Usb cable connected to laptop and printer but isnt printing
SOURCE: Unable to print
Disconnect your printer and go to the HP web page and down load the latest driver. Follow the install instruction and only connect the printer when the software instructs you to. The windows plug and play has conflicts with HP printers. Ignore any window messages that say the the software is not on their compatablity list. Restart the computer. Anything in the printer que will start printing. Make sure you cancel any duplicates or you may have hundreds of pages printing. Also go into the control panel and click on printers and faxes and delete the old printer profiles. Select the current printer as the default
SOURCE: connect to usb on laptop
The Easy affordable solution:
www.sewelldirect.com or (801)356-3823
* USB to Parallel Adapter, part # SW-1302 ($14.95) + * Centronics to Mini Centronics, Part # SW-2104 ($12.95).
I ordered before 2pm EST and received two days later.
Plug usb into computer, wait, then plug in printer. Voila! Instantly worked!!
PS: Found this site after www.monoprice.com Product ID: 2277 (parallel to USB) and ID 257 (male to mini) - $15
SOURCE: printing through wireless
hi,
if you had the printer before using the USB cable. then you changed it to wireless, try the ff:
1. re-insert the CD the came with the box, the cd that you used to install the printer Software to your computer.
2. after inserting the cd, it will give you option "add a device".
3. click on that to install the printer driver for WIRELESS.
note: the reason why you cant print, is mainly because the printer driver you have is still for USB connection. so inorder for you to be able to print, you need to install a printer DRIVER for wireless... That should WORK..
adonscott
HP TECH
SOURCE: Can I connect the printer directly to my laptop using ethernet cable
Hi!
If the computer is connected to an HP All-in-One on a network, you can access the Embedded Web Server that resides in the HP All-in-One. The Embedded Web Server is a web-based user interface that provides some options not available on the HP All-in-One control panel, including advanced network security options. The Embedded Web Server also enables you to monitor status and order printer supplies.
For information on how to use the features available in the Embedded Web Server, see the onscreen help within the Embedded Web Server. To access Embedded Web Server help, open the Embedded Web Server, then click the Help link under Other Links on the Embedded Web Server Home tab.
NOTE:
Only use the Embedded Web Server to change network settings if you cannot access the HP All-in-One control panel, or you need to change an advanced option not available on the control panel.
Access the Embedded Web Server
Use the following instructions to access the Embedded Web Server. You can only access the Embedded Web Server on a computer that is connected to an HP All-in-One on a network.
Good Luck!
SOURCE: printer keeps saying usb cable not connected
1)right
click the my computer icon
2)click
properties and then click hardware n go to device manager.
3)uninstall
all usb ports and then scan for hardware changes
4)ur
pc will detect your printer and ask for printer drivers
5)re
load drivers and your pc will communicate with your printer
6)for
reloding install the cd follow the instructions on the screen and click next
7)restart
when the printer is loded.connect the wires and cords properly.
