Question about Kenmore Dryers
Kenmore 700 series Dryer shuts down after a few minutes in heated cycle, runs forever with no problem in Air Dry (no heat) mode, I disassembled the entire machine drum, motor, vents and removed every spec of dust - no change, I am running with the vent hose disconnected to test it, there is plenty of hot air flowing freely out of the vent, but it still shuts down after a few minutes
  • John Mock Mar 18, 2014
    Hi Brian Best, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Does your dryer have a moisture sensor in the controls?
  • Brian Best
    Brian Best Mar 18, 2014
    Yes - 3 options: timed, moisture sense and air dry
  • Kenmore Master
  • 932 Answers
Brian, look inside your drum for some curved strips of metal that may be 6-8 inches in length. There may be two of them that run parallel to each other about half an inch apart. This is your moisture sensor. If you use dryer sheets like a lot of people do you may have an issue where there is a build up of residue from the dryer sheets on the sensors. Take some rubbing alcohol and some cotton balls or a rag and wipe down the sensor strips. If they come back blue in color there is build up on the strips. Keep wiping down until you no longer get any blue color. That build up can make the dryer think that the clothes are dry and shuts the dryer down. Hope this helps, I have done this on a couple of different dryers and it made a big difference.
Posted on Mar 18, 2014
Testimonial: "John - thanks for your suggestion, we don't use the dryer sheets but your question made me think to try the Moisture Sensor cycle and the dryer ran through the cycle OK. Maybe after I cleaned it and checked the connections it finally shook something loose. When I tested the heated cycle before it only ran a few minutes. Over the last couple days I tried this at least a dozen times, but now in Moisture sense it worked OK. I'll try the heated cycle again and see what happens."
  • Brian Best
    OK, well now it just ran successfully through a 60 minute cycle. I hate to say I fixed it because I don't know for sure. But I guess a god thorough cleaning and checking all the connections made a difference. Thanks again.
SOURCE: Asko T701 Runs for full cycle but does not dry
There are two thermal switches on the duct; 40 and 60 degree. How do I tell which is which?
Posted on Oct 01, 2008
  • 115 Answers
SOURCE: My Frigidaire electric dryer doesn't heat normally.
some of them dryers have 2 elements and one could be out you have too take drum out too check it
Posted on Dec 28, 2008
  • 530 Answers
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
mgprice
  • 744 Answers
SOURCE: Kenmore electric dryer heats but does not dry the
Hi, Here are the obvious parts to check: Heater, High limit, Thermal fuse or thermostats...these are all generally located in the back but some models you access them from front. the most common cause is either heater or thermal fuse, I will include a picture of the thermal fuse. If you test these parts and find they all work you may be looking at a centrifiacal switch problem.
Here is a picture of the thermal fuse check this part first:
http://www.partselect.com/repair.aspx?appliance=dryer&part=replace-thermal-fuse
Please feel free to contact again if you have any other problems.
Hope this helps.
Posted on Jun 24, 2009
protek480
  • 1723 Answers
SOURCE: Kenmore dryer shuts off after five minutes
The vent box inside the dryer still has lint in it. You need to reach way inside to get at it. Turn power off.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 22, 2009
My danby dryer keeps shutting off and turning on and the clothes take forever to dry
GOD IS STILL GOOD !!!!
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Sep 09, 2014 | Danby DCD5505W Electric Dryer
What is wrong with my gas dryer ? no heat and wn't shut off.
FIRST OFF IN THE AUTO DRY MODE THE DRYER USES THE MOISTER SENSOR AND AS LONG AS THE MOISTER SENSOR DOES NOT DETECT HEAT OR DRIED CLOTHES IT WILL CONTINUE TO RUN FOREVER.
NEXT AS FOR UR NO HEAT:
Aug 09, 2014 | Kenmore Dryers
Ge dryer dcvh515efoww runs on air dry, but when set on any heating cycle, it runs for a few minutes and then it turns off on 00
it is over heating you might have unplugged a wire to the thermostat when you had it apart or the thermostat has went out.
Mar 21, 2014 | GE Dryers
My kenmore series 80 model # 110.74852400, takes forever to dry. the flame comes on, but doesn't seem to stay on for long. please help. thank you
my kenmore dryer ignites runs for awhile then wont reheat. let it sit for a few minutes and it will heat again for awhile
Apr 20, 2010 | Kenmore 72802 Gas Dryer
Our kenmore eliite HE4 gas dryer keeps shutting off after a few minutes of running no mattter what heat setting we put it on. On air dry mode it works. Is this a high heat sensor problem? The unit is 4...
You didn't mention if the dryer is getting hot.
If is getting hot, then shutting off, I agree with you.
If it is NOT getting hot, I would suspect the IGNITER ASSY
Dec 13, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Jul 27, 2009 | Dryers
Jul 22, 2009 | Dryers
Kenmore Electric dryer runs on cool down forever.
Call the mfr and ask them about it. This problem may be pretty complicated. There may be a problem with your board that tells it to go to cool down. Can you set the timer for 45-60 minutes and it stay on heat for that long?
Feb 11, 2009 | Kenmore Dryers
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Dryers Logo
180 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
