Question about Acer A2909.001 Aspire 1800 Aspire 9500 Keyboard
Laptop goes suddenly off
I have got an aspire 1800. Since few weeks it would suddenly go off. I changed battery and bought a new battery charger as well but the problem is still there. Can someone help me please
  • 244 Answers
The sudden shutdown, is caused by an overheat problem.
Notice that the laptop is hotter than usual when it happens.
As a quick solution, get a vacumm and **** the dust accumulated on the fan or fans.
That should bring your laptop back to work.
In more serious cases, the heat sink will need to be cleaned up.
If you are not familiar with the process you should seek for professional help.
Please rate this answer if its helpful
Posted on Jun 18, 2009
Acer Aspire 4830T laptop battery behaving vaguely
Do you still have the old battery. If so charge it, and see if it charges properly. If so then you have a bad battery.
Mar 18, 2017 | Acer Aspire Timeline X 4830T 14 Inch...
My acer aspire one notebook won't boot up.
Is the new cord/charger/transformer the EXACT same power specs? When your "dog ate your charger", it may have shorted out something in the Laptop? Was it plugged it when your dog ate it?
Jan 16, 2013 | Acer Aspire One PC Notebook
2 ac adaptors have stopped working on acer laptop
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.
If it still can't work, perhaps the charger you bought is a dead one, just contact the seller to get a replacement one after all you have used it for about a few minutes. If you don't believe in that seller, just contact them for the refund and go to other vendor for a new adapter. I recommend the following one for you:
http://www.chargerbuy.com/replacement-acer-aspire-5739g-ac-adapter-19v-4-74a.html
http://www.chargerbuy.com/replacement-acer-aspire-5738-ac-adapter-19v-3-42a.html
Oct 26, 2012 | Lifetime Acer Aspire 5738PG Replacement...
Acer cannot switch on to wifi
I have that same one bought new and the wifi card was bad when i bought it
Jun 30, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
Hello, As i was working on, suddenly my laptop was shut down without any indications. and i tried to start it but it did not. after plugging in the battery charger it started. After that if i remove the...
Looks like you have a faulty battery, since you bought your laptop 4 months ago, I think it is still covered by their warranty. Please try to contact the manufacturer about the possible battery replacement. :)
Some of the things to do/check if the manufacturer requires you to return your laptop to them: 1. Backup all your important files to a different media/storage, like an external hard drive or burn them to blank DVD's
2. You can also tell them that it MIGHT be your charger that's faulty. Either way, they SHOULD check the battery and charger.
Nov 18, 2010 | Acer Computers & Internet
Hi I have a acer aspire 5720 laptop had it about 1 year the orange light on the front which shows battery charging started to flash and when I moved the charger wire it flashes on and off I bought another...
Usually when you see this flashinf indicator it is a failing battery. IT maybe that some of the cells in the battery are failing and refusing to accept a charge, in that case the battery will actually damage the charger.
May 21, 2010 | Acer Aspire 5720 6497 Laptop
Not charging
If you have tried both adapter to swap as well as the battery the problem might be with you MOBO or mother board try to flush the bios first or get the latest bios update of you system .
ERNZ
Feb 03, 2010 | Acer Aspire 5920-6335 Laptop
Problem with battery or motherrboard?
ok..first thing..does it run ok with no battery on mains power?
Feb 29, 2008 | Acer Aspire 5100 Notebook
Acer A2909.001 Aspire 1800 Aspire 9500 Keyboard Logo
112 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
