Question about Ryobi Garden
Ryobi 150r trimmer runs very slow
My friend gave me this to fix for him, first it ran very slow so he installed a new battery, then it would not charge. I looked at it and found he reversed the battery leads,I repaired this and the charging light lights up, but it is still runs very slow no matter how long its charged??? The motor?? is there a way to test it??? Other ideas Thanks James
SOURCE: Trimmer Not Charging - No CHARGE Light too.
I have the same problem using Remington MB 200
Posted on Apr 11, 2008
  • 313 Answers
SOURCE: weed trimmer, cst 1000
common problem battery
Posted on May 29, 2008
SOURCE: battery
battery is dead, maybe you need to ask for the guarantee
Posted on Sep 10, 2008
joboo1
  • 257 Answers
SOURCE: Ryobi 18V lithium battery won't charge
Hi, Thanks for getting back to me. The yellow and blinking red indicate a defective cell. Since it has lithium cells and is that new any repair to it would be a waste of your time. Ryobi tools purchased in 2008 have a 2 year warranty. I am guessing you probably got it at a home depot and you should return it under the warranty. All new Ryobi tools have a three year warranty. Good Luck! and Thanks for using fixya!
Posted on Feb 05, 2009
  • 103 Answers
SOURCE: Ryobi charging stand BCSC12C does not charge battery
i have a manul that you can fix all your batterys ,very easy email me i will send you the file cheers at pfcatering@optusnet.com.au
Posted on Apr 12, 2009
Ryobi 40022 trimmer (40v lithium battery) has completely stopped working. Battery and charger kept inside when not in use. Battery indicates that it is fully charged when in the charger. Any ideas?
Sounds like a bad charger my friend..test suposly charged battery with a multimeter and you will find your answer...can also test charging unit with it too...GL
Aug 13, 2016 | Ryobi Garden
New Ryobi trimmer putters out at full throttle
Absolutely it can. Weight can slow it down, Friction can slow it down,. There are many things that will do exactly what you are talking but the #1 thing would be a Gummed up Carburator. EVERYONE is having the same problems right now.
Apr 07, 2013 | Ryobi 2-Cycle 26 cc Curved Shaft Gas...
Cross section of ryobi 18v trimmer
the wiring maybe disconnected, either at the switch or down near the head of the trimmer
Sep 09, 2012 | Ryobi Lithium Ion 18 Volt 18v Cordless...
My weedeater starts but doesnt seem to be getting enough fuel
You can't clean the filter. You can however order a new filter with the filter attached from www.ryobi.com.
When you say it's not getting enough gas is the weedeater shutting off on you? If so your carb may need to be clean. If that's the case then report back and I can tell you how to do that.
Mike
Aug 19, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
I believe my Ryobi 12 VoltBattery Line trimmer need a new battery
First, check to see if the charger is working properly. To do this, recharge the battery for about 15 minutes. Then check to see if it now runs the trimmer. If so, then you have a bad battery. You can go on the WEB and find a replacement. These batteries or sensitive to heat and cold. When storing, try to place it in a comfortable environment. Sorry for your loss. If it still under warranty, check with the Co.
Dec 27, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
Oct 03, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 12 V 10: 150r trimmer edger - How to remove battery
Easy!
Just remove the screws from the housing (I had to do it this morning). There are approximately 12 screws that can removed with a flat head screw driver, all from the same side of the housing. The housing readily opens up, but be carefull, there will be some rubber strips that start to fall out. Make sure you keep these; you will need them again for the replacement battery you install. The rubber strips act as a cushion between the battery and the housing's inner ribbing; helps to reduce rattle & vibration.
Next pull the 2 electrical leads (red and black) down and off of the battery terminals, a quick **** will work well.
Lastly, your battery is 12V 8.0Ah and retails for $100 plus shipping. Mine lasted 11.5 years, but finally died (I think). You might however, want to have your battery tested to see if it really is bad, it may be a bad charger which is only $10 - $20 to replace.
Aug 07, 2008 | Ryobi Multi-Volt Battery Charger
Garden Logo
275 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
