Question about Toys
I need to order a pump replacement for a Hukou Falls SKULWHFS
I would like to place this order.
Hoover steam vac, center brush falls out repeatedly
Hey there! All the brushes have to work together to function properly. If the center brush is falling out the brush block assembly is broken and will need to be replaced. Follow the link below to place an order for a replacement brush block.
Search Results
Hope this was helpful!
Aug 02, 2014 | Hoover C3820 Commercial Steam Vac Black...
My 1994 pontiac transports ignition is stuck in the on position
Typically what happens is the lock cylinder falls apart and jams inside of its housing. The good news is the key needs to be in the run position in order to remove the lock cylinder. Once the steering wheel covers are removed you will see a small hole in the hosting the lock cylinder fits into. Place a small screwdriver or pick into that hole and push. This will release the locking tab that holds the lock cylinder in place. Pull out on the lock cylinder and it should pop out. A replacement can be found at your local parts store or dealer?
Apr 09, 2013 | GMC Suburban Cars & Trucks
The ignition is stuck on the on position and wont turn on or off
Apr 09, 2013 | 1994 Pontiac Trans Sport
Do you have to pull the engine to replace water pump?
it is a tight fit, but you do not have to remove the engine to do a water pump-rachetting wrenches are very helpfull this because of the narrow clearances though/
Aug 21, 2011 | 1998 Saturn SL
I have an error E20 showing on my machine. The filter is ok. How can I check the pump for a blockage ?
TURN POWER OFF FIRST take the kick plate off undo the screws holding pump to machine lean the machine back so you can get underneath it a torch will be handy then you need to take the screws out of the pump pull pump of filter and undo hoses clear any blockages then check the propeller on the pump if it falls off or spins around freely you need a new pump. it should as you spin it round lock into its place kind of thing as you move it round.
Jan 05, 2011 | Zanussi IZ12 Front Load Washer
2000 ford mustang code 453 and missfire cyl 5 where is the cyl
a haynes manual from a parts place will show you--or chec the condition of each plug wire-if one looks bad or falls apart--probly need to get all new wires /plugs
Dec 18, 2010 | 2000 Ford Mustang
I have a 99 chev blazer and it falls on it's face and then the next minuite it falls on it's face. Won't hardly run. Someone told me it's probably the fuel pump does the fuel pump have a fuse?
The fuse would not allow the fuel pump to work,then not work,replace the fuel filter first,if this does no good,have the fuel pressure checked.If this was helpful,please rate,thank you.
Jun 24, 2010 | 1999 Chevrolet Blazer
TFXW24RL ICE FALLS EVERYWHERE ICE SHUTE PERISHED TO GUIDE ICE CAN I REPLACE PART IN AUS
Here's one place you might can find the part. Post your model number in the proper place and select the dispenser parts. You'll have to go through the ordering process to see where they ship. http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Aug 19, 2009 | GE Freezers
Need help replacing 1998 hyundai sonata fuel pump
in order to replace fuel pump one has to drop the gas tank.. make sure car is turned off unplug all hoses and electrical switches, once the gas tank is off the car the fuel pump is visible on the top side of the tank... simply replace the old pump with the new one.... place gas tank back in place plug all hoses and switches back..turn car on and leave it on idle for a couple of min..
Jun 13, 2009 | Hyundai Motor 1998 Sonata
Replace a headlight in 2005 chevrolet trailblazer It is the low beam light that is on the passager side.
Purchase a pair of bulbs (30.00). Start by removing the plastic trim with the Chevy emblem, pry off with a screw driver. There are two tabs that hold the head light assembly in place. Pull both up and the assembly falls forward. A quarter turn releases the bulb housing. Change bulb and reassemble in reverse order.
Apr 07, 2009 | 2005 Chevrolet TrailBlazer
Toys Logo
19 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
