Question about Apple iPhone Smartphone
Back battery remove
Need to figure out what model
    New Friend:
Apple batteries are not removable by the user only a technician who has to take it apart. Steve jobs wanted an elegant seamless design
Posted on Mar 21, 2014
  • John Bell
    John Bell Mar 21, 2014
  • John Bell
Install sim card
typically the SIM card slot is located under the battery. you would remove the back cover, then remove the battery. you should see place to insert the SIM card. it is usually identified by looking for a metal square about 3/4" H x 1/2" W and the plastic where the SIM card is inserted has an 'engraved' image of a SIM card and the correct orientation. without knowing the exact model, it is difficult to give exact information. another resource is to do a google or youtube search asking the question you posted along with the phone model number. hope this helps!
Mar 29, 2014 | Samsung Galaxy Cell Phones
Iphone4, how to open battery
Make sure you turn your phone off before you remove the battery. There is 2 torx head screws, 1 on either side of the charger socket on the end of your phone. Remove these, you then slide the back cover up slightly to remove the back cover. You then have to remove 1 phillips screw which holds the battery connector, be careful as there is a small metal guard under the battery connector which could fall out without you noticing. You then prise the battery connector up with something plastic to avoid shorting out the battery. The obvious sign that your battery needs replacing is when the battery status goes down to 12 or 10 percent and the battery dies before getting down to single figures.
Dec 31, 2013 | Apple iPhone Smartphone
Need a charger for model number kt1085wm mongoose raider quad
I have 6v chargers with alligator clips on the end that work, you'll just have to remove the plastic battery cover (6 screws) so that you can clip it onto the battery
Jan 06, 2013 | Mongoose Raider Quad Ride-on Bike
We just bought a 9053 for our grandson. We seem to only have room for 4 batteries. Where do the other 2 go?
The 9053 hand controller actually holds 8 batteries you need to remove the back cover then remove the battery holder and place 4 batteries in each side.
Kind regards, Julian.
rccontrolfreak.co.uk
Sep 02, 2011 | Axial Syma 9086 Helicopter
I have omnia i910 samsung the screen froze and do noting
Try removing the battery from the back of the phone by removing the back cover. There should be some kind of button or latch on the back of your phone to push to release the back cover. Remove the battery and that will shutdown your phone. Put the battery back in, close the back casing, and restart your phone and everything should function normally. If you can't figure out how to remove the back case, just let the phone's battery run down and you should be able to restart it then also.
Mar 05, 2011 | Cell Phones
How do I change the battery in a logitech wireless battery. I can't seem to figure out how to open it to even see what kind of battery is needed.
For changing the batteries of logitech wireless.I guess a video tutorial will help you out rather than written instructions. Watch it to lean how to replace battery of the logitech cordless mouse ( Logitech MX 1000 Model). If you are having a different model please specify the details of your model.
Mar 02, 2011 | Logitech Cordless Mouse
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
Casio module 2273 battery change
did u ever figure out how to get the retaining clip?
Mar 13, 2010 | Casio PRG-40T-7 Pathfinder
Cant figure out how to open back of phone to put in new battery
First: you need to simply remove the back; then after you remove the back the battery will be there. If it wasnt removed simply remove the battery from the back of the phone without it getting wet. There might be some slight difculty doing this. What you have to do is ; slam the back of you're phone; on you're thigh if you have anyproblems. also place the sim card in behind the battery u will find the sim card slot; . Then place it in the slot facing up wards.
Thank You; :-* Hope it works!
May 02, 2009 | T-Mobile Sidekick II
Need to replace battery
OK it took some effort but I pulled the back off and there was the battery! Duh... thansk anyway.
Aug 19, 2008 | SanDisk Sansa e260 MP3 Player
Apple iPhone Smartphone Logo
37 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
