Question about Toro 1800 Power Curve - 38381
Machine will not start when handle engaged. Power source is good. What is wrong ?
My power source and cord are good. When I engage at handle the machine will not run. The key is in, proper power, and last time used it operated properly. What is wrong ?
5 Suggested Answers
  • 133 Answers
SOURCE: toro self propelled will not move wheels. Checked engaging keys
Remove the front wheels and see if the cogs that are molded into the wheels are stripped. If they are stripped out that could be where the noise is comming from.
Good Luck let me know if this helps.
roundo4
Posted on Aug 14, 2009
  • 85 Answers
SOURCE: The transmission will not engage
If the unit is between1998 & 2004 , the gears in the transmission may be stripped.To tell for sure, remove belt cover, start the unit & engage the drive. If the pulley turns & not the axel, the gears are stripped.
Posted on Aug 16, 2009
harlan301
  • 205 Answers
SOURCE: the front wheel drive will not engage properly
check the front wheel drive pinion. and the gears in the wheel. you may want to check the belt from your trany to the engine. some times thy Ride up the pulley
Posted on Oct 13, 2009
harlan301
  • 205 Answers
SOURCE: Toro Lawn Mower Electric Start Won't Engage
you'll need to pull the starter. It sound like your Bendick's is bad. that's the upper gear drive assay. the only other res ion would be, low power to the starter, and not receiving an acquit amount of amp to reach the rpm's it needs. good luck
Posted on Oct 23, 2009
Testimonial: "Thank you for the advice.... I will check out the Bendix to see if that is the problem. Jim"
Shark Euro Pro 473: The needle won't go up and down when I press the pedal. Power is on, light too and machine running but no action. Any suggestions other than rethreading everything? Thanks!
Is the bobbin winder engaged? The smaller handle inside the balance wheel, the large handle. If the bobbin winder is engaged the thread will only wind around the bobbin and the needle does not move.
May 29, 2015 | Sewing Machines
No power to light on start button
Handle not engaged all of the way. Press down and engage. it works.
Jul 13, 2012 | Keurig B60 Coffee Maker
I have a Troy Bilt Weedeater Model # TB415CS Here is the problem my wife decided to use this unit while I was at work one day and broke it. When I go throught the start up routine and go to pull the start...
If the rope recoils back into the starter, at least the starter spring is not broken...but...if you can break the unit down to where you can get a good look at it, you may find that the ratchets on the starter pulley are not engaging with the pawls on the flywheel...The pawls are spring loaded so they engage and then drop out of the way when starting, See if you can break the machine down to that point and post back,
Aug 06, 2010 | Troy Garden
How to remove the inside door panel from a dodge 2005 2500 pick up
FRONT DOOR TRIM PANEL - REMOVAL
Release door latch and open door.
Roll window down.
Remove window crank Window Crank - Typical , if equipped.
Remove screws attaching trim panel to door Door Trim Panel and Trim Panel Screw
CAUTION: Do not forcibly pull trim panel from door, damage to trim panel may occur.
Simultaneously lift upward and outward to release retainer steps from inner door panel Trim Panel Retainer
Disengage inside handle linkage rod from inside handle.
Disconnect speaker harness wire connector Speaker And Power Mirror Connector
Disengage power mirror wire connector, if equipped (driver's side only) Speaker And Power Mirror Connector
Disengage clips attaching power window/lock switch panel to door trim panel. Disengage wire connector from switch panel, if equipped Power Door Lock/Window Connector
Separate door trim panel from vehicle.
INSTALLATION
Position trim panel at door.
Engage wire connector for window/lock switch panel, if equipped. Engage clips attaching power window/lock switch panel to door trim panel.
Engage power mirror wire connector, if equipped.
Connect speaker harness wire connector.
Engage inside handle linkage rod to inside handle.
Align trim panel retainer steps with inner door panel and slide trim panel into place.
Install screws attaching trim panel to door.
Install window crank, if equipped.
Hope helped with this; remember rated this help. Good luck.
Nov 12, 2009 | 2005 Dodge Ram 2500 Truck
Oct 23, 2009 | Toro Lawn Mower With Toro Power Tools
How to trouble shoot starting system 98 ford crown victoria
Also check to see if there is power in the start wire form the ignition switch, the wire is a white wire with pink stripe, most likely not a common problem, but still something that could go wrong. this wire will feed the starter relay under the hood...
Sep 21, 2009 | 1997 Ford Crown Victoria
Difficult to start chipper while gears engaged
The drive belt may be the wrong size if there is no play in the clutch. I have a 10 hp, but there is a common manual for the 10 and 8. My belt is a 4L380.
Jul 12, 2009 | Troy-Bilt Chipper Shredder
Pull Start Locks
Disassemble and, re-engage the pull cord locking pawl spring
May 20, 2009 | Toro Lawn Mower With Toro Power Tools
How do i engage the self propel mode on my lawn mower
Hello:
You Pull the Handle and it will Pull the Cable that Engages the Transmission.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
May 11, 2009 | Toro Lawn Mower With Toro Power Tools
Electrical
PROBLEM: THE KIRBY WILL NOT TURN ON AT ALL
POSSIBLE CAUSES:
Please note......The Kirby has TWO safety switches that need to be engaged before it will operate. One is on the fan case in the front. It is activated by having an attachment attached to the front. (hose, power nozzle, etc.) The other switch is on the side of the Kirby where the cloth bag attaches and is engaged by the little tab that sticks out from the side of the hard plastic cloth bag "boot". The bag boot MUST be completely engaged to activate the safety switch and allow the Kirby to power on. If you are having trouble getting the bag to properly engage, (sometimes they are STUBBORN) simply lubricate the black gasket that the boot fits onto with gasket lubricator, VASELINE, or try a tiny drop of DISHWASHING DETERGENT or HAND CREAM. It doesn't take much, so use the smallest amount possible to get the desired effect. You should hear a slight "pop" when the bag completely engages.
If neither of these things are indicated, it is probably again, either the power cord, switch or the carbon brushes.
If your Kirby is sparking there are a few causes...
PROBABLE CAUSE (MOTOR): Worn out carbon brushes, bad armature or perhaps BOTH
PROBABLE CAUSE (CORD): The cord has a short in it. Replace the power cord
PROBABLE CAUSE (POWER NOZZLE): There is something metallic stuck in the fan or power nozzle
I think you have a problem with the carbon brushes and amature because of where you describe seeing the sparks. I would suggest taking it to an authorized dealer for repair if it is the motor that is going bad.
Apr 01, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Toro 1800 Power Curve - 38381 Logo
121 people viewed this question
Top Toro Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Toro Heavy Machinery Expert? Answer questions, earn points and help others
