Will not work with my manual transmission. Intermittently, but I am not doing anything different.
Not 100 percent sure, but sounds like the neutral switch connection is not working properly. Python can and is used on lots of standard vehichles, but they tie into the nuetral switch on the transmission. If this switch or the wires are corroded or loose, this is the problem that usually shoes up. Hope this helps
SOURCE: i have a python sst car alarm
usually a combination of 2 buttons so the car doesnt start accidentally.
Depending on the number of output channels - the installer could have installed on any of the channels and that would dictate which buttons to press.
if it is not set on the AUX (output 2) button, then try...
You have not given the model # of the unit - so these are viper's STANDARD remote controm configurations.
CLICK HERE to enter your correct model # and Download your instruction manual.
Hope this helps.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
SOURCE: I need to pair my
CLICK HERE for your owners manual.
CLICK HERE for replacement remotes.
Find your remote - and click on it.
There will be an option to view the manual for the remote.
Programming instructions are there
SOURCE: Viper 5101 Manual Transmission - can't start
First off, is it in neutral? It can't engage the starter motor if it's in gear. Secondly, If it was professionally installed, why not just take it back and demand that they fix it?
Your wiring should somewhat match this.
SOURCE: how do you turn on a python 991 2 way remote
The remote must first be fully charged. It will then turn on by itself.
SOURCE: Python 1600 XP Remote Starter my
You have the 24 hr timer on and you just have to press the lock and remote start buttons at the same time.
