Question about InFocus LP540 LCD Projector
Small green mark on screen
My screen has a small green smudge it is only seen when the screen is black it has no color mixing all the colors are fine just this smudge it looks as if some one might have touched a lens or light filter inside..can this be fixed or will it be some kind of foreign object it is green it looks as if a coating has been touched i dont know if it is on lcd part or lens it has one smudge that is the same color but this one is right up in the left and it looks as if it is just outside of the border of the screen the projector lamp has only got 130 hours used i only got it yesterday from eBay i dont know if the clock has been reset but the picture is bright ans sharp it might have a new lamp but some one might have been inside of it...can any one help me sort this out or should i just leave it be..it only bothers me when i watch a movie and it cuts to a dark screen and it looks as if a green translucent worm is an the screen,,but soon as something is under it its gone but back to the dark its back
  • 14,337 Answers
Ingrown worm,lol.
Posted on Mar 18, 2014
Testimonial: "LOL YES GREEN LITTLE DEVIL it looks as if i might just leave it as it is"
SOURCE: Infocus LP70 - It's all Green
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loos cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Assuming that you've made sure that the cable connections are solid at both ends, there is a simple test to verify that this is a cable issue and not a costly projector issue. While the image is tinted green, open the menu. If the menu colors appear fine while the rest of the image is still tinted green it's the cable.
Posted on Nov 21, 2007
  • 16 Answers
SOURCE: Help.....
Hi there.
This is definetly the light tunnel issue. After searching and a million phonecalls, I tracked down a place that you can buy the light tunel for $41 on their own and simply put that in, making the projector good as new.
I Have the phone number of the place and also the link to the forum giving you fully pictured diagrams of how to change the light tunnel, and also I have a service manual if anyone would like it to be sent to them.
Cheers
Russ
Posted on Feb 11, 2008
SOURCE: ask proxima m2+
lamp gets brighter & brighte within a minute & immidiately color wheel stops rotating & projector goes to standby mode. for 3 to 4 minutes again same symptom contimuously observed pls guide me which part is suspected
Posted on Feb 16, 2008
SOURCE: infocus lite pro 720
Sounds like the LCD inside is dying and you're losing pixels. Bummer.
Posted on Sep 26, 2008
projdoc
  • 2236 Answers
SOURCE: Right side of the image is very dim, left side is near normal
the light tunnel is collapsing and needs replacing. it is very difficult to do on your own with out the proper setup. you can send it in for repair, but it'll take them about 1 1/2 hours. the part itself is not expensive. try av solutions in ny. they're pretty good. www.avsolutionsny.com
Posted on Nov 12, 2009
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Gray smudge on edge of paper
If you get only black smudge even when you're printing in color your problem is most likely the black cartridge. If it smudge in colors look at your transfer belt, open the front door, the big belt that hangs on the door.
Dec 02, 2010 | HP Color LaserJet 2600n Printer
Colors mix
there is a problem in signal cable bend it if change in color is seen then replace the cable problem will be solved
Feb 26, 2010 | CTX S965A (Black) (Black, Silver) 19" LCD...
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
My screen turns green and then turns off
you need to adjust the screen voltage. behind the front grille and inside cover. a small black box 6 adjusters protruding from it. only adjust the the color counterclockwise that matches the problem in this case it's the green so look for the knob with "G" marked by it. there are 2 with "g" marked by them the row across the top of the box are for focus don't adjust. back the knob off untill the raster is blank with your input set to an inactive input, the picture should be blank and black.
when it is you have the adjuster close to where it should be, now change the input to an active signal and turn the color off so that you wil have black and white picture. adjust that knob untill you do have a truely black and white picture not too green or red or blue. go back to inactive video input and check that there are no lines of any color on the screen. repeat if needed. always adjust these knobs slowly the set will be watching you ! if your autofocus won't work now you have the adjustment set too low. check this function before putting back together again. these adjustments can be real touchy so be patient
Feb 20, 2009 | Sony KP-57HW40 57" Rear Projection...
Some black colors are replaced with red blue flickreing in whites
Hi there
Firstly reinstall the graphics drivers, if its still the same there is a problem with the graphics card and you'll have to have it looked at.
Good luck and thanks for using Fixya!
Feb 06, 2009 | Fujitsu LifeBook C2340 Notebook
1988 mark 7 color code for sound system
1986-89 Lincoln Mark VII Stereo Wiring Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Red Illumination Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) Pink/Blue Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Green Left Rear (-) Blue/Orange Right Rear (+) Pink/Blue Right Rear (-) Green/Orange
Aug 17, 2008 | 1988 Lincoln Mark VII
Color problem
There are three Cathod Ray guns responsible for the millions of colors.All colors are produced by mixing the three basic colors namely Red Green and Blue (RGB) at suitable proportion. If any one of the three guns fail firing then we get improper colors. This can be rectified by
(1) hitting the monitor at the back by keeping it on a pillow the screen facing down - it will reolve the problem if the failure is due to the loosening of the Head due to repeated thermal expansion and contaction.
(2) check the signal cable for loose connection, twisting etc on both ends - at the back of the CPU and Monitor (it is fixed)
TRY YOUR LUCK
ProfSweetlin
danielswweetlin@gmail.com
Jul 15, 2008 | Samtron 76df 17" CRT Monitor
InFocus LP540 LCD Projector Logo
57 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
