Singer washing machin sts 60 nda rpair
Singer washing machin sts 60 nda slow speed and water not flow out from tob to pipe. valve is ok 1 what is belt no use in this machin 2 how can remove rotator from tob
SOURCE: Washer not completing cycle
I HAD THE SAME PROBLEM ON A 4 MONTH OLD MACHINE AND I CALLED A SERVICE PERSON. HE SAID THAT I CAN THROW IT AWAY. THIS IS A PROBLEM THAT NOBODY CAN FIX.
Posted on Feb 15, 2007
  • 1462 Answers
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Posted on Jun 22, 2007
  • 183 Answers
SOURCE: cold water will not flow into machine
either the valveis faulty or the dispenser box is blocked, remove the internal hose from the valve anf see if you have full pressure at that point if yes box is blocked. Regards Advisor
Posted on Aug 22, 2007
  • 156 Answers
SOURCE: Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Posted on Feb 27, 2008
grandadfixer
  • 99 Answers
SOURCE: washing machine wfm 2010 not rotate just fill and drain water
sounds like the carbon brushes in motor,Or motor has had it.
Posted on Oct 11, 2008
Ecs gentle annie
Is it just the cold valve slow do you have a hot valve to swap it with to check the flow rate.
I think there 12volt valves,
The solenoids would be OK just the valve wont open all the way.
The solenoids do come off with a flat blade screwdriver under the solenoid.
Dec 17, 2013 | Fisher and Paykel GWL11 Top Load Washer
MY nEP[TUNE WASHER WONT STOP RUNNING WASTER
Ok there are 2 possibilities that cause this problem. 1) If the drain pipe is placed to low, the water will not stop draining. It will just carry on coming into the machine and just flow out again. Make sure the pipe is at least 3/4 the height of the machine before that draining will stop. 2) If you switch the power off on the washer, and the water still comes into the unit with the power switched off,then the water solonoid needs to either be serviced or replaced. With the plug pulled out, undo the 2 water pipes connected to the water valve assembly.Once removed, open the individual valves and clean them properly. once cleaned, reassemble and retry. Either of those 2 must work. My bet is the water pipe is to low. lift it up a lot higher.
Aug 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water slow coming into the tub this happens every time you turn on the washer. We cleaned the screens
Check the water inlet pipe is not kinked or blocked. If you can turn water off, remove pipe, place pipe end in bucket, turn water back on, check flow from the pipe to eliminate it. If not that, then the water control valve in the machine might want replacing. By the way, those horrible "quick connectors" that are sometimes used to screw on to the water pipes, can corrode over the internal hole, and prevent good flow, so replace with a proper washing machine valve, and TEE connector.
Aug 11, 2010 | Maytag Washing Machines
When i run the cold water into the wash machine it runs very very slow. What could the problem be?
If the water flow/pressure is ok to the inlet valve and the inlet valve filter is clear, it's likely that the inlet valve itself needs to be replaced.....Not an uncommon problem...not difficult to fix...Good luck....Nomess
May 21, 2010 | Washing Machines
Why it takes 1.5 hours to wash my clothes in washing machin
The washing process might be delayed due to slow water speed in the inlet valve to solve this kindly check the pipe line for any block in that
May 18, 2010 | Whirlpool LTE6234D Top Load Stacked...
Hot water will not run properly into machine, have
fit new hot water valve but check the flow from your fill pipe first both easy jobs
Dec 15, 2009 | Washing Machines
Cold water flows slowly into the tub when doing wash. checked the screen at the water inlet on the machine and it is clean. water flow on the connecting hose is also ok
If screen and water pressure are ok then the cold water solenoid valve assembly could be partically clogged. The older ones could be taken apart and cleaned. I cannot say if yours can be cleaned.
Jul 07, 2009 | Speed Queen Washing Machines
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
Kenmore wash macine
Feb 27, 2008 | Washing Machines
Kenmore washing machine 80 series
check for kinks in the pipe or restrictions to the flow in the pipes before it gets to the washer, if all is ok then check the filter on the outside of the water connector on the machine for dirt
if you confirm all is clear and the flow of water is not the problem before the machine, replace the cold water solenoid
Oct 14, 2007 | Washing Machines
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
