Question about Maytag 15 Cu. Ft. Top Mount Refrigerator
Loud vibration from compressor, but still cooling
Ever since I moved in, the compressor has made a loud clunk when turning off. Returning home after a 3 week trip, I found that the compressor now makes a loud vibrating sound when running. It also seems to be running more often, although the freezer and refrigerator compartments are still cold. The repair guy just listened and said the compressor is going out, no way to know when it will quit. I am willing to buy a replacement, but wondered if it's possible that there is a simple mechanical problem, say a loose bolt or some such. I am fairly handy, although I don't know anything about refrigerators specifically, so if there is something I can check, I will. Thanks for any advice!
  • Karen Lewotsky
    Karen Lewotsky Mar 18, 2014
    Sorry, this is in reference to a kenmore top-freezer refrigerator, model # 619891000. Don't know why it is listed as a Maytag.
I would check for loose bolts some where if the ref is get cold and the freeze
Posted on Mar 18, 2014
Loud grinding/clunking noise when driving, lessens when I press the brake
Loud Noise Unknown Origin - Ask the GM Technician - GM-Trucks.com
www.gm-trucks.com > ... > Ask the GM Technician
Jun 30, 2006 - 7 posts - ‎3 authors
I get a loud clunking, grinding noise while turning to the right only, and ... I moved the passenger side tire to the rear driver side just in case it ...
can bad wheel bearing/hub cause loud clunking noises?
www.jeepsunlimited.com/.../showthread.php?...loud-clunking-noises
Nov 12, 2009 - 14 posts - ‎6 authors
driving home, i noticed some metal clunking sounds coming from the front driversside. at ... hmmmm....if it's grinding, then probably a bearing.
Front Clunking sound when driving straight. - TDIClub Forums
forums.tdiclub.com > ... > VW MKIII-A3/B4 TDIs
Dec 21, 2011 - I have a sporadic clunking noise from the drivers side front end. '98 jetta ... If I try to coast it gets really louder and more pronounced. ... whirring orgrinding could be several things: wheel bearing, brake pads due to a caliper ...
Quick Guide to Diagnosing Differential & Driveline Noises ...
Dec 26, 2015 | Cars & Trucks
Why does my whirlpool refrigerator makes a very loud clunk noise when it turns off
Try looking for any pipes that are rattling against the cabinet , if not, I'm afraid compressor problem.
May 02, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Compressor motor inside the hermetic container has rubber mountings. If any go, the motor will lean in that direction and the motor will hit the shell when it starts, or turns off.
Compressor motor is not going and the guy is full of it.
U cannot open the case and repair the mounting but the motor and its bearings are good to go for a long time, albeit it might have some noise. U can experiment with tilting the compressor assembly in the direction opposite to the bad mounting - often you can reduce and/or completely eliminate the startup/shutdown noise and running noises..
Mar 22, 2017 | Kenmore Refrigerators
To much bass and vibration
-5 decibels can be quite loud. Either turn down the bass, volume or both. The bass could be vibrating some items on a shelf or any other place. If you continue to play it that loud, you will more than likely, damage the amp.
Dec 19, 2013 | Audio Players & Recorders
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
I have a 1995 24.5 cu. ft. GE Profile refrigerator. When it shuts off there is a loud clunk. I think it could be the compressor turning off. Other than that it seems to be working fine. Is this a serious...
The compressor is sitting on springs inside a metal case. When it stops, the centrifical force is absorbed by these springs. If one or more springs become weak or break, the compressor hits against the outer case a time or two. (CLUNK CLUNK clunk) There is really nothing you can do about it, short of replacing the compressor. (read big bucks) NOTE: If you take a new compressor and give it a shake, you will hear the same clunk. If the noise is really bothering you, I'd say after 15 years, it's time to move that refrig to the basement and get a new energy star model for your kitchen. (the old one most likely has several more years worth of clunking before it truely dies)
Sep 25, 2010 | GE Refrigerators
Very LOUD banging noise from front left wheel
the right outer tierodending needs replaced.
Apr 03, 2010 | 2001 Chevrolet Impala
Makes a loud clunk every now and again. It
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Sep 04, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Kenmore top freezer, Refrierator shuts off with loud clunk.
It sounds like you may have a compressor that is working hard against high pressure due to a dirty condenser or a condenser fan not running or blocked. If all is well otherwise, the mounting springs inside the compressor may have broken or are weak. The only fix then is a new compressor.
Jun 22, 2009 | Kenmore 64802 Top Freezer Refrigerator
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Refrigerators Logo
46 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
