Question about Life Fitness 95xi Elliptical Crosstrainer
Life Fitness 95xi elliptical electronic panel will turn on but after a few seconds the screen goes blank and evenutally starts back at start up screen.
Im not sure if its the battery or not, any help would be greatly appreciated.
  • Life Fitness Master
  • 914 Answers
I would suggest verifying 6 volts output from the battery. From there, check the reed switch connection on the power control board. Also verify the gap between the reed switch and the magnet on the pulley. It needs to be close enough to the magnet to get a good reading. I am attaching a link to a video that shows the reed switch replacement procedure. You can see the magnet and also the slots in the reed switch that allow the adjustment. LifeFitness 95Xi Crosstrainer Video Reed Switch Replacement Speed Sensor
Posted on Apr 23, 2014
5 Suggested Answers
knight_nemes
  • 11 Answers
SOURCE: Life Fitness 9100HR Treadmill won't start
Typically a non start up of any electrical Exercise equipment raises alot of red flags If this treadmill will not start Check the internal fuse MAKE SURE ITS NOT PLUGGED IN!!!! UNPLUG IT FROM THE WALL
2 If there is NO Fuse and you just bought it new Return it for an exchange.
3 Check your wall outlet for less then 5 Bucks you can buy a wall outlet tester that tells you if your Outlet is good Or Bad.4 DO NOT Attempt to service this item on your own the way they make treadmills you have to have a qualified service tech come out and fix it because the risk of serious shock or death is emminent.
Posted on May 04, 2012
  • 59 Answers
SOURCE: my treadmill life fitness 9100HR won't start
Have you checked the drive belt @ the motor, if it is OK then check the fuse, if it is ok then the brushes in the motor may be worn out
ercupa190
  • 12223 Answers
SOURCE: how do i get the hours info from a life fitness 9500 hr elliptical
go to the MENU, and see the details.
However your must read your instr. manual and see how to enter.
God bless you
Posted on Dec 05, 2012
ercupa190
  • 12223 Answers
SOURCE: life fitness crosstrainer 9500 HR just shut down few second after start
see the video and fix it. This happen because the lack of maintenance schedule.God bless you
Posted on Apr 04, 2013
Lifefitness 95xi wont turn on
Check the speed sensor to turn on the elliptical, or send the lower board to repair with www.xtremefitnessservice.com, ask for Javier
Sep 26, 2014 | Life Fitness 95xi Elliptical Crosstrainer
Electrical issue.
check the battery or alternator that charges it. battery is usually front end and alt is in the back. if this is not it it could be the the controller board
Mar 18, 2014 | Life Fitness 95xi Rear Drive Commercial...
Where is the battery on the life fitness 95xi
The battery is located in the front of the rear drive mechanism. It is mounted just below the alternator control board. The following video shows the battery location along with the battery replacement procedure. Battery 6 Volt 2 5 Amp Hr LifeFitness 0017 00003 0685 SPORTSMITH net
Dec 29, 2013 | Life Fitness 95xi Elliptical Crosstrainer
Life fitness 95XI elliptical clanks
You may still have the original tie rod design on your machine. If so, more than likely this is your problem. The link below is the updated fix for the original design.
Control Link Kit LifeFitness GK62 00002 0071 SPORTSMITH net
Dec 16, 2013 | Life Fitness 95XI Elliptical Trainer...
Eliptical 9500 HR lifefitness lights then stos
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Start by checking your battery for the proper voltage output. The following are some helpful videos.
Nov 10, 2013 | Life Fitness Remanufactured 95Xi...
95xi machine goes into pause mode when being used.
Check the gap between the magnet on the drive pulley and the reed switch that is mounted to the frame.
Aug 05, 2011 | Life Fitness Remanufactured 95Xi...
How to reaplce a battery on the life fitness 95 xi
u open top rear hood and you will see battery on there
Nov 19, 2010 | Life Fitness Remanufactured 95Xi...
Life Fitness 95xi Elliptical Crosstrainer Logo
308 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
