Question about Astoria Coffee Makers & Espresso Machines
Lever don't return
Also middle grp on delivers 1/2 the portion
    President:
  • 1,618 Answers
The head needs to be rebuilt the gaskets or spring or bearings need to be replaced.
Posted on Apr 05, 2014
Brand new Singer 4423 won't go in reverse ?
Your reverse lever may have become disconnected inside the machine. Return it to the dealer if you don't want to fix it yourself.
Jul 29, 2013 | Singer 4423 Sewing Machine
How do you adjust clutch?
On your bike it should be right there at the clutch lever. There should be a large round adjuster lock,screwed onto the actual adjuster. If it is too loose,..loosen the large round nut,and screw the small tube portion out (away from lever) untill it leaves a slight amount of play...about 1/8th of and inch, Then re-tighten the large round locknut. If its too tight,..loosen large locknuut,and screw small portion of adjuster in (towards lever) untill the correct slack is in the lever,then tighten the locknut.
Aug 29, 2012 | 2005 Yamaha WR 250 F
Replacing ink cartridge
Hello!
1. Start with your printer turn on.
2. Lift the ADF scanning unit together with the flatbed scanner glass unit.
3. Wait for the cartridge carriage unit to position itself in the middle.
4. Once ink cartridge carrier in the middle, lift up the carrier lock lever.
5. Remove the black or colored cartridge and replace it, once lever is unlock.
6. Once replaced, return back the lock lever, then return back the top cover lid.
Aug 28, 2011 | Canon PIXMA MX310 All-In-One Printer
Simplex 1000 lever handle when correct combo put in lock combo lock operates fine except unless you let the lever snap back lock dose not reset in locked position, in other words if you slowly let the...
I don't have a direct answer, but here is the contact info you need for customer service:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
1-800-849-8324 (option 1)
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Technical Support (Simplex, E-Plex, PowerLever, 4000 Series, Solitaire 850L, Solitaire 850/950)
1-800-849-8324 (option 3, and then option 6)
Tech Support is probably your best bet!
Aug 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Shifter lever won't return to the " center " position always. The problem is intermittent and seems to occur more in the heat. I've heard there may be something binding the mechanism....
Follow the shifter reach rod that runs from the shift lever back to a short lever on the transmission. Take the nut off and take the rod loose from this short lever. Then, move the forward like you are going to shift into low gear but don't actually shift the transmission into gear. Feel for the spring tension. Then, move the lever backwards and feel for the spring tension there. Check the shift lever and the reach rod for binding. If you don't feel the spring tension trying to return the lever back to the center, it's likely that the shifter pawl return spring is broken. This spring is what returns the shifter lever back to 'center". But,the temperature of the transmission will not change this. If the spring is broken, it's broken cold or hot. If the spring is good and there is not bind in the linkage, the problem may be in the shifter cam mechanism inside the transmission. Either way, this is an internal issue in the transmission.
Good Luck
steve
Aug 20, 2011 | 2006 Harley Davidson FLSTNI Softail Deluxe
The turn signal lever sticks and does not return to the neutral or middle position after the turn is complete.
The canceller mechanism is part of the turn signal switch assembly inside the steering column. The only one I've ever replaced was in a 1965 Mustang, and I had to pull the steering wheel. Of course that was before air bags, which can be activated if you don't follow the correct procedures.
I would not try to repair this one yourself. Get a few estimates, you may want to just learn to cancel it manually. I'd guess this will cost somewhere around $100 to $200, but I don't know.
Apr 28, 2011 | 2001 Toyota Sequoia
Got it for Christmas and love it, but it is very glitchy: sometimes doesn't return to last page read, sometimes shuts down and reboots in the middle of reading, sometimes takes FOREVER to power up -...
This looks like a hardware defect covered by the 1-year limited warranty, assuming you did not mistreat your device like dropping it into a bathtub or running your car over it a few times.
Contact Amazon Kindle support:
  • In the United States: 1-866-321-8851
  • Outside the United States: 1-206-266-0927
In general, you will need to deliver your Device, postage paid, in either its original packaging or in equally protective packaging to the address specified by Customer Service. Before you deliver your Device for warranty service, it is your responsibility to backup any data, software, or other materials you may have stored or preserved on your Device. It is possible that such data, software, or other materials will be lost or reformatted during service.
Your Kindle will be repaired, replaced, or refunded.
Jan 14, 2011 | Amazon Kindle 3 WiFi
When I shift my 02 GSXR 600 the gear shift lever gets stuck
Get yourself a repair manual and find out what it says, but I think you are correct, the return spring is either broken or it has slipped. Try this site for a freebie manual:
http://www.carlsalter.com/motorcycle-manuals.asp
Jan 27, 2010 | 2002 Suzuki GSX-R 600
My shutter was et at 60. When I set the lever and
You can try the coupler on the bottom of the camera. It is on the take up spool side next the the rewind release button. A penny will fit the slot, turn it clockwise, (looking at the bottom of the camera). It will only turn about 120 degrees (1/3 of a turn).
If that does not work, there may be a broken part in the top area of the camera.
Jan 07, 2010 | Nikon FE 35mm SLR Camera
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
noel
noel
J.D. Browning
J.D. Browning
Kolbrun...
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
