Question about TechSmith Camtasia Studio for PC
Camasia 8 Recorder won't work on Windows 7
I had to reformat and reload my PC. I then installed the Camtasia 7 that I purchased a couple years ago and then installed the Camtasia 8 that I recently got. However, when I try to run Camtasia Recorder 8 either from the taskbar icon or from the program files, nothing happens. I checked the processes and there is no reference to camtasia there either. I am running Windows 7 Pro with 8 GB Ram and a Quad Core processor. What can I do to get this to work? Thanks in advance Larry
  • Larry Truitt
    Larry Truitt Mar 19, 2014
    LI updated to 8.3 and the recorder works now. Thanks for the help!!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Delete 7 and 8 but then only reinstall 8 and see if that works because they might be screwing with each other.
Posted on Mar 18, 2014
  • 7 more comments
  • Bryan Perry Mar 18, 2014
    make sure you delete all the files because even after using the uninstall it can leave extra folders and files
    if this does not solve it tell me
  • Larry Truitt
    I used revouninstaller to uninstall both Camtasia 7 and Camtasia 8 and then reinstalled Camtasia 8 by itself.
  • Larry Truitt
    Unfortunately, that didn't fix the problem.
  • Larry Truitt
    I can access the studio, but I can't get the recorder to work either from the shortcut or by clicking on record the screen in the studio setup.
  • Bryan Perry Mar 19, 2014
    so u can open up the studio but the only thing not working is the recorder
    try to find the the application for the recorder like the program u would click to open up just the recorder not the shortcut and dont try to open it from studio just find out where it is on your computer and try to open it also if that dosnt work try to run it as administrator if that dosnt work tell me this is helping narrow down the possibilities.
    also before u try all of what i said above enless you have already the proscess for the recorder would be camrecorder.exe so check your processes for that because you may have not noticed it is the recorder because it does not say camtasia anywhere so check your processes tab for that
  • Bryan Perry Mar 20, 2014
    Well that was the last thin I was going to suggest because usually it auto updates but no problem :)
3 Suggested Answers
SOURCE: Camtasia Preview Windows is blank
http://www.associatedcontent.com/video/22854/camtasia_troubleshooting_the_preview.html
Posted on Apr 16, 2008
SOURCE: Memory Problems
The clip can be recovered if you open the temporary directory where Camtasia stores the raw captures in AVI format. The path to the temporary directory can be found by opening the Camtasia Recorder > Tools > Options > Program > Temporary file folder (I'm using v.5 so it may be a little different in other versions).
I've found that there's a certain workflow that seems to work best and you can avoid accidentally erasing your temporary files and having to start your capture session over from the beginning...
  1. Stop Camtasia Recorder - Pressing the Stop button on the Recorder likely won't work, so open the Task Manager (CTRL+ALT+DELETE) and select "CamRecorder.exe" from the Processes tab and click "End Process". Don't open Camtasia Studio right away after doing this step - You'll likely be prompted to recover the recording and in my experience Camtasia hasn't done a very good job at being able to do this successfully and you may end up losing your temp files.
  2. Recover your raw capture files - Navigate to the path where Camtasia stores its Temp files (look above for instructions). Typically, there will be a folder titled "CamCapture{random string of numbers/letters}" - look for a folder with a date modified attribute of the date/time you were working on your project. In that folder, there will likely be several audio and video files as well as an XML data file. The video files will all be 1GB apiece as Camtasia splits the capture into chunks and then pieces them back together to create one continuous file. Cut and paste the files from this folder into a new location outside of the Temp directory. The most important one is the FileWriter{random string}.avi as this is the pieced together file - It will have the largest file size.
  3. Add your media files to the clip bin/timeline - Start a new Camtasia project and import the FileWriter{xxx}.avi clip into the Clip Bin and drag it onto the timeline. Now all of your video/audio should be recovered and available for you to edit. If you have particularly long clips, you may want to check how the audio syncs with the the video towards the end of the clip. If it's messed up at all, you may want to try adding the smaller, chunked recording segments sequentially onto the timeline to see if that helps. If the FileWrite{xxx}.avi clip is good though, you can delete all of the other smaller audio and video clips associated with the capture from your pc to save space - just keep the FileWriter{xxx}.avi clip - the XML can be deleted too.
Good luck - We've had the same trouble here and we use Camtasia almost everyday. In my experience, this seems to happen more frequently when we capture larger dimensions - especially if the capture contains full motion video (as opposed to just screen captures of a product demo or something) and we always seem to have trouble when capturing things that play back FLV or SWF clips at a higher bitrate. This issue is also described in TechSmith's Camtasia knowledge base.
Posted on Sep 18, 2009
Is there a download or disc I can get to use one of these computers to work with "your product"?
Support for Windows XP ceased a couple of years ago. Only Windows 7, 8 and 10 are supported.
It is very unlikely that a computer running XP will run Windows 10. It may run 7, albeit slowly.
You refer to 'your product'? We are Fixya, not Microsoft or any other software vendor.
Mar 09, 2016 | Computers & Internet
The Toshiba user's guide and support app on windows 8 start screen is not working. it says critical error
Windows 8 sucks. Have had so many issues with it myself. Sounds like the load may be corrupted, the easy is call Toshiba tech support, the hard is reformat the hardrive and reload windows but I would suggest Windows 7 over 8 any day.
Sep 23, 2014 | Toshiba Satellite Computers & Internet
Compaq tc4400 suddenly turned into non tablet pc (pen & touch gone)
http://www8.hp.com/us/en/support-search.html?tab=1#/qryterm=compaq%20tc4400&searchtype=s-002
this is where your find the moel drivers for tablet , there are two available , so please read before installing.
Nov 27, 2013 | Compaq tc4400 Tablet PC
Always booting but unable to load untill iremove the battery to get it off
That means your operating system in unstable. First of all you need to identify what operating system you are using for example Windows 7 or 8 or XP. Then Get a CD for that operating system. Boot from the Operating system CD and select Repair so that the machine can be repaired. During the repair process your machine will restart a couple of times so do not freak out it will be okay. But if it does not work after repair, then you will have to consider what we call wipe and reload. In wipe and reload, we only save all your data and reformat and reconfigure your computer to its factory settings
Nov 21, 2013 | Computers & Internet
Camtasia Studio 8 Only Opens Once per Start-up
what u need to do is if you have windows press ctrl shift esc and the task manager should pop up go to processes then on the list you would see Camtasia studio right click and select end process or if u see the name more than once end the process of them all the reason you have to do this is because for some reason the first time you open and close it it dos not actually completely close witch then gets in a glitchy state to where you can not open in again but by ending the process u should be able to open it again
Jun 17, 2013 | TechSmith Camtasia Studio for PC
Aspire 5532 won't load windows 8
Hello you can test here:
http://windows.microsoft.com/en-US/windows-8/upgrade-to-windows-8
If the pc is compatible to run windows 8.
If it fails, the pc is not capeable to run windows 8.
Here is no drivers for windows 8, at the support site:
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=1290
The solution is to continue useing windows 7, or buy a new pc with windows 8 installed.
Good luck
Feb 09, 2013 | Acer Aspire 5532-5535 AMD Motherboard...
Have a w-10 olympus voice recorder, will not work on windows 7, olympus states can't help. Now what?
Yes, sorry; this is a basic model released about 8 years ago when Win 98, 95 etc was still in use.....Microsoft don't support 98,95 etc anymore...youv'e gone to the newest Win7 OS so unfortunately you will have to get a newer recorder.....in 8~10 years time you may have to do it all again....such is technology...ain't it a great world.
Aug 26, 2010 | Olympus W-10 Digital Voice Recorder
TechSmith Camtasia Studio for PC Logo
95 people viewed this question
Top TechSmith Computers & Internet Experts
David Payne
David Payne
Are you a TechSmith Computer and Internet Expert? Answer questions, earn points and help others
