Question about A.O. Smith SQ1102 Pool Pump Motor
Sq1102 hot to touch, how hot should it be? I cannot hold my hand on it.
    President:
  • A.O. Smith Master
  • 1,378 Answers
On to be so hot you can barely put your hand to it. The motor likely has a thermal shut off device on it. If you see "thermally protected" on the motor nameplate, you are safe. If the motor starts to run louder, you will want to replace the bearings and probably the pump seal to avoid a complete failure down the road.
Posted on Jun 14, 2009
Midland 75-785 handheld cb gets hot to the touch when used
check the interior and find out where the hot spot is then replace it.
Apr 21, 2014 | Midland 75-785 Handheld CB Radio
GE rotisserie convection oven Model 898691 very hot
I've got one of these and it says engraved right on the outside of the oven "Hot surface - do not touch" so I'd think that would be expected.
Nov 22, 2011 | Microwave Ovens
Remove impeller from motor
Remove the power plug, remove the back cover, loosen the clamp that holds the capacitor and move it out of the way. With a 1/2 inch open end wrench, (I think it is 1/2 inch) hold the armature via the flats on the rear of the armature. With your other hand, remove the impeller. While you are at it, you should replace the seal inside as well. If you can't get the impeller off by hand (I presume you are removing it because it is damaged) use channel lock pliers to remove it. It may turn off in a direction other than what you are expecting. Try both directions.
When stopping and starting your pump, make sure it is actually stopped before turning it back on. Frequently, air pressure in the filter will run the pump in reverse when you turn the power off to the pump. Starting the pump before the pump has come to a stop will spin the center out of the impeller. 10 seconds should be plenty of time.
Thanks for your question @ FixYa.com
Apr 16, 2011 | A.O. Smith SQ1102 Pool Pump Motor
I have a A O Smith SN 1152 pool pump. The motor just hums when the switch is turned on. The pump is eight years old and I have had no problems until now.
Remove the 4 fasteners that hold the pump head onto the motor and try to turn the motor shaft by hand. If it turns freely, apply power and see what happens. If it turns Ok, then your problem is the pump head not the motor. If the motor does not turn by hand then it needs to be replaced. If it turns by hand but not when power is applied, you may get away with replacing the bearing in it.
Nov 18, 2010 | A.O. Smith SQ1102 Pool Pump Motor
I am trying to replace the motor on a pool pump. How do you remove the front end or impeller to install a new motor?
it may have a left hand thread screw in the front of the impeller turn this screw clockwise to loosen, to loosen the impeler just use a 7/16 or a 9/16 wrench to hold the back of the motor shaft look close you will see a slot in the shaft for the 7/16 wrench just under the centrifugal switch , this will hold the rotor still so you can turn the impeller counter clockwise to remove it
Oct 10, 2010 | A.O. Smith SQ1102 Pool Pump Motor
Honda vlx 600 93 im not shure but the engine ghet too hot ,i ken not put mi hand on it \r\nit supose to bee like that?maibee i need to check the water but i dont know where is the reservoir
The engine will get too hot to touch by hand.
all engines will get too hot to touch when they have warmed up, whether they are air cooled, oil cooled or watercooled
Jun 24, 2010 | 1993 Honda VT 600 C Shadow
What in addition to a pool pump capacator is damaged if the capacator shorts against the grounded cover
If the capacitor was grounded for more than just an accidental touch, it could possibly short the start windings.
Jun 18, 2010 | A.O. Smith SQ1102 Pool Pump Motor
Cord gets hot where you plug into outlet hot meaning warm to the touch but can hold your hand around cord and is comfortable.Is this dangerous? Could this start a fire?
Not dangerous at all. All heaters create some warmth around where the plug enters the outlet. WARM, not hot, if it's HOT too the touch, then it's a problem. Never use extension cords, and never splice the cord... also don't run the wire under rugs etc... you'll be fine.
Feb 28, 2010 | Honeywell HZ-3220BW Compact Heater
Sony Bravia 40" LCD TV generating heat.
First, you will have to define what you mean by "hot to touch" ie.:
can you or can you not hold your hand on it for a few moments.
Apr 27, 2008 | Sony BRAVIA KDL-40V3000 Television
A.O. Smith SQ1102 Pool Pump Motor Logo
625 people viewed this question
Top A.O. Smith Plumbing Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Gil Shultz
Are you an A.O. Smith Plumbing Expert? Answer questions, earn points and help others
