Question about Genius NETSCROLL G500 Laser Mouse
Laser is not working properly?
The laser is not pulsing anymore !
Kodak W730 Pulse is not finding any wireless networks
I'm having the same problem so I'm trying to re register it but need the activation cade since I don't have the box anymore and it won't come up on screen
Nov 16, 2013 | Kodak W730 PULSE Digital Frame
What is Laser Hair Removal?
Laser hair removal is a procedure by which hair is removed from the body by utilizing a long pulse laser. Lasers are developed and designed from years of research. The laser parameters are carefully defined by studying the anatomy of the hair follicle and precisely matching the laser light and pulse duration to the follicle size, depth and location to inhibit the re-growth of the hair.
Laser hair removal is performed by a specially-trained laser specialist or a doctor depending on where you go, who distributes the light of a long pulse laser onto the skin. The laser works by disabling hairs that are in their active growth cycle at the time of treatment. Since other hairs will enter their growth cycle at different times, several treatments are necessary to disable all of the follicles in a given area.
Nov 23, 2010 | Health & Beauty
Can't find switch on phone or base to go from Tone to Pulse. Nothing in Manual. How do I do it? Thanks.
From what I understand the unit does not have Pulse capability. Most phones do not anymore.
Aug 10, 2010 | Vtech Cordless 6041 Phone
Lack of spark and injector pulse on audi 80 have replaced coil pack distributor and crank sensor still no joy
lack of injector pulse? perhaps there is a controller problem..like a pcm or something....without anymore information, i can't tell you anything else.
Nov 19, 2009 | 1988 Audi 80
I was told my Toyostove Laser 72 stove needs to be cleaned. Can i do this myself and what do I do.
I would recomend having a qualified technican service your Toyo.
It IS possible to clean it yourself, but you will want to do it during a time that you aren't needing the heater to keep the space warm.
Certain parts can be hard to tell if they are working as they should if you aren't familar with what you're looking at.
With proper service, your Toyo will operate efficently, and likely last for a long time.
_Helping Hands Services_
- Fairbanks, Alaska -
Oct 05, 2009 | Rinnai Toyostove Direct Vent Heater:...
Dispaly cannot read disk
DONT FORGET TO RATE SOLUTION
1. CLEAN THE LASER. ALWAYS DO THIS FIRST. MOST TIMES THIS IS ALL YOU NEED TO GET YOUR SYSTEM BACK RUNNING A 100% AGAIN
2. IF THE LASER CLEANING DON'T WORK ON YOUR PS2 SYSTEM PERFORMANCE THEN TRY ADJUSTING THE LASER VOTAGE.
3. IF THE LASER VOTAGE DON'T WORK YOU NEED TO REPLACE THE LASER
Nov 18, 2008 | Sony PlayStation 2 Slimline Console
1988 Chev c1500 wiper motor pulse board
well if you replace the whole wiper motor and get the lifetime warranty you wont have to worry about it anymore because if it goes out again you just get another motor sure its a little more hard work then a pulse module but you don't have to worry that the motor will go out. just a recommendation.
Jun 13, 2008 | 1988 Chevrolet K1500
Dvd player not working
If the disc isn't spinning, and you have cleaned the lens (using a proper method) then it is likely that the laser has failed. The disc usually won't spin until the laser has sent/recieved a pulse from the surface of the disc. A new laser is usually about the cost of a new player.
Sep 10, 2007 | Toshiba SD-4900 DVD Player
Yardage pro 1000
Has laser been cleaned properly?
Aug 26, 2007 | Bushnell Yardage Pro 1000 Rangefinder
Genius NETSCROLL G500 Laser Mouse Logo
24 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
