Question about Delfield Freezer 6151XLSR Stainless steel
Display flashing HI
Everything is thawing
Moved, freezer wont run properly, food thawed out, digital readout display flashes E and then flashes #9 alternately. what do I do?
E9 is a defective Temperature Control
  • You will need to replace Part # 297216004 It should be mounted on the evaporator behind the panel in the inside of the freezer.
  • I am including a picture and a link, it should be #21 on the diagram.
  • You have to unscrew the Knob and the 3 screws holding the temperature control Cover and the one holding the probe/sensor (#24 on diagram)
Best of Luck,
JP
http www searspartsdirect com model part FFU14K0DW0 1428 0142000 R0405108...
Jul 08, 2015 | Frigidaire 14.1 cu. ft. Upright Freezer...
Ice buildup in bottom of freezer--puddle of water on floor
this sounds like your freezer is operating properly, except that the drainage of the water when going through the defrosting mode is not draining properly, pooling on the bottom of the freezer and then freezing. Check the drainage hose for the defrost in the lower pan. I would remove everything, place in ice chest, let the unit completely thaw out and then inspect. I hope this is beneficial.
Aug 05, 2009 | Freezers
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
How tro restart my digital freezer?
Can you hear the compressor start? If not try the extreme freeze button. Check the condenser is clean and fan working ok.
Jul 24, 2012 | Frigidaire Freezers
Samsung RSA1WTMH i just blew my fusebox and my fridge freezer just flashing 1 led light
hope the following helps you, I had a similar problem with my RSH1 and it took me a few hours searching online before I found the following.
"Hi, I have it on good authority that this is the system check for Samsungs (RS21, SRS20, etc) during normal operation, is to hold the top two buttons down, just until display flashes - this will reset the electronics.
Secondly, if the top two buttons are held down for longer (8 seconds) the display goes blank and will show any error messages in the form of DASHES
I have experimented with unplugging air or frost probes - and the error code you get -on a blank screen is different parts of the last digit lighting up.
Example: when i disconnect the fridge air-probe, shut both doors, hold down top buttons around display - The SIDE of the last "8" digit lights up ! ...strange but true.
But, I need to know what it means when the BOTTOM of the "8" digit lights up"
I am still trying to find a list of the error codes the lines refer to but so far my unit is working fine.
Angus
Sep 21, 2010 | Freezers
Frozen drain line from top freezer to drip pan
Hi, Remove everything in the freezer. Get as much ice out as possible with out using sharp object. You will need to remove the rear evaporator panel inside the freezer and locate the drain hole below the evaporator. The safest way is to use a hair dryer. Once you can get to the drain hole and get the ice down inside the drain thawed (a few glasses of hot water usually gets the job done) Try and run a wire (I use a hose or biasting seringe) and get that drain hole flushed out real good. Sometimes it takes 45 minutes or so. After that is cleaned out, put the rear panel back on and you should be all set.
I hope I have helped you. Please let me know if I can be of more assistance.
Thanks
Vic
May 12, 2009 | Freezers
Defrosting???
your food should not thaw in a frost free freezer. but I can not tell you why it is thawing, sorry.
Apr 25, 2008 | Frigidaire 13.7 cu. ft. Upright Freezer...
GIBSON DEEP FREEZE IS RUNNING BUT EVERYTHING IS THAWING OUT
Might try unplugging for a few hours and then plug it back in. There is a possibility that it slugged the compressor and there is a restriction in the line. Sometimes when the compressor fails to stop running in cold air the liquid gets back to the compressor. It can cause a bit of gunk to be picked up out of the oil and carried to the expansion line and plug up the line. Maybe turning it off will let the plug fall free and not replug the line. Worth a try anyway.....
Feb 07, 2008 | Freezers
Delfield Freezer 6151XLSR Stainless steel Logo
70 people viewed this question
Top Delfield Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Delfield Freezer Expert? Answer questions, earn points and help others
