Question about Conair HC318RV Cord/Cordless
Fell apart when I dropped it
Nose cone fell off and now can't put back together, no parts are broken
2 Suggested Answers
SOURCE: fell apart..help please!!!
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Posted on Jul 09, 2008
PS3 r2 button fell off
You'll have to take it apart there a screws in it the problem is they are tri heads they look like a Y you need to get that screwdriver look online you can find them once you have one its a simple fix just take out the screws and gentle take the controller apart at the seams put the pad back in it appropriate spot and put it back together. a simple fix if you have the screwdriver to do it with keep this in a nice spot cause all game consuls are put together this way its to keep you from breaking the warranty.
Apr 13, 2014 | Sony Playstation 3 (PS3) Console
How does the hansgrohe hand held shower head md # 17850831 snaps together
The 17850 is not designed to be taken apart and put back together. They are pressed together in the factory. If it was dropped and came apart it is most likely broken beyond repair. If you need further help fell free to contact Hansgrohe Tech 1-800-334-0455.
Dec 08, 2012 | Hansgrohe Carlton 17850831 Polished Nickel...
Can some tell me if they have a picture of the inside on the switch my fell apart need put back together?
If you click HERE you will be taken to a web page of part numbers and the exploded view diagram's of the area of the washer the parts is located in.
Dec 15, 2011 | Roper RAS8445KQ Top Load Washer
Bought a KB classics build & load track set. The small car fell apart when I thought I was putting in the battery. Instead when I unscrewed the car, the small motor just fell apart. There are...
i have the same exact problem, tried to put the gears back together myself and couldn't figure it out. i tried to see if i could just order another car car but no luck with that either. please let me know, as well
Jan 01, 2011 | Toys
My son dropped it
pick all the part carefully try and fix it or take it where phones are been repair they will fix it 4u
Apr 07, 2010 | Pantech Matrix Cell Phone
WE HAVE A HEATER THAT HAS STRONG FUMES WHEN RUNNING. THE COILED FOAM FILTER IN THE BACK FELL APART. DOES THIS HAVE ANYTHING TO DO WITH IT?
It sounds like you need to increase the air mixture. there is an adjustment screw in the back next to the foam filter (which you can get a new one at Ace Hardware). Dial the screw in 1/4 turn at a time until the nose cone turns about 90% red/orange and you should notice a great reduction in the fumes and a greater heat output.
Jan 07, 2010 | Reddy R70ET Utility Heater
Garmin Charger fell apart
Yes. Call Garmin up and tell them the pieces came off they will send you free pieces (covered under warranty) just tell them that you know how to put it back together and you can see images online of how it should loo kafter it's put back
Jul 14, 2009 | Garmin nuvi 205 GPS Receiver
Broken psp
well..
i think since you've dropped..
it..
&& it came apart..
it probably..
doesn't work anymore..
no matter how you've put it back together..
its not going to work again.
sorry =[
Jul 26, 2008 | Sony PlayStation Portable (PSP) Console
Conair HC318RV Cord/Cordless Logo
611 people viewed this question
Top Conair Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Conair Electrical Supply Expert? Answer questions, earn points and help others
