Question about Roland GX-300 CAMM-1 Pro Vinyl Cutter
I have a roland camm 1 pro cutter and I can't get the machine to communicate with my computer and produce an image any longer.
It used to work perfectly.
Fault motor voltage error
Check the voltage. You may have to do a hookup. (hookup) a unique connection to a component to check voltage or signals.
May 09, 2014 | Roland GX-300 CAMM-1 Pro Vinyl Cutter
Machine is not responding
Did you get a fix to this problem? I also have the same problem
Jan 03, 2014 | Roland GX-300 CAMM-1 Pro Vinyl Cutter
Pen mode light blinking
Material not aligned or wrong thickness... Blinking means something is not right. Try taking the material out and see if it changes, things like that, troubleshooting....
Nov 26, 2013 | Roland GX-300 CAMM-1 Pro Vinyl Cutter
Can someone tell me how to use my Roland CAMM-1 CM300 Pro vinyl cutter with Windows Vista as it's a pretty old machine and I think will only work with Windows 98
You should Buy a newer Model, Vista will not detect it. That is why Vista was a mistake... I like Linux Computers much better
Sep 25, 2013 | Computers & Internet
Message error moteur (02) sur camm 1 GX 300
XEROX 5020 PHOTOCOPIEUSE ERREUR U4 LA SOLUTION
Sep 16, 2012 | Roland GX-300 CAMM-1 Pro Vinyl Cutter
How to get out of dpics mode on a roland camm-1 pro gx400
Please help us the error code comes "dpics mode" in roland gx-500
Jul 29, 2012 | Roland GX-400 CAMM-1 Pro Vinyl Cutter
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
Roland GX-300 CAMM-1 Pro Vinyl Cutter Logo
89 people viewed this question
Top Roland Office Equipment & Supplies Experts
JonSnell Electronic
JonSnell Electronic
Ravi
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
