Question about Denso BHT-8044D
My Fi-6130z won't stop. It keeps trying to scan after all items have been scanned?
It is not a flatbed.
Copy goes through scanner but comes out blank on screen. I know it's being inserted correctly (not backwards).
I'm a 99% sure that you've got some hardware problem with your scanner, probably some internal sensor it has is failing. Just as a test, you should install this scanner on another computer - ask a friend for help - test it and if failure persists you have two options: Live with the failure until it goes worst and stops scanning at all or you take it now to repair.
On the other hand, if it works ok on another computer, try to uninstall it completely and reinstall it.
Dec 22, 2014 | Fujitsu fi-6130z - Document scanner -...
Fi-6130z continueously scans. It doesn recognize when there is no paper to be scanned
Your scanner went crazy. If you don't want to take it to repair, just disconnet it after you've finised scanning
Oct 09, 2014 | Fujitsu fi-6130z - Document scanner -...
My fujitsue fi-6130 stopped automatically scanning both sides
You can try a 'hard reboot' of the unit by unplugging it while it is running, wait a minute or so and then restore the power.
With most electronics this forces a 'self-diagnostic' program which might fix the problem. Another option is to delete and them reinstall the software with a disc or online. Make certain that you have your machine set to automatically check for updates if it is connected to the Internet.
Jul 22, 2014 | Fujitsu fi-6130 Flatbed Scanner
Fujitsu Fi-6130Z is pausing after each page scans. How can we stop this so it is a continuous scan!
The command to scan comes from the host computer when it has recieved the previos scan and is done processing the data such as descew and borders. Faster host computer and or faster network if you are saving to a server. If the first few scans are fast then slows down then this is it. More ram in host will sometimes help.
Feb 12, 2014 | Fujitsu Fi6130z Sheetfed Scanner
After scanning several pages, I don't know how to save it as one file.
After you scan the first page, click on add another page or add more, or ahatever your particular program asks for to add another page. When you save as, the pages will all be in one document. If you scan each page, individually as a separate document, they will be just that, separate documents.
Jan 17, 2013 | Fujitsu fi-6130z - Document scanner -...
Fi-6130z ScandAll Pro won't close
You probably have Roboform as well.
Launch Roboform. It will open in Internet Explorer. Open the settings option.Under the default proflie window select 'applications integration', then uncheck 'automatically attach to Windows applications'. Reboot your system. The program should now close after scans.
Aug 26, 2012 | Fujitsu fi-6130z - Document scanner -...
Blank Pages
The scanner's paper sensor may be jammed. IT is sensint there is paper and hence scanning!. Try and fix it. Sensor may be optical or mechanical. If optical remove shreds of paper or dust. If mechanical ensure it moves forward and backward.
S. Mohan. Chennai
May 09, 2008 | Fujitsu fi-5750C Flatbed Scanner
Fi 5750c adf will not initialise
Just something simple to try...check your software setting to see if it is set for ADF or Flatbed feeding. You said the light bar moves when power is interupted or the adf opened. But you never said if it is scanning in Flatbed mode. If the Flatbed scans, then check the software setting. Most of the flatbed/adf hybrid scanners start up defaulted to flatbed, so when you try to scan, the adf won't pull anything thru until you change to ADF mode.
Mar 13, 2008 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi-4750C Flatbed Scanner
1.st step remove the software from the computer and then reboot. 2nd step install the software. 3rd step try a scan. Still in trouble? 4th step new scanner These items are not repairable.
Jul 01, 2007 | Fujitsu fi-4750C Flatbed Scanner
Denso BHT-8044D Logo
21 people viewed this question
Top Denso Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Denso Office Equipment and Supply Expert? Answer questions, earn points and help others
