Question about Epson Stylus® RX640 All-In-One InkJet Printer
Cannot find IP address
I need to connect my tablet to my printer to print a document but cannot figure out how to find IP address or how to in set up
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
Pair tablet with printer. Manual, manual, manual READ it that's what it's for
Posted on Apr 29, 2014
4 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: Hi: I have an Epson
Router model?
Posted on Oct 28, 2010
  • 4 Answers
SOURCE: Hi, my computer cannot connect
maybe your network have DHCP server. WHen you set the IP on your printer, please select "specified the IP address, not select use DHCP.
Posted on Mar 18, 2011
  • 8404 Answers
SOURCE: Default printer port
Delete the printer and reinstall for best results.
Posted on Aug 09, 2012
Cant print. im offline
Sounds like you can no longer connect to the printer. Is the printer a wireless connection? Check if it is and if so, verify that the IP address you used to originally connect to the printer is still valid.
If you have admin rights to your desktop PC, the easiest fix is to create a new printer device. Use the add device option, select printer (remember to let the operating system know the printer is a wireless printer on the network) and let the operating system locate the printer. It should find the printer and when you select it, it will label the printer the name of the printer with the number one (1) beside it. Then proceed with printing.
The more difficult way still requires having admin rights to the computer. Just select the printer, right-mouse click over the device and select "Printer Properties" and select "port". Then select configure port. To re-configure port you need to know which IP address the printer currently uses. The IP setting should be found in the "Settings" menu on the printer. Once you have the current IP Address, enter that into the field on the Configure Port menu and save the changes. That should allow you to print again. Most likely you will have a backlog of unprinted documents so remember to kill off any documents you no longer need to print.
Jun 11, 2012 | Brother Mfc 8890 Dw Copier Printer Fax...
How do i set the ip address for e250dn
Follow these steps: 1. Press the "Operator Panel" button to print a Network Setup page.
2. Locate the entry labeled "UAA" or "Physcal Address."
3. Write down the 12-digit address. An example is "00:1A:2B:3C:4D:5E."
Set the IP Address 1. Insert your Lexmark drivers CD and select "View Documentation."
2. Select "Software and Utilites" and click "IP Setup Utility" to start the program.
3. Enter the physical address for the printer in the "Discover Print Servers" field and click "Discover."
4. Select the printer from the "Configure Print Servers" list and click "TCP/IP Settings."
5. Click "Suggest Address" if you'd like the utility to locate an available IP for you, or enter the IP of your choice in the "IP Address" field and click "OK.
May 22, 2011 | Lexmark E250dn Laser Printer
Got a new router and can't connect the printer wirelessly
In this situation your wireless printer might require a power reset before you print each document. Though the printing activity will take place efficiently you will have to physically go and power the printer to enable it to print. This problem might require you to reload the firmware of the router and set the wireless printer to manual IP address in order to make it work seamlessly no matter how many documents you have to print.
Nov 09, 2010 | HP OfficeJet J4580 All-In-One Laser...
I need to get a wpa passphrase how do i get 1
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
How do i set up my wireless canon printer to my laptop? I keep getting messages saying can't find the printer.
Instructions
· USB printer
· Ethernet cable
· Computer
1. Step 1
Step 7
Step 10
Mar 21, 2010 | Canon PIXMA MP600 all-In-One InkJet...
How do you set the ip address on an IBM 1222
Any queries regarding Ip-details, please log in to, http://www.ip-details.com/ which gives you the latest information and a accurate solution for your search.
Feb 04, 2010 | IBM Infoprint 1222 Laser Printer
Just installed printer and drivers via a network connection for Vista 32bit. I did this per the instructions Provided by Konica at ftp://ftp.minolta-qms.com/pub/crc/out_going/manuals/misc/km_vista...
I presume that the IP Address in the instruction is just an example IP Address. I don't know if your printer is connected to a router or to a Hub or Switch, but your printer's IP Address should depend on the device that provides the IP Address and the example is router. The first 3 octet of the Printer should be the same as the router's. So the setup should be router->printer then router->computer.
Feb 03, 2010 | Konica Minolta magicolor 2430 DL Laser...
I have a netgear wgps606 wireless print server. I
Manual Configuration of WGPS606 Print Server
Note: Before configuring the printer server please check if you printer is compatible. You may open this link to you web browser: http://kbserver.netgear.com/kb_web_files/N101216.asp.
1. Please make sure that the printer works when connected directly to the computer.
2. Confirm the wireless settings of your router. You should have the SSID, wireless security and IP address of the router.
For NETGEAR routers please follow these instructions to check the wireless settings:
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. Click on Wireless Settings under Setup tab and you may get the wireless settings on that page.
e. On the left side under Advance setup, click on the LAN IP setup and locate the LAN TCP/IP Setup. Underneath that is the IP address of the router.
Note: If your IP address is 192.168.1.1, then you may use 192.168.1.200 for your print server.
3. Please connect a computer to the print server. At this time, the router is not connected. The printer should be connected to USB1. The power, LAN port and LPT1 should be lit.
4. Assign static IP address to the computer.
a. Click on Start and right click on Control Panel.
b. When the Control Panel window opens, double click Network Connections.
c. Right click on Local Area Connection, then click Properties. When the Local Area Connection Properties window appears, click Internet Protocol (TCP/IP) then hit Properties button.
d. Change the option from Obtain an IP address automatically to Use the Following IP Address and enter the following:
IP: 192.168.0.50
Subnet Mask: 255.255.255.0
Note: Leave the default gateway and DNS addresses blank.
f. Click on OK and then Close. Exit out of all the Windows.
5. Ping the print server.
a. Click on Start and then Run. Type cmd and hit OK.
b. On the DOS prompt, type ping 192.168.0.102. This should give four responses.
c. If it gives request timed out or destination net unreachable, please turn off both print server and computer. Wait for few minutes, then turn it on again. You can also try holding the reset of the device. Then repeat steb 5.b.
6. If you are able to get replies, you may now open Internet Explorer and type 192.168.0.102 on the address field.
7. After hitting go or enter on the address field, it will ask for a login. (Please type in admin for Username and password for Password).
8. Click on Wireless Settings under Setup tab and we need to set the same SSID as your router.
9. Please also select the appropriate Wireless Security and type the network key or wireless password from the router. Then click on Apply to save the settings.
10. When you get back to the page, click Print Server settings.
11. Check Change to and set the following:
IP address: 192.168.1.200 (It should be on the same range as the router. e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router). This will be the print server's IP address.
IP mask: 255.255.255.0
12. Click Apply to save the settings. We will get a Page cannot be displayed.
13. Set the IP address of the computer back to dynamic.
For Windows 2000 and XP:
a. Please click on Start, select Settings and then Control Panel.
b. Double click on the Network Connections icon.
c. Right click on Local Area Connection and click on Properties.
d. Scroll down to Internet Protocol (TCP/IP) and click on Properties.
e. Select the option Obtain an IP address automatically and Obtain DNS server automatically.
f. Then click on OK.
For Windows 98 and ME:
a. Please click on Start, then Settings, and then Control Panel.
b. Double-click Network then select TCP/IP for the Ethernet adapter. Then click on Properties.
c. Go to IP address tab and select Obtain an IP address automatically.
d. Click on the Gateway tab and delete the numbers under the Installed Gateway.
e. Click the DNS Configuration tab, and then select Disable.
f. Click on OK. Windows will then prompt for a restart.
14. To set up a TCP/IP port to the computer, please follow these steps:
b. Double click on Printers and Faxes.
c. Right click the printer icon and go to Properties.
d. Click Port Tab and click Add Port.
e. Select Standard TCP/IP port. Hit OK or Next.
f. In the field for Printer Name or IP Address: enter the IP address of the Print Server and click on Next.
g. Select Custom and then click Settings.
h. Under Protocol select LPR, and for Queue Name, type L1 if printer is connected to the print server USB port 1 and L2 if the printer is connected to the 2nd port.
i. Click on OK, then Next, and Finish.
j. Lastly, please right click on your printer icon and select Use Printer Online. If this is not an option, disregard it.
15. Check if you can print through the print server.
16. If it is not printing, then please try to connect the print server to the router and check if you can print. If it can, then there might be a need to re-do the steps for wireless configuration of the printer server.
Mar 29, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
My printer doesn't want to print. I've owned this printer since 4/19/2002. I had no problems since then. Yesterday I had to print some documents, it came out some lines between the documents so I...
How are you connected from the printer to the computer?
What you want to do is first go into the print driver and open the port properties. And be sure that the port settings are correct.
If you are connected via an ethernet cable. You need to be sure you IP address is correct and did not change on you.
If that happened you want to go into your printer and set up the address again, set it to manual, and re enter the proper IP address. And if there is an IP filter on the printer, make sure the setting is OFF.
Also try new cables, Something may have happened to one of them.
Apr 17, 2008 | Office Equipment & Supplies
Documents not printing
Hi How to check the print server is in the wireless network or not!! Check under the Router Setup page Router's ip address... Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range.. If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN... Try the following steps. 1. Go to run and type "cmd" press enter 2. type ipconfig. 3. Check the range of ip address...if its 192.168.0.XX 4. Try pinging that ip address.. 5. If able to ping the router and print server.. Then the wireless network is fine... Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
May 30, 2007 | D-Link DP 301U (DP-301U) Print Server
Epson Stylus® RX640 All-In-One InkJet Printer Logo
151 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
