Question about Blenders
I need the blade assembly for a Westinghouse blender WST2019W
I have a Westinghouse blender model no. WST2019W and it is about 12 years old. I really love this blender, but unfortunately I just broke the blade assembly. I tried to find it by calling the Westinghouse product warranty department, but they don't carry it anymore. Does anyone have any idea where I can find it? Thanks!
SOURCE: Bamix stick blender Handle vibrates but shaft does not turn
Old food residue and juices will have got into the shaft bearings, and have dried out enough in 9 years to stop it turning. Starting with the simplest solution, try immersing the shaft in hot, or even boiling, water nearly up to the top of the metal shaft. CAUTION - DON'T BURN YOURSELF! Let it stand in the water for a few hours, and then try turning the shaft by hand (with the machine unplugged, of course). This could be repeated a number of times. You may also be able to unscrew the blade guard after this treatment, bear in mind it has a left hand thread, so if you are looking at it from the bottom, turn it clockwise to loosen. Be careful not to lose any seals or springs when it comes off.
If this doesn't work, support the Bamix upside down, and pour a small amount of WD-40 into the blade guard, so that it pools around the end of the shaft. Leave to stand, and the oil should slowly seep into the bearings, dissolving the food residues. Again, try this a few times.
If neither of these work, the Bamix will need to be dismantled to clean the shaft and bearings. This is really beyond the scope of this forum and requires some experience of this type of work.
Posted on Mar 13, 2009
  • 10865 Answers
SOURCE: Need replacement blade for Russell Hobbs hand mixer
go to this page http://www.russell-hobbs.com/parts.shtml and order what you need directly from Russel Hobbs.
Please mark this answer as a fixya! thanks
Posted on Mar 18, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: CA 4203 model #, Smoothie 700 Pro
Here's the parts order form:
http://www.focuselectrics.com/finditem.cfm?itemid=4287
-Tha Mp3 Doctor
Posted on Mar 27, 2009
SOURCE: Can't find replacement parts for my Thunderstick Pro blender
I can sell you part of mine. I getting a new one to replace a part for mine.
Posted on Jun 10, 2009
  • 244 Answers
SOURCE: How do I fix or
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Posted on Jun 16, 2011
I need a blade for Lectrix blender Model 0101
get to the shop where you bought this blender and ask for a blade.... they mite take for exchange....
good luck Thanks for rating
Jan 04, 2011 | Westinghouse 0101 IntelliBLEND¿ Work...
I need glass jar for westinghouseintelliblend model#wst2019w thanks
sometimes you can post what you are looking for on Ebay and wait ,there are companies that have new and used for Demos very cheap too >^.^<
Mar 12, 2010 | Westinghouse 0101 IntelliBLEND¿ Work...
Motor works but blade not spinning
Check and make sure that the shaft in the base housing spins. If it does, the blade assembly has become disconnected from it's shaft probably due to an improper spot weld or peening of the blades to the shaft, or has torn loose or ripped the splines out due to an immovable object trying to be spun. A jammed ice cube can do this. Blade assemblies can be had usually directly through the manufacturer and usually on line. If this has helped, please rate it accordingly.
Jul 20, 2009 | Westinghouse 0101 IntelliBLEND¿ Work...
Waring blender - new blade
You can call Waring and they can send you a parts breakdown showing the order the parts need to be in. If you still have problems they can go over the assembly with you on the phone or direct you to a service center near you to help.
Feb 21, 2009 | Blenders
Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
Jan 28, 2009 | Blenders
Stopped blending
Exact same problem.  Turned out the threaded shaft that holds the blades was broken so tightening the nut on the top doesn't really help.  Just ordered a new blade assembly from www.smallappliance.com.  Mine was the Waring 007314W Blender Cutting Assembly but there is also an older one for earlier models.  Don't know if it will work yet (assume it will), but cheaper than buying a new blender.
May 17, 2007 | Waring PBB 25 Professional Work Top...
Blenders Logo
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
