Question about Sta Rite 333 Btu Natural Gas Heater Maxetherm Sr333na
What does E06 mean on my sta-rite heater
333NA
  • steve macdonald Mar 18, 2014
    It doesn't say this anymore, but sometimes the red 'service heater' light comes on. I already replaced the Thermistor and the Thermal Regulator. Sometimes it will fire up but then it goes off after 5 mins or so....not sure why.
    Top Expert:
  • Sta Rite Master
  • 5,706 Answers
Check gas pressure
Posted on Oct 11, 2017
SOURCE: Sta-Rite SR400 heater displays error E01 and doesn't fire.
Resolved - the thermister was bad.
Posted on Jan 02, 2009
PartsCenter
  • 125 Answers
SOURCE: sta-rite heater Display shows 125 degrees, won't activate heater
sounds like the temp sensor is bad. Sta-rite Heater
Posted on Feb 26, 2009
  • 83 Answers
SOURCE: sta-rite gas heater won't ignite
I am not sure if either of these issues have been solved, but with the AGS light on, you will need to check the flow of water first. If it is below what is needed for the heater, this will light up. If the water flow is fine, then check the water temp on the display panel. If it is readin higher than that of the ACTUAL pool water temp, you need to replace the Thermister.
If the water temp displayed is about that of the pool water, then the Automatic Gas Shutoff will be the next thing to check and replace.
You can tell IF a Sta-Rite heater has been converted by the model number. The Convesion Kit is supposed to come with a sticker stating that the heater has been converted, but there are two options for the kit and the one without the sticker is cheaper.
If you take off the top two halves of the heater, on the Junction Box there should be a Tri-fold card there. Unfold it, if the model number ends with NA it is a Natural Gas Heater, LP would be Propane.
Posted on Jul 10, 2009
  • 83 Answers
SOURCE: Sta-rite heater error code 126
The 126 is not an error code, but it maybe the temp of the water that the heater is reading. If the heater thinks the water is 126 degrees, it will not start at all.
If the heater is reading the wrong water temp, the problem is the Thermister, which is the sensor that is suppose to read the water temp. You will need to replace this sensor in order to correct the problem with the heater. It is really easy to do!
If you have a manual for the heater, if you go to the Replacement Parts Listing for the Electrical System, page 53 in the online version, the Thermistor is Item #9. It goes into the left side of the manifold in the to place, between the first two manifold bolts.
  • 83 Answers
SOURCE: sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Posted on Jul 14, 2009
R3 code and e06 what are thes codes
R3 should be a software code on the board.
E06 is Temp Sensor but check the wires and the connections. Also remove and inspect the sensor, it may be damaged.
Jun 18, 2014 | Sta Rite SR400NA Max E Therm Pool Spa...
E05 code
e05 error code means shorted stack flu switch or sensor. oder heaters have the switch, newer heaters have the sensor. make sure you know which one you have before ordering a replacement.
Apr 01, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Heater displays error code E06 - what does this mean? Is it something I can address myself or do i need a service tech to address?
Thank you for posting your question here on Fixya.com.
Page 43 of your manual, found here suggests both E05 and E06 errors mean the issue is related to "...(the) fuel supply, thermal regulator, check for correct orifices, etc...". It also touches on the possibility that if the unit was converted from NG to PP or vice-versa that the orifices are not correct.
Start with these two areas...if you need additional assistance please comment to this answer with details from what you find while checking these areas and I'll try and help you from there.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Apr 22, 2011 | Sta Rite 333 Btu Natural Gas Heater...
How can i get a Manual of Sta-Rite Hi - Rate Sand Filter system ??? Model- D 64347
Sta-Rite is owner by Pentair; their manuals are available here. Sand filters are towards the bottom of the page.
John
Nov 24, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
What does R* mean
Where is this "R" if it is the one in the model SR400LP That is Rite, SR Sta-Rite, 400 is btu's in thousands, LP is liquid petrouliem or propane.
Jun 24, 2010 | Sta Rite SR400LP Max E Therm Pool Spa...
Sta-rite pool heater won't fire...
www.cheappoolproducts.com/.../Max-E-Therm-manual.pdf - United States
https://www.gpspool.com/.../Sta-Rite/Tech%20-STA-%20Servicing%20the%20Heater%20Control%20Board%20%u2013...
Those manual should sort you out.
May 29, 2010 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Sta rite 400na gives error code 05 after about 30 seconds
Jun 14, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Heater won't maintain program high temperature
Not sure which one is correct but here is a link to the Pentair/sta-rite site so you can get the information.
Sta-rite Heaters
Feb 22, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Sta Rite 333 Btu Natural Gas Heater Maxetherm Sr333na Logo
228 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
