Question about Omega Rear Drive Wheel Snapper Mowers
Need to know how to adjust the rubber drive wheel on a rear engine snapper. Any help will be great. Thank you
  • 376 Answers
Usually just replacing the drive wheel will fix the problem. There are two allen head set screws on the disc mounted on the engine shaft visable through the hole in the rear of the mower. However, don't expect when you loosen them that the disc will move up or down freely. I've only ever move one by taking the engine off. I'd try replacing the rubber drive wheel first.
Posted on Jun 14, 2009
  • David Lindy Nov 13, 2012
    Hi, I'm from across the pond an Englishman living now in France. Had a similar prob with getting any speed in 1st gear on my snapper. I replaced the wheel but still had low speed and poss slip and loss of drive going up hill. I cured the prob by loosening the 2 bolts that secure the notched selection plate on the right side of the mower and moved just a small amount forwards. This made the rubber wheel engage a little bit further onto the drive plate. Don't go too far otherwise 5th gear could go off the outside edge of the drive plate. Blooming marvellous now
    Problem Solver:
  • 4 Answers
There is no ajustment the spring holds the tension
Posted on Oct 25, 2011
Replace friction wheel Snapper 3317523BVE (7800254) - Snapper 33" Rear-Engine Rider
Warren, Could not find your particular model, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HowTo Replace Your Disc Drive Friction Disc Wheel
Riding Lawnmower doesn go foward Drive Disc Replacement
snapper clutch repair for beginers friction disc
Snapper Friction Drive Modification
May 13, 2016 | Snapper Garden
Snapper rear riding mower won't move while in gear
yes your looking at the problem easy to change close the vent on the fuel cap remove the battery and lift it up and stand it on the rear bumper tubes (thats what there there for) after replacing you might need to move the links for the cable up near the pedal
Jul 11, 2012 | Garden
Need to adjust rubber drive clutch on 30 inch snapper mower
there are small metal beads on the cable near the pedal you move to the other side of the pedal if the friction wheel is warn you will need to replace it only 3 nuts hold it on just flip the mower up on the rear bar and take it off no fancy tools needed
Jun 28, 2012 | Briggs & Stratton Snapper 5900748 355Z...
Snapper rear engine mower wont go forward or reverse
the drive system on that mower is a rubber friction wheel after time the rubber become brittle and falls apart and also wears it you tighten the vent on the fuel cap and stand it up on the rear bars you can see it it rides on a alum wheel held in by 3 or 4 bolts easy to change if it has electric start you need to remove the battery if you leave it up on it back for more the 30min
Jun 13, 2012 | Garden
I have an older Snapper lawn mower that just stopped moving while I was mowing grass. I have put a new drive plate on it (the one that has the rubber around), but that didn't help it. When I stand the...
your trans axel has striped out in side you will need to get that in to the shop let me know if this helps you or if you need to find a shop
Oct 04, 2009 | Garden
I own a Snapper riding mower, hydrostat drive, 14.5 Hp, 38 cut. Reverse speed has suddenly been reduced to a crawl. Could it be the brakes need adjusting or is the engine/transmission shot?
could be a linkage came loose, or that the fluid level in trans is low, has nothing to do with engine but the hydros are prone to failure, also the hydro is driven by a vbelt which can stretch and mimic a trans problem
Sep 30, 2009 | Omega Rear Drive Wheel Snapper Mowers
Snapper comet rubber drive
Get a new drive wheel.
Put mower in neutral.
Stand mower on rear supports.
Remove the four bolts holding the old wheel.
install new wheel.
Jun 15, 2009 | Garden
Omega Rear Drive Wheel Snapper Mowers Logo
2,133 people viewed this question
Top Omega Garden Experts
Rodney Carroll
Level 1 Expert
randy yarpos
randy yarpos
Al Schrader
Al Schrader
Are you an Omega Garden Expert? Answer questions, earn points and help others
