting you may have to select a name rather than Francais. If so select the name of a person from a French speaking country.
I hope this solves your problem.
Jun 02, 2011 | Garmin nuvi 205W GPS Receiver
I accidently changed the language on my 205 series. I think its French but am not sure. How do I get it back to English?
  • On the page that shows WHERE TO and VIEW MAP press TOOLS (The spanner symbol) in the bottom right corner
  • Press SETTINGS (the spanner symbol) or LOCALE (the blue symbol) on models that don't have a settings icon
This brings you to a screen with 3 items on it. VOICE, TEXT LANGUAGE and KEYBOARD
If it's in French you won't know which is which but it will show the language beside the TEXT LANGUAGE icon. Francais is the French word for French. To change the voice language press VOICE and select an English speaking name. To change the text language press TEXT LANGUAGE and select English or American English if you're in the USA.
This should solve your problem.
Feb 07, 2011 | Garmin nuvi 205W GPS Receiver
I have a Garmin 265w and the writing is in french and I want it in english How do I reset it back to defult there is no small hole in the bottom of it
Resetting the satnav will not change the text language. Below are details on how to change it.
  • On the page that says WHERE TO and VIEW MAP there's an icon of a spanner in the bottom right corner. Press the spanner.
  • Press SETTINGS (another spanner icon) or LOCALE (the blue icon) on models that don't have a settings icon
  • This takes you to a screen with 3 items. VOICE, TEXT LANGUAGE and KEYBOARD
  • You may have to use trial and error to find which of these is TEXT LANGUAGE but when you press text language you can select English or American English if you're in the USA.
The French word for French is Francais and this should be shown beside TEXT LANGUAGE. I hope this solves your problem.
Jan 19, 2011 | Garmin Nuvi 265W GPS Receiver
I have Garmin 3790 and some how managed to change the language from English to French. How do I change it back please?
Press TOOLS (Spanner Icon)
Press SETTINGS (Spanner Icon) LOCALE on some models (Blue Icon)
Press Language (Lips Icon)
If you need to change the voice language press VOICE and select an English voice.
If you need to change the text language press TEXT LANGUAGE and select English
Sep 30, 2010 | Garmin nuvi 250 GPS Receiver
Street turn
you can only change to the voices available in your device.
Aug 08, 2009 | Garmin nuvi 255W GPS Receiver
Garmin 250
In your menu, tools,languages,
You have 4 choices, voice , text, keyboard,restore, to ammend.
http://www8.garmin.com/manuals/nuvi200_OwnersManual.pdf
page 22.
Hope this helps
RPF.
Nov 01, 2008 | Garmin nuvi 250W GPS Receiver
Model 21028GE3-A multihand phone
To change the language used by the answering machine, look behind the base. There are four buttons in back, one says Language. Press it until you hear the language that you want.
Sep 06, 2008 | GE 21028GE3 Cordless Phone
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
